  1. Apr 29, 2016 at 7:41 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    I want to but it seems like a bitch... Is it worth it? Does it help your alignment?
  2. Apr 29, 2016 at 7:48 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    It's a big job for sure. Main purpose is just replacing worn rubber bushings. Poly bushings have their pros and cons versus rubber.
    Don't see how it would improve alignment unless it's going alongside replacing frozen cam bolts, or you have really bad bushings.
  3. Apr 29, 2016 at 7:49 PM
    hyre82
    hyre82 Member
    Mark
    Pittsburgh,PA
    2004 Tacoma TRD Double Cab
    Bilstein 5100's up front set to 1.25" lift, Bilstein 5125's on the rear,
    New bumper knocked out.
    Burnett, Soflanick and JKU3000 like this.
  4. Apr 29, 2016 at 7:51 PM
    TacoVio
    Kolton
    CO/WY
    I see...well the ones on the truck now don't squeak yet...but I haven't broken its trail virginity yet. My 04 squeaked like a son of a bitch but thanks for the info did you use the jack to push them out if remember right?
  5. Apr 29, 2016 at 7:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Anyone one wanna donate to my truck money?!?
  6. Apr 29, 2016 at 7:58 PM
    Squeaky Penguin
    Brett
    Bottle jack method kind of worked for me. Not what I would use if I did it again. Read up here if you want to attempt it:
    https://www.tacomaworld.com/threads/lca-bushings-oem-energy-suspension-whiteline.394935/
  7. Apr 29, 2016 at 8:13 PM
    TacoVio
    Kolton
    CO/WY
  8. Apr 29, 2016 at 8:54 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Worked late tonight to try to get the truck kinda back to normal before frame replacement for a wheeling trip. Painted the sides of the bed that will be exposed when I cut the drop in liner, relocated the tailgate cables, tinted the ambers red, and painted the tailgate I've been doing body work on but unfortunately ran out of fuckin paint.
    The cable relocation was done because of the tailgate hitting the bumper when weight was put on the tailgate. Fuck doing all that body work for it to get ruined again by something so stupid.
  9. Apr 29, 2016 at 10:04 PM
    BHill_teq
    BHill_teq Cruisin Hills
    Brayden
    SLC, Utah
    FJ62 Land Cruiser / 21 Tacoma TRDOR Army Green
    2010a6528e64ada75b607e0b2a7ac774_7ef16e12f0d2f0620b897b033128bc06e2a7ca4b.jpg I washed it today, so I felt like I better take a cool picture of it before the stupid weather here in Utah decides to rain again.
  10. Apr 30, 2016 at 12:24 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Mocked up the fogs...
    ...and the backup lights.
    Burnett, gray223, BroTaco and 5 others like this.
  11. Apr 30, 2016 at 12:34 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Smacked the passenger corner of my front bumper into the side of a ditch.. Now the tire rubs when I turn at a specific angle left, time for a tube bumper?
    Until then, anyone got ideas on how to bend it back, its pushed down and in, I think at the mounts..
  12. Apr 30, 2016 at 10:09 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Im trying something new. (these are a spare set)
  13. Apr 30, 2016 at 10:37 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    What are the mounts under the BAMF bracket? The other yellow parts
  14. Apr 30, 2016 at 10:49 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Those are the BAMF drops for an LED.
  15. Apr 30, 2016 at 11:12 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Thought they were only for the 05s and up :facepalm:
  16. Apr 30, 2016 at 11:17 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Cut bed liner up for more space, made a better platform for high lift (thanks @JLink for that idea), and re mounted all my shit in the bed for a wheeling trip. Co2 is only ratchet strapped in right now lol.
    Fernando, Burnett, thumper72 and 6 others like this.
  17. Apr 30, 2016 at 11:37 AM
    devinzz1
    devin
    2023 aclb trd or mt
  18. Apr 30, 2016 at 11:40 AM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    I might do that with my bedliner. My sleeping platform is cattywhompus because of the curvature in the corners due to the bed liner.
  19. Apr 30, 2016 at 11:52 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    It's basically a glorified bed mat now. Will def replace with real bed mat.
    WildLand likes this.
  20. Apr 30, 2016 at 11:56 AM
    AdeptFox
    AdeptFox Active Member
    Jake
    Vermont
    2015 Access Cab 4x4
    What'd you use for the tail lights? Red VHT Nite Shades?
