  1. Aug 21, 2023 at 9:46 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    How are you going to determine just how the 555s are holding up?
  2. Aug 21, 2023 at 9:57 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    That's rad. Those fit perfectly. The PO of my truck installed MDF enclosures on either side.
    I'm hesistant to put woofers back in them though cause I think the boxes will rattle against the outer skin of the cab.
  3. Aug 21, 2023 at 10:04 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    I had to add a "leg up". (getting old)
  4. Aug 21, 2023 at 10:18 AM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Here's to making mistakes and hoping it works out anyway.
    Was getting annoyed with having to top off the oil frequently and park on top of a cardboard box to keep oil off the garage floor. My drivers side cam plug has been leaking for a while and now with the turbo it's much worse.
    I'm really not sure why it's leaking to begin with since I replaced the cam plug and resealed the half moons when I replaced both valve cover gaskets.
    However if it leaks this time I'll have an excuse and it's totally my own damn falt
    :anonymous:
    I put the cam plug in backwards. I put the plug in the collar without thinking about the direction and put the rubber face on the inside then bolted the collar down and proceeded to put it all back together.
    I have a feeling I'll be back in there fixing the same leak in the very near future but at least I already have all the parts
    ztwatson likes this.
  5. Aug 21, 2023 at 10:36 AM
    unstpible
    Derek
    Cedar City, Utah
    Truck did that to my wife once when she took it to work on a bad weather day and it hasn't happened again but I feel like I'm waiting for it to happen every time I drive it.
  6. Aug 21, 2023 at 10:42 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Those cam plugs only fit half ass decent, I put some Toyota black FIPG on them before cinching them down. And of course on all the sharp edges of the cam caps that the valve cover gasket sets onto.
    unstpible[QUOTED] likes this.
  7. Aug 21, 2023 at 11:08 AM
    unstpible
    Derek
    Cedar City, Utah
    I did use the black FIPG. I think that might have been why I started to rush getting it back together and didn't catch that it was backwards in time.
    I also noticed a couple imperfections in the Doorman valve cover that I sanded out to help the gasket seal better and I used a square this time around to insure the half moons were nice and flat.
    Speedytech7[QUOTED] likes this.
  8. Aug 21, 2023 at 11:14 AM
    unstpible
    Derek
    Cedar City, Utah
    Oh and the light right above the engine bay in my shop stopped working again so that was pretty annoying. Usually there's decent lighting. Idk why the fixture is having issues
  9. Aug 21, 2023 at 1:11 PM
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    Odd Question but someone here might know, I am thinking about putting SPC UCA on, but want to keep the factory wheels and 33x10.50s. I have a 1/2" of clearance to the factory upper currently and no issues rubbing at all on them. But was curious if SPCs or even a JBA will end up sticking out any farther and contacting.
    I don't really want to run wheel spacers since I have almost zero rubbing on factory offset. IMGP0795.jpg
  10. Aug 21, 2023 at 1:27 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    unstpible and Dirty Pool[QUOTED] like this.
  11. Aug 21, 2023 at 1:39 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    That's where I saw them, I thought it was you but but I was looking only at your bumpers.
    I had wanted to get them when I made the bumper but life got in the way.
    I went with the zinc finish and that was a mistake, couldn't get any type of primer to stick at all no matter how much I sanded/wire brushed/sand blasted etc. Ended up with a dip in a Muriatic acid bath. 3 minutes of foaming later, nice bare metal and paint stuck well.
  12. Aug 21, 2023 at 1:42 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    As someone far less detailed than yourself, my plan was to stick a prybar on them occasionally and hope they don't develop noticeable play as soon as the OEM joints. :D
  13. Aug 21, 2023 at 1:45 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Just count the miles until the wheel falls off. Compare to previous wheel off adventures.
  14. Aug 21, 2023 at 2:11 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    I don't see that method working with the 555's due to their construction. Between the ball and the cap/cover is a compressed slug of rubber forcing the ball against it's seat. That's essentially a spring continuously taking up any play that would develop as the ball/seat wear.
    Not saying they are not a viable option, just that the "play" thing does not apply. You always see folks saying "I been running them for X years with no play".
    I once did some measuring on the cut away OE joint and found that there would be around 0.10" or 3/32" play when the plastic liner wore thru and ball was rubbing on the joint housing. That's like 5 times the Toyota spec for play and the point when the integrity/strength of the joint starts to deteriorate, rapidly.
    https://www.tacomaworld.com/threads/ooof-another-lbj-bites-the-dust.712577/page-3#post-25355440
    Again, just something to be aware of, maybe replace them on some schedule devined from the trail gods.
  15. Aug 21, 2023 at 3:01 PM
    betterbuckleup
    Ian
    Concord, CA
    So you're saying there's really no way to check for play in the 555 joints at all?
  16. Aug 21, 2023 at 3:24 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Well, yes.
    I should say "no practical way".
    One could measure how far the ball stud protrudes from the joint body (wear of the seat) before and after but that would be a moderate pain and need a bunch of checks over time to mean anything. Hence the suggestion for R+R on some schedule that has not been determined and would likely vary considerably from user to user.
    Squeaky Penguin likes this.
  17. Aug 21, 2023 at 4:03 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
  18. Aug 21, 2023 at 6:08 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    FYI - these were clutch on our Rubicon trip
    The wing nut makes it tough to get some air chucks on. So, I bought these.
    The nut instead of the wing nut should work better.
    But either way they work... they can save your bacon.
    unstpible likes this.
  19. Aug 21, 2023 at 6:15 PM
    Squeaky Penguin
    Brett
    If there was enough wear to have a measurable difference in length, you don't think you could find some amount of vertical play with a pry bar? Maybe not the audible clicking I just heard with my bad OEM joint.
    Edit: reread the post you linked and answered my own question.
    Now to cut apart the joint I just removed for science.
    unstpible and Digiratus like this.
  20. Aug 21, 2023 at 7:28 PM
    Squeaky Penguin
    Brett
    Don't know if I learned anything after taking the porta band to it, but it was oddly therapeutic. :rofl:
    I do think after seeing how it works first hand, and inspecting it, that the small but noticeable play I was achieving with the pry bar would not have caused a failure for much, much more time.
    jubei, unstpible, Winkle99 and 2 others like this.
