  1. Nov 10, 2017 at 8:59 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    10mph difference is huge. Something doesn't add up there.
  2. Nov 10, 2017 at 9:03 AM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    ...that's some fine looking lab pups! How much are they eating :transformer:
  3. Nov 10, 2017 at 9:06 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Whatever mum dog lets them. I don’t really know how we’d measure that....
    I guess flow rate x amount of time fed... but there’s still some variables that’ll throw that off.
    A Mo Cat and Bulldogs129[QUOTED] like this.
  4. Nov 10, 2017 at 9:08 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    265/75r16s are ~32s and will make your speedometer read low.
    Combine that with the fact that the speedo from the factory always reads a bit low. (edit for clarity: your actual speed will be lower than what the speedo is displaying) Mine was about 5 mph off from the factory.
    It would be interesting to know more accurately what your actual speeds are compared to what the speedometer is showing. I use an Android app call Maverick because it will give a your speed in real time using GPS.
  5. Nov 10, 2017 at 9:11 AM
    taco57
    taco57 Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    I could be wrong but I think that is just for the little rubber tube that goes up to a breather vent only, since this actuator is electrically operated not vacuum. It looks just like the one I replaced on my truck.
    If interested PM me, my old one is in a box in my shop, you could just swap the top cover from mine to yours and that would take care of your dilemma.
  6. Nov 10, 2017 at 9:11 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    My speedo was high from the factory - ~5-6mph @65mph. (It would read 65 when I'm doing 60 via GPS). Interestingly, putting on the 255/85 R16's (33's) has brought the speedo perfectly in-line with GPS, no new speedo gear needed!
  7. Nov 10, 2017 at 9:12 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Considering that though 32s should make his speedo almost dead on. My 33s make it just a touch high.
    m3bassman likes this.
  8. Nov 10, 2017 at 9:12 AM
    taco57
    Jeff
    Columbus Ohio
    You guys with your pretty non rusted salt exposed frames kill me. Lucky dog!
  9. Nov 10, 2017 at 9:13 AM
    Bulldogs129
    Malcolm
    Mississippi
    I have stock 265 70 16s, no rubbing.
    And your speedo...7-10 mph off o_O
    Here's a speedo chart to consider...:notsure:
  10. Nov 10, 2017 at 9:15 AM
    taco57
    Jeff
    Columbus Ohio
    Now that's a used bed!
  11. Nov 10, 2017 at 9:37 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Haha, english is hard! Especially so because our perspective interferes with clearly expressing something. o_O
    What your truck (from the factory) did is exactly what I was trying to describe. :rolleyes:
    I added this edit to my post: (edit for clarity: your actual speed will be lower than what the speedo is displaying) Mine was about 5 mph off from the factory.
  12. Nov 10, 2017 at 9:40 AM
    CHMM
    CHMM GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Thanks, I think it's the 4.1 gear ratio and I'll have the tire shop confirm it with they lift it. If so, we're going with 265 70 16s and callin it. That should run pretty stock for now.
  13. Nov 10, 2017 at 9:40 AM
    CHMM
    CHMM GTO
    Gabe
    aND NICE TRUCK Btw
    Digiratus likes this.
  14. Nov 10, 2017 at 11:48 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  15. Nov 10, 2017 at 11:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well..lots of factors.
    Are your 33s really 33s? Are mine? Probably not haha
    Silver02Taco and ChadsPride like this.
  16. Nov 10, 2017 at 12:01 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Depends on PSI and what width rim you are using too. Skinnier rim pushes the tire taller and wider rim makes it shorter
  17. Nov 10, 2017 at 12:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well yeah but then you get the differences from manufatures. And like JD said wheel size and tire pressure.
    Im on 255/80s but a 8.5'' wheel30-40psi depending on weather/road conditions.
    The end of it. No ones truck is ever the same. Unless its bone stock and untouch and even then it would have to be made around the same time because toyota switched shit all the time haha
    Silver02Taco likes this.
  18. Nov 10, 2017 at 2:04 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    started truck after sitting 2.5 months. ABS light stays on now.
  19. Nov 10, 2017 at 2:08 PM
    Siktaco
    Siktaco Well-Known Member
    Robert
    Yuma
    1996 Toyota Tacoma long travel
    Total chaos long travel kit 8" king coilovers Short course 3 link with 16” king coilovers 32 gallon rci fuel cell Msd fuel pump Mini d2s 4.0 retros 5 hella 4000s hid McNeil fenders Fiberwerx bedsides
    They are all metal lights, that’s why I like em haha. I love the hellas 4000s. And I haven’t heard of the bowls getting ruined in those lights, but it is possible I would imagine
  20. Nov 10, 2017 at 2:12 PM
    Siktaco
    Robert
    Yuma
    So I got a slime air compressor, went to air up my tires one day and after about 10-15 minutes my cigarette lighter lost all power. Fuse is fine, pulled the radio out and checked the connections and they seem fine. Bad cigarette lighter? or any other ideas?
