  1. Sep 16, 2024 at 10:01 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Good shot of showing why the 2pc driveshaft is good for clearance.
  2. Sep 16, 2024 at 10:06 AM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
  3. Sep 16, 2024 at 10:37 AM
    koenbro
    koenbro Well-Known Member
    Phoenix, AZ
    2001 Tacoma SR5 Xtended cab 3.4L 5Spd
    No way I'd feel comfortable driving this truck at 100+ miles per hour, limiter or not.
  4. Sep 16, 2024 at 10:45 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I used that thread to decide which bolts to use. And used the best ones tested when I installed the TC LBJs.
    3 of the 4 bolts broke. One of the bolts hung on but was bent to shit. (The reason my tire didn't flop all the way out). This was not a situation where one of them backed out and then caused the others to break. The LBJ bolts are some of the few bolts I actually RELIGOUSLY follow the torque spec (with blue loc-tite). I can't really even come up with an explanation that makes any sense on how it would have happened. I didn't take any hard hits, it was a relatively normal wheeling trip. I was going about (literally) 2mph, in shallow sand, when they let go.
    For the record, I'm absolutely not saying the @TotalChaos LBJs were the fault. They absolutely were not. It was 100% the bolts that failed. And if memory serves correct, TC doesn't even provide bolts with the LBJs. I may be wrong about that, but I used bolts ordered specifically based on the observations of the thread mentioned above.
    But the point I made earlier is that the TC LBJs DO NOT "solve" the problems. Because the vast amount of LBJ failures, I've seen, have been the bolts. The TC LBJs do absolutely nothing to address that part of the problem.
    unstpible[QUOTED] and Bandido like this.
  5. Sep 16, 2024 at 10:49 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    That sucks. I always have anxiety about those bolts for the same reason on what happened to you...
    One thing worth noting though is that loctite changes the torque spec for fasteners. Not saying that's why it failed in your case, but the wet torque is different than dry torque. I use blue loctite on mine as well and have been fine thus far, but do plan to swap out to one of the stronger fasteners mentioned in that thread.
  6. Sep 16, 2024 at 10:52 AM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    My TC Uniball LBJs came with the 4 bolts to attach the spindle. Matter of fact, they were 2 different lengths, for the inner and outmost.
    unstpible likes this.
  7. Sep 16, 2024 at 10:58 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    We couldn't get the bolts back out of the blind holes (nearest wheel). So we had to do this, to limp off the trail to where we could get a tow.
    Now that I have sacrificial spindles to work with, I'm considering seeing how drilling and tapping the blind holes to M12x1.25 would work. The blind holes are the ones with the locators in them on the LBJ, so those holes are already, basically, halfway drilled to M12 diameter anyway (then with the locator sleaves pressed into them.)
  8. Sep 16, 2024 at 11:02 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I had a zip lock with 8 brand new LBJ bolts in my kit. It may have been the ones that came with the LBJs.
  9. Sep 16, 2024 at 11:13 AM
    Truckstop13
    Truckstop13 Well-Known Member
    Los Angeles
    1999 Red TRD Off Road SR5 Extra Cab 4X4
    TRD Supercharger, headers, Cold air intake, MagnaFlow exhaust, ARB front bumper, Kennesaw Mtn rear w/ tire mnt, OME suspension with beefed up rear springs with 2 1/2” lift, 285/75/16 tires, Shell, Contractors rack, Road shower and 120v inverter in cab.
    I installed some 6112/5160’s. I need to put some more miles on them to really tell, but it felt more solid and there was less body roll, which was a nice change. My suspension was pretty tired. I need to change out, or get my leaf packs rebuilt next.
    Big shoutout to @memario1214 with http://hotshotoffroad.com/. Shipping was same day on the 5160’s and his communication was great.
    BYJOSHCOOK and unstpible like this.
  10. Sep 16, 2024 at 11:14 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    You do what ya gotta do...
    Pic credit to @SwagThor
    betterbuckleup likes this.
  11. Sep 16, 2024 at 11:15 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Okie engineering credit to @CrashN'Burn (I'll never doubt you again brotha)
    CrashN'Burn likes this.
  12. Sep 16, 2024 at 11:16 AM
    unstpible
    Derek
    Cedar City, Utah
    I was thinking about that last night since the bolts were a common fail point glad to see you looking into bigger hardware so I can watch :popcorn: definitely keep me posted on the progress and I'm glad that at least one bolt was hanging on for dear life. I had a buddy trying to tell me to get the chaos BJ and I tried to tell him the joint wasn't my concern and he wasn't understanding why so thanks for being a perfect case study haha
  13. Sep 16, 2024 at 11:16 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    And how good the tank tuck looks :cool:
  14. Sep 16, 2024 at 11:19 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The tank tuck was a GAME CHANGER for me, for sure. @eimkeith kit is good stuff!
    (And on the subject of drivelines... I'd agree that picture is a perfect representation of why a single piece DL is NOT a good idea. I would have been through about 10 drivelines, by now, if not for the 2 piece design.)
  15. Sep 16, 2024 at 11:27 AM
    unstpible
    Derek
    Cedar City, Utah
    I wanna see! What's happening? The image didn't load haha
  16. Sep 16, 2024 at 11:30 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    We've got lots of footage from the weekend. Should be up on our YouTube by the end of the week. I'll probably start editing tonight.
    unstpible[QUOTED] likes this.
  17. Sep 16, 2024 at 11:34 AM
    unstpible
    Derek
    Cedar City, Utah
    I'm not on YouTube much but I'll give it a look when you send it out
  18. Sep 16, 2024 at 12:30 PM
    unstpible
    Derek
    Cedar City, Utah
    Just ordered 16 of the black bolts with washers PN 90119-10933
    I have reused the previous black bolts I ordered a couple times now since I had to take it apart twice for my passenger dif seal so I might as well replace them before Trail Hero starts in a couple weeks
    I also ordered a new steering rack. Larry Miller Toyota has it listed at $570 with a 30% discount and they even added free shipping on the rack so might as well get the hardware shipped at the same time.
  19. Sep 16, 2024 at 1:29 PM
    betterbuckleup
    Ian
    Concord, CA
    Do you plan to use the rubber boot with those bolts as well?
  20. Sep 16, 2024 at 1:36 PM
    unstpible
    Derek
    Cedar City, Utah
    Nope
