  1. Jul 25, 2023 at 9:19 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Gotcha. That makes more sense. :thumbsup:
  2. Jul 26, 2023 at 7:54 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Question:
    Are there any upgraded powersteering pumps that people run. My turning has been feeling heavier than normal and I want to replace the pump but curious if there is a better option over stock?
  3. Jul 26, 2023 at 8:25 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Not really, no
    Clean the reservoir screen and make sure your rack isn't leaking. You can drill out the flow restrictor if you want but it can have some unintended side effects
  4. Jul 26, 2023 at 8:43 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Basically this. I haven't found anything that lasts as long as OEM too, rack and PS pump included. Basically I am under the impression that I will always have a slight whine and leak after a year or two even when bought brand new. I wish we did have a better option though, it's crazy going from my new DD on 35's to the Tacoma on the same size, steering feels so underpowered.
  5. Jul 26, 2023 at 8:51 AM
    Wulf
    rock raisin
    interesting, my steering effort is pretty low compared to most of my fleet -- granted my truck idles at like 900-1000 rpms so the pump is flowing more than yours is at a normal idle RPM
    If you drill out the flow restrictor you will have more fluid volume at low rpm and lower steering effort but it will make the steering slower and increase pump whine even more.
  6. Jul 26, 2023 at 9:41 AM
    Dan8906
    Daniel
    Concord, California
    yeah I’m on a brand new oem rack and added a cooler at the same time for larger fluid volumes. My pump is original with about 115k miles and a lot of those being wheeling and getting beat on. Figured it would be a good time for a new pump.
  7. Jul 27, 2023 at 10:39 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Finally had a free minute (over a long lunch) yesterday to get smogged. No issues on the smog, but I think it's cause the shop was too busy damaging my front brake line. Brake pedal to the floor at the first stop light as I drove away. I bet those f:censored:ers do that to a few vehicles per month expecting them to turn right around and they'll be happy to fix it that day.
    Front brake line was cut just below the upper attachment to the spindle. bone-head place. Nothing else could interfere with the brake like there. :facepalm:Like if it were cut directly at the bend of that attachment point they'd have a case to say it was chafed through or something, nope, cut below it.
    Safely limped home using gearing and the e brake to stop. Luckily didn't drain the master cylinder. Cut the line the rest of the way and plugged it with a machine screw that fit inside the line. Ordered some new brake lines that'll be here Friday.
    Pretty shitty when you can't even take your truck to get smogged. I didn't give the shop a chance for an explanation or to fix it. Gotta go through the rest of the truck when I do the lines to see if they got creative anywhere else.
  8. Jul 27, 2023 at 10:55 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    turbodb, unstpible, jubei and 3 others like this.
  9. Jul 27, 2023 at 11:17 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    You should rebuild your OEM pump. Aftermarket pumps are real hit and miss. You can rebuild the original pretty easy. This thread, https://www.tacomaworld.com/threads/power-steering-pump-rebuild-how-to-with-photos.377002/ will show you how to do it.
    Here are links for rebuild kits:
    4 Cyl 2.7 3RZ rebuild kit: https://www.toyotapartsdeal.com/oem/toyota~gasket~kit~power~steering~pump~04446-04020.html
    6 Cyl 3.4 5VZ rebuild kit:https://www.toyotapartsdeal.com/oem/toyota~gasket~kit~power~steering~pump~04446-04010.html
    unstpible and ztwatson like this.
  10. Jul 27, 2023 at 11:24 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Just another reason to never live in California. Sorry you had to deal with that nonsense though
    Fantastic11 likes this.
  11. Jul 27, 2023 at 11:27 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    o_O
  12. Jul 27, 2023 at 11:32 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'm not understanding this.
    There is nothing, at all, that would be performed during a smog inspection that would have anything to do with a brake line. And if it's a test only smog Test Station, they aren't allowed to make any repairs to a vehicle. (I would never get a smog for any shop unless it's a test only station).
  13. Jul 27, 2023 at 11:35 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    It wasn't a test only. Agree - they shouldn't have been anywhere near the brake lines- but they were, and they conveniently have an auto parts store in the same building..
    Appropriate complaints have been filed, and reviews have been left.
    Kwikvette likes this.
  14. Jul 27, 2023 at 11:36 AM
    Red_03Taco
    Jerad
    30 years in AZ, never once had to get an emissions test
  15. Jul 27, 2023 at 1:50 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Rub it in why don’t you!
    …well how hot is it there rn? :boink:
  16. Jul 27, 2023 at 2:17 PM
    Red_03Taco
    Jerad
    Not trying to rub it in, just trying to offer solutions :thumbsup:
    It's 92 here in Prescott right now, so not too unbearable. Not recommending Phoenix, Tuscon, or the Western part of the state. Northern AZ ftw!:oldglory:
  17. Jul 27, 2023 at 2:23 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Northern AZ has a lot to offer. Spent a few weeks up in Sho Low about 12 years ago, was a nice up there.
    DIRT YOTA likes this.
  18. Jul 27, 2023 at 2:27 PM
    Red_03Taco
    Jerad
    Indeed. Lots of wildlife, camping, hunting, hiking, kayaking, etc, with reasonable weather. Looking forward to putting a turbo on my Tacoma and really rubbing in the no smog part then lol:mudding:
    CS_AR, Tour991[QUOTED] and DIRT YOTA like this.
  19. Jul 27, 2023 at 2:28 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Shit that temp is not very Az like :D the project I’m covering is in high 90s to low 100s this week :bananadead: at least I live 10 mins from coast and it’s way cooler.
    And for the record leaving Cali sounds better and better… especially since I blew leg/knee out and don’t chase swells anymore.
  20. Jul 27, 2023 at 2:29 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    As you should!!! I’d be LS swapping my truck right away!
    Red_03Taco[QUOTED] likes this.
