  1. May 1, 2013 at 9:40 AM
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    fixed!
  2. May 1, 2013 at 10:18 AM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Sorry to hear that. Put it in the tidewater thread. You might get a buyer.
  3. May 1, 2013 at 12:08 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    I'm thinking of doing a front end conversion for this summer. I found a good deal on a 01 hood and grille. I've been doing research and know I still need the headlights. However what I couldn't find is if I need new corner lights and fenders? People seem to be indifferent about both
  4. May 1, 2013 at 12:11 PM
    livel0veryde
    livel0veryde Well-Known Member
    josh
    missouri
    Tacoma based buggy
    Finished tubing for 35s
  5. May 1, 2013 at 12:15 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Looks good!!
  6. May 1, 2013 at 12:22 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    New good, grill, headlights, corner lights, fenders, bumper.
  7. May 1, 2013 at 12:39 PM
    Madjik_Man
    Colorado Front Range
    For a 98-00 to an 01-04 swap you will need a new hood, hood latch, grille, headlight assemblies, and bumper fillers. If you want to switch bumpers, then obviously you would need a new bumper too.
    Here's a helpful link to STLHarry's swap. He went from an 01-04 to a 95-97 swap
    http://www.tacomaworld.com/forum/1st-gen-tacomas/95766-how-95-5-97-grille-swap-onto-01-04-a.html
  8. May 1, 2013 at 12:40 PM
    Madjik_Man
    Corner lights and fenders are not necessary.
    At least according to STLHarry who did this swap (in reverse)
  9. May 1, 2013 at 12:43 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Corner lights will only be if you swap fenders. Which while they are all basically the same..id do if you want it.."authentic" i guess. Each sub generation has different fender flares and slightly different front fenders.
  10. May 1, 2013 at 1:20 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    wut?
  11. May 1, 2013 at 2:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    was thinking of you. :D
  12. May 1, 2013 at 2:45 PM
    RangerNelson
    RangerNelson Active Member
    Burlington, NC
    02 Tacoma
    5100's on front, Rear diff breather relocation mod, 265/76/16 Duratracs, Emergency Lighting, Other Fun stuff
    So I finally took the time and installed my new r&p bushings from wheelers, and it handles like new. Gotta go get alignment in the morning I guess. I did find out the 1/2 socket extensions work awesome for getting old bushings and pins out, and for putting in the new bushings if you put the poly parts in by hand then use a thatching wood clamp it goes together really quick and effortless for the middle and driver side. I know there'd been a lot of talk recently about this topic so I figured I'd pass along what I found to make the project go quick simple and with out any problems!
  13. May 1, 2013 at 3:11 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    pampered the hell out of the Rad Baron today..
    did a THOROUGH inspection and cleaning of the entire front suspension. Determined that the leaky LBJs need to be addressed ASAP. MOOG? added some Lucas stop leak to the power steering resevoir in hopes that it will slow the leaking seals in the rack, and realized that there's more play in the rack than I had thought :( Probably replace that in a few months. Removed, sanded smooth, and greased the caliper pins. Washed and waxed her, as well as detailed the engine compartment. Shampoo'd the hell out of my Wet Okole's, good as new! and finally, color-matched my shackle..
    it was a good day :)
  14. May 1, 2013 at 4:29 PM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Drinking free booze, eating free food and working on server upgrades... oh wait, wrong forum. Bought a 5-pack of Summit D-Windows in 15x8 3.75BS - Slapping some sweet rubber on them early next week...
  15. May 1, 2013 at 4:37 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    :cool:
  16. May 1, 2013 at 4:40 PM
    FramerKat
    FramerKat Well-Known Member
    kAt
    Fort Lauderdale, Florida
    2004 PreRunner TRD Limited DC
    Wheeler's five pack leaf springs, Bilstein 5100s (rear), front tint, windshield top tint, Century Camper Shell/Cap/Topper, Wade window visors, Wade bug shield, cassette adaptor (so I can play Slacker Radio via my phone!), Sunday Blues with Dar sticker, Wounded Warrior Project sticker, no NRA sticker 'cause I don't wanna advertise ;-)
  17. May 1, 2013 at 5:25 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Alright sweet! Ya I was just wondering about the fenders because if I needed new ones I wasn't going to do it. I'm gonna get the hood, latch, grille, and headlights.
  18. May 1, 2013 at 6:41 PM
    PcBuilder14
    Brent
    Nor Cal
    Sprayed the pollen off my truck, aired up my tires for my 500 mile trip tomorrow, and detailed the interior and exterior of my truck.
    I swear, washing my truck is like therapy for me haha I just focus in on making the paint look as smooth as possible and i can shut out everything!
    Really don't know why I bothered washing it though, it's supposed to rain and get down into the 30's tonight... Haha
  19. May 1, 2013 at 7:15 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Pulled 1100 lbs on some sketchy ass harbor freight kit trailer 80 miles. Picked up a motorcycle and some laser cut skid plates.
    Got decent gas mileage on the whole trip considering I had a tail wind going down and head wind coming home.
  20. May 1, 2013 at 8:05 PM
    99tacoprerunner
    99tacoprerunner Well-Known Member
    oscar
    rohnert park ca
    99 prerunner
    I finally said f*** it and bought some new wheels and tires......what do you fellas think
    BEFORE
    image_zps1a8c0fc9_3418295cee3b6f43b5b3a8b4979e78de21a29d43.jpg[/URL]
    AFTER
