  1. May 20, 2013 at 4:34 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    EDIT: nevermind.
  2. May 20, 2013 at 4:40 PM
    BradyT88
    BradyT88 Well-Known Member
    A dual caliper setup that was more low-profile would allow 15's to clear without hurting braking power I imagine. Would be a pain to install though I bet. haha
  3. May 20, 2013 at 5:50 PM
    Bullfrog
    Bullfrog "I think I know more than I do."
    McLaren
    North Bend
    98 V6 4x Limited Ugly Canadian Green.
    Accessory Box with CB attached. Alpine Type S front and back. LineX. Bedline SKidplates. In progress: Bilstein 5100s with BFG mudterrains 33x10.5 A/C compressor to Onboard Air compressor mod.
    I built quick releases for my doors. If you've never driven with your doors off you really missing out it's a hell of a lot of fun and you don't waste gas on AC! It's pretty simple to do. Should I do a write up?du4egyhu_ba3ba5c3beb13c990d07647c57dec2bf840c1f11.jpg
  4. May 20, 2013 at 5:52 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Did you do quick release pins or just use the bolts?
  5. May 20, 2013 at 6:00 PM
    Madjik_Man
    Colorado Front Range
    That's pretty slick... but I'd have no tunes if I did that :(
  6. May 20, 2013 at 6:08 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    rear speakers and a sub! or leave the speakers in
  7. May 20, 2013 at 6:14 PM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Yeah, i've heard the same about Duratracs so i figured I'd be better off with KM2's - Then again, i'm really not bent out of shape about it, sh1t happens. That's why you buy the tire warranty :)
    I'd love a set of MTR's... i just don't want 33x12.5's...
    Caliper vs. Rim argument? Who cares. Grind only as much as you need to (and make sure your rim only needs a little bit of clearancing) and move on. I don't disagree that grinding the Rim is also a viable option. To each, his own. Also, i have no clue how this relates to 2nd Gen's so do your own research on that.
    There's a shoddy pic with a an arrow pointing to where the rim will leave the mark. Remove only as much as is needed to clear plus mayyyybe 1mm and you'll be fine.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/153662-grinding-brake-caliper.html#post3099541
  8. May 20, 2013 at 6:20 PM
    Madjik_Man
    Leave the speakers in what? :confused:
  9. May 20, 2013 at 6:22 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Mine had speakers in the rear!
  10. May 20, 2013 at 6:26 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    I've heard of jeep people relocating them to the kickpanel or under the dash. I don't see why you couldn't do the same with a little creativity.
  11. May 20, 2013 at 6:28 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  12. May 20, 2013 at 6:29 PM
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Ha that's exactly what I was talking about for the kickpanel. Would suck for someone that uses their deadpedal though..
  13. May 20, 2013 at 6:29 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  14. May 20, 2013 at 6:34 PM
    PcBuilder14
    Brent
    Nor Cal
  15. May 20, 2013 at 7:10 PM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Bought an arb 50qt fridge/freezer today. Will install it tomorrow when it gets here. Should make camping that much more comfortable.
  16. May 20, 2013 at 7:11 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Im jealous, I don't think I could fit one of those in my extended cab :(
  17. May 20, 2013 at 7:31 PM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Debating if im going to make a deck and pull out the back seat or mount it in the bed?...
  18. May 20, 2013 at 7:35 PM
    PcBuilder14
    Brent
    Nor Cal
    I would want to go with something like this...
  19. May 20, 2013 at 7:38 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    I have seen the pull out deck you are talking about and that's what I would do but that's just me, because I probably wouldn't move it to often once I have it in place and I help out on the family farm a lot during harvest and wouldn't want to risk ruining the fridge in the bed, but the situation is probably different for you though. :D It also kinda depends on how many people you drive around and if you always have your topper on all the time because I would think that it would get annoying having to crawl in the bed everytime for a beer or whatever you put in there. :D
  20. May 20, 2013 at 7:53 PM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Stackable?
