  1. Jun 5, 2016 at 8:58 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    thumper72 likes this.
  2. Jun 5, 2016 at 8:58 PM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Sooooo close. Most the major stuff is done. Still have some things to button up. Filling up with nitrogen, touch up paint, wire in tail lights. OMG I love this thing! Can't wait to go 4x4 some mountains.
    [​IMG][​IMG]
  3. Jun 5, 2016 at 9:06 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Do you plan on needing one? I only ask because I found that the tranny cooler I installed in my wife's suv was great for the summer and towing keeping below 200 degrees, but it also kept the transmission under 100 degrees in the winter on anything but long freeway trips. I feared condensation would not cook out of the fluid for weeks at a time and weaken the water based adhesives in the clutch material (gm 4l60e). I oppted to remove the cooler and just do a drain/fill from the pan each fall.
  4. Jun 5, 2016 at 9:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I did not bypass the radiator for precisely this reason.
    Without the radiator to maintain some temp in the fluid, the fluid might be too cold in colder climes with harsher winters.
  5. Jun 5, 2016 at 9:21 PM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    That's the only thing I'm worried about is winter time but plan on pulling @3800lbs total as many times as I can during the spring to fall time area.wonder if there's a way to make a bypass for winter but turn it on Durning the summer time? Great point though..
  6. Jun 5, 2016 at 9:27 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Where in God's name did you get that hood, I need it!!
  7. Jun 5, 2016 at 9:28 PM
    retroboy1989
    99 2.7L 5spd 4x4
    Right, the kit that I bought was designed to go in-line after the radiator. I figured with how little my trans temps ever get really high w/o the cooler, and how long and bitter UT winters can be, an annual refresh (approx 1/3) on the fluid fit my needs better.
    But, that is a Chevy running Dex vi, this is a Toyota forum. The only point I was trying to make is that if transmission temps never go above normal operating ranges anyway in a cold climate, money may be better spent keeping fresh fluid in the pan.
  8. Jun 5, 2016 at 9:33 PM
    retroboy1989
    99 2.7L 5spd 4x4
    3800 lbs in over 80 degrees will definitely put some heat in your tranny. I did look at bypasses at one point. This unit looks promising: http://www.amazon.com/Hayden-Automotive-163-Thermostat-Bypass/dp/B000HE8HAY . You could build a very Utah friendly setup with that deal.
    thumper72[QUOTED] likes this.
  9. Jun 5, 2016 at 9:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was only referring to my personal experience with my truck.
    When I added a lift and larger tires, I put more and more load on the trans. First went to 32s and then 33s. I found the trans hunting for gears more and more. Each time the trans goes in and out of torque converter lockup, it generates more and more heat in the fluid. I can monitor this on my scangauge. All this is without towing.
  10. Jun 5, 2016 at 9:43 PM
    retroboy1989
    99 2.7L 5spd 4x4
    Different needs. Family vehicle on stock tires vs off road rig on 33s. Makes sense why we have different stories.
    Now, my Tacoma is a 5spd so this is a moot for my Toyota needs.
  11. Jun 5, 2016 at 10:36 PM
    reef
    reef Well-Known Member
    04 4WD
    Took her camping. 5th weekend in a row.
  12. Jun 6, 2016 at 12:17 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks bud
  13. Jun 6, 2016 at 12:25 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Set the power and ground distribution blocks.
    Also mounted the spots. Still need to trim the drop brackets a bit more so they will push back another inch or so.
    TuckGraham, JKU3000, fiziks and 3 others like this.
  14. Jun 6, 2016 at 5:22 AM
    j0shu4
    Its the OE hood. I wrapped it in vinyl and cut out vents. Vents were from Amazon or eBay maybe $20 for all. The larger ones are marine vents. I like it, gives a good look plus allows a lot more air flow and heat release from the engine bay.
  15. Jun 6, 2016 at 5:32 AM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    How do you like the kayaks mounted like that? And what roof rack do you have them mounted on. Thinjing of doing those same mounts. Any effect on driving?
  16. Jun 6, 2016 at 6:17 AM
    reef
    04 4WD
    I love it so far. It's the thule roof rack setup. No problems with driving.
    malburg114[QUOTED] likes this.
  17. Jun 6, 2016 at 7:36 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Wish I had my better camera, being #funemployed gives me lots of free time
    j0shu4, jubei, FirstGen Jer and 2 others like this.
  18. Jun 6, 2016 at 8:02 AM
    thumper72
    Jon
    Ogden Utah
    http://www.amazon.com/Adjustable-Ve...w_p_img_2?ie=UTF8&refRID=1JH44RWH1DDN2XHGWBVW
    sorry it took so long but for some reason i couldnt post from my phone for you as it kept wanting to open the Amazon app....
  19. Jun 6, 2016 at 8:14 AM
    RedManRocket
    Red
    2002 Double Cab LT
    That's some good handywork, you should do a hood scoop and a top mount intercooler, that would be sweet!
  20. Jun 6, 2016 at 8:18 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Constructive criticisim time. Air flow for what? Stock air intake is in the pass fender, so unless you moved it like with a CAI or ram air intake you aren't getting any "extra" air.
    And I've noticed in winter the snow melts fastest right in the center of the hood so that is where most of the heat is, not on the sides.
