  1. Dec 30, 2015 at 6:41 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
  2. Dec 30, 2015 at 7:15 AM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    I just used some cheapies from the local auto parts store, because I mounted them on my receiver hitch and figure they'll get crushed sooner or later.
  3. Dec 30, 2015 at 8:05 AM
    Wadar
    Wade
    A few.
    That's a sweet switch setup! I've pulled the trigger on a bumper purchase, and will be adding some lighting at the same time. Where did you find this switch panel? Any info on this mod would be greatly appreciated!
  4. Dec 30, 2015 at 8:15 AM
    Suggs12
    Suggs12 Well-Known Member
    Logan
    Johnson City, Tennessee
    2004 PreRunner
    3" Lift kit, Bilstein 5100 front and rear, 2881 EMU coils, 2" Deavers AAL, 18x9 KMC rockstar 1 wheels and 33" Nitto Terra Grapplers, Debadged, Grillcraft insert, clear corner and turn lights, 6k Leds, 30" Led light bar, 4 Pod fog lights.
    Got the Pods hooked up and mounted for fogs. Super bright!
  5. Dec 30, 2015 at 8:20 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    dammit....^^^
  6. Dec 30, 2015 at 8:23 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    That's looks sick
  7. Dec 30, 2015 at 9:08 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wait, I am confused. The 8" diff and the 8.4" diff are not the same.
    Your info says your truck is a factory TRD. If that is accurate and that is the axle housing you are asking about, then you have the 8" diff and your axle housing is an ABS housing. Even if your truck does not have ABS.
  8. Dec 30, 2015 at 11:35 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    He has the 4 banger TRD package with no locker (from another post). He has a "no slip" or "lock right" or something like it. Have to assume he has an 8.4 non ABS rear. The previous pic in Mr BDN's link should make the 2 types apparent to him.
    Matic likes this.
  9. Dec 30, 2015 at 11:40 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    bogs froze solid. You can drive to ponds and ice fish outa the truck.
    Also found out that while holding the brake the abs system does a pretty good job of keeping both front tires spinning on ice.
  10. Dec 30, 2015 at 12:03 PM
    Redrainey
    Redrainey Member
    2003 White Tacoma TRD
    Hey, didn't do any mod's to the truck today, but had a interesting offer presented to me. met a guy that wants to get his truck back to stock and trade me a set of near new 33's on decent aluminum rims for my stock rims and tires. easy decision I know. heres my issue I only have a two inch lift on the truck and I'm concerned about getting into needing spacers to prevent the rub, any advice on how they would fit and if they will fit would be greatly appreciated
  11. Dec 30, 2015 at 12:28 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    A picture would help and specs that you know of the wheels
  12. Dec 30, 2015 at 12:47 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    10k and I'll deliver the truck to somebody within a state from NC
  13. Dec 30, 2015 at 1:00 PM
    GreeGunc
    Jacob
    North GA
    You're selling it?
  14. Dec 30, 2015 at 1:04 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    That's interesting. I thought that TRD was considered Locked rear if your a 4x4 or prerunner. Maybe someone could educate me on this. But the with the 8.4 and non abs housing is what I have on my 02 prerunner ,non trd, 2.7 auto.
  15. Dec 30, 2015 at 1:06 PM
    bellassaiw10
    Currituck NC
    Yeah, going to a diesel finally.
  16. Dec 30, 2015 at 1:07 PM
    GreeGunc
    Jacob
    North GA
    All I know is 8" is TRD, 8.4" is non TRD, and the 4 banger didnt get a locker
  17. Dec 30, 2015 at 1:07 PM
    GreeGunc
    Jacob
    North GA
    :eek::annoyed:Duramax?
    bellassaiw10[QUOTED] likes this.
  18. Dec 30, 2015 at 1:17 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Still chugging along
    SWYPER, j0shu4, RustyVT and 7 others like this.
  19. Dec 30, 2015 at 1:20 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Some 4 bangers had it but most dont.
  20. Dec 30, 2015 at 1:21 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ride height really won't help rubbing as much as wheel backspacing. Chances are if he's a first gen running them without spacers as well, you won't need spacers. You might however need to smash/cut the pinch weld a little.
