  1. Feb 12, 2015 at 10:16 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Party!! :kona::broccoli::dancingbacon::bananadance:
  2. Feb 13, 2015 at 6:36 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    does anyone else have issues with there dakar springs squeaking?? mine r so freaking annoying, only about 3-4 months old.
  3. Feb 13, 2015 at 7:16 AM
    SeekingZero
    SeekingZero Well-Known Member
    Ben
    Sierra Mountains, CA
    01 Xtracab 4x4 SR5 TRD Supercharged
    I definitely have a squeak or creaking during flex off road. Don't really know exactly where it coming from, but it seems like the leafs. You can hear it in the videos I took a couple months ago in my build thread.
  4. Feb 13, 2015 at 7:27 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    mine does it when i push on the quiick gas, go over like curbs, idk its really annoying
  5. Feb 13, 2015 at 7:37 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    My expos did that for a few months as well. It eventually went away, or I just can't hear it anymore haha
    Lithium grease is supposed to help, or you can do what this guy did and put some bicycle tubes in between the leafs...
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/98055-diy-squeaky-leaf-fix.html
  6. Feb 13, 2015 at 7:46 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    i put some moly grease in the zerk joint thingys between the leafs, didnt help. thanks for the link ill try that this weekend
  7. Feb 13, 2015 at 7:49 AM
    PcBuilder14
    Brent
    Nor Cal
    Could also be your bushings.
  8. Feb 13, 2015 at 7:52 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    make sure all your vertical side plastic pieces aren't worn through already. u bolts are tight? lift up the truck and hammer in a pry bar between the leaves with the anti squeal pads on the very ends. throw a little grease in there after you clean out the dirt. it makes a mess but wipe off any excess and I don't have any problems.
  9. Feb 13, 2015 at 8:00 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    i greased them aswell.. :(
  10. Feb 13, 2015 at 8:05 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    its weird cause the squeak is when i go over certain bumps, but i cant make the noise jumping around in the back and stuff, it also does it when i push the gas suddenly itll make a tini squeak ive check u joints and greased my drive shaft and it hasnt helped. so im assuming leafs are my problem.
  11. Feb 13, 2015 at 8:05 AM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Mine were squeaking like crazy. I sprayed lithium grease on both ends of the bushings and between the springs. Squeak gone for now, not sure how long it'll last but the squeak was annoying
  12. Feb 13, 2015 at 8:08 AM
    Mainmoe02
    Moe
    Austin, Texas
    Mine would squeak at "takeoff" as well. Try greasing the main eye bushing
  13. Feb 13, 2015 at 8:22 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    cause i greased the bushings through the Zerk joint, where r u referring to exactly?
  14. Feb 13, 2015 at 8:54 AM
    Deere9798
    Deere9798 Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    Anyone know the weight of a Non ADD front diff?????
    Thanks,
    Charlie
  15. Feb 13, 2015 at 9:01 AM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    Mine did this as well... turned out to be the springs contacting the exhaust... fixed it by dumping the exhaust right after the muffler
  16. Feb 13, 2015 at 9:03 AM
    WFD
    WFD Well-Known Member
    Springdale, Utah
    '96 3.4L 4x4 5 Speed Man
    OME Suspension 2" lift, Leer high-rise topper w/ sleeping platform.
    I have had my Dakars on for about 8 months. They squeaked a bit in the first 3 months then quieted down. I still have an intermittent squeak that occurs after an extended period of no precipitation. Yes, I know live in the desert. I drive a lot of dirt and gravel and the dust is very fine. As that fine dust works between the leaves over the course of 3-6 weeks, I start to get a creak when slow-rolling curbs and rock obstacles.
    To give you an idea of how far in the fine dirt can work its way in: I had the dakars with AAL for about 6 weeks when I decided I was too ass-high and decided to take out the AAL. When I pulled apart the leaf pack there was dirt/sand/dust/fine grit between the leaves all the way up to the ubolts. And yes, I was torqued to spec.
    My fix? Blast the shit out of the leaves with a pressure washer, get all up in there with a 20 degree spray tip. Enough to blast fine debris, but not enough pressure to take the paint of the leaves. 10 minutes of work takes the squeak out for months.
    I will also occasionally loosen the nut on the shackle spray some penetrating oil between the bushing and the shackle bolt and jump around in the bed. Maybe once a year. I do this if i start hearing a 'knock' from the rear when slow rolling obstacles. Also works wonders. (ARB doesn't make the greaseable shackles for the shorter pre-'97 leaf packs...I think Marlin Crawler does though??)
    Just my experience.
  17. Feb 13, 2015 at 9:06 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    haha come to think of it i havent sprayed my truck off from my last crawling trip... so much dust too... maybe thats the culprit!!!!!!!!!!!!!!:eek:
  18. Feb 13, 2015 at 9:17 AM
    WFD
    Springdale, Utah
    Definitely possible. Hope it works for ya!
  19. Feb 13, 2015 at 9:25 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    i hope so to, im about ready to rip them off, ive never had a single issue with my stock leafs haha. they are the dakars with the aal, i might try and run the expos from all pro but ive heard about squeaking with them aswell.. so who knows.
  20. Feb 13, 2015 at 9:29 AM
    PcBuilder14
    Brent
    Nor Cal
    I wouldn't go and get new leafs just because of squeaking. I can't thing of a single pack hasn't been called out for making noises from somebody.
