  1. Jul 2, 2016 at 11:01 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Bobbed the bed last weekend
    bayareataco, JKU3000, TacoVio and 3 others like this.
  2. Jul 2, 2016 at 11:26 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Black taco lives! Started it for the first time in like a month. And it looks more like a truck again!
  3. Jul 2, 2016 at 11:29 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    So when do the new fenders go on?
  4. Jul 2, 2016 at 11:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The high temps are from over working the torque converter. It generates a tremendous amount of heat with no way to dissipate it.
    There are two aspects to this, so there are two things you must change.
    One is to reduce the load on the torque converter. 4hi in drive = high heat generation. One option is to hold it in a lower gear. Better yet, shift to 4lo. You do that and the temps will start to come down immediately.
    The other aspect is to help with cooling the trans fluid by adding an external cooler. There are a ton a good threads on this topic. Don't be lazy, read some of them. Start with this thread:
    https://www.tacomaworld.com/threads/hayden-transmission-oil-cooler-install.108470/
  5. Jul 2, 2016 at 11:30 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Welded some spindle gussets!
  6. Jul 2, 2016 at 11:48 PM
    Ice Horse
    Lauren
    Florida
    Sooooooon...
    I have to go map a trail tomorrow but hopefully it shouldn't take too long. But then we'll begin that process. I've got a few small things to button up on it then we can start actually mounting them.
  7. Jul 3, 2016 at 1:57 AM
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    Can anyone in the bay area recommend a good toyota mechanic?
    Located in the east bay but willing to travel a bit for good service!
    I need to change for a few reasons!
  8. Jul 3, 2016 at 8:01 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    It's kind of disappointing, I was literally only 20 minutes into the trail.
  9. Jul 3, 2016 at 8:29 AM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    It doesnt take long in 100 degree weather to hit 200+ in a tranny. I did that with my wife's trailblazer last week on the highway.
    I am still curious at what point that light comes on. 300 degrees seems a little late.
  10. Jul 3, 2016 at 8:55 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Please tell me you stitched welded that and not one long bead..
    malburg114 likes this.
  11. Jul 3, 2016 at 8:59 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I welded about half of that length then let it cool for awhile then the other half.
  12. Jul 3, 2016 at 9:01 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Anyone here done a fuel pump kill switch?
  13. Jul 3, 2016 at 9:08 AM
    Bobert14
    Bobert14 .
    Finally got the rebuild kit for my other coilover.
  14. Jul 3, 2016 at 9:23 AM
    retroboy1989
    99 2.7L 5spd 4x4
    To prevent theft? I just read a writeup for a 90s honda/acura. Looks straight forward..
  15. Jul 3, 2016 at 9:41 AM
    JKO1998
    Utah
    If my fluid was burnt would it a brownish color? Sorry for all the questions about it.
  16. Jul 3, 2016 at 10:02 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Possibly, it will smell burnt, smell some good trans fluid and then smell yours, the difference will be noticeable.
  17. Jul 3, 2016 at 10:05 AM
    JKO1998
    Utah
    I'll give that a try when I get home.
    What should I replace it with?
  18. Jul 3, 2016 at 10:17 AM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    IIRC it should be Dexron II atf or any other ATF that's compatible with Dex II
  19. Jul 3, 2016 at 10:18 AM
    retroboy1989
    99 2.7L 5spd 4x4
    From the 99 manual:
  20. Jul 3, 2016 at 10:20 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Just go to the dealer and say you need trans fluid for your 99 v6 automatic tacoma.
    thumper72 likes this.
