  1. Aug 28, 2018 at 4:42 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Pulled from reddit.com/r/shittycarmods
    It's made its rounds on the internet.
  2. Aug 28, 2018 at 4:55 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I don’t hate em, but I don’t love them.
    Thanks sir
    Sperrunner[QUOTED] likes this.
  3. Aug 28, 2018 at 6:00 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Bought a Tacoma today!! Looks like I signed up to do a frame swap or more like I was forced into it :annoyed: 01prerunner 180xxx on it ,probably be parting it out soon.
    4708059A-B9CB-4FC6-941C-E33FF3930FC9.jpg 7115FD00-1DF6-4379-AE42-3AAC4BC9CF77.jpg
    Dcpsychobilly and SwampYota like this.
  4. Aug 28, 2018 at 6:02 PM
    JKO1998
    Utah
    So huh, are front and back spot handles the same? If so, dibs on back drivers side ext. handle.
  5. Aug 28, 2018 at 6:16 PM
    vonellis
    Some and some more
    Yes don’t let me forget when i start selling
  6. Aug 28, 2018 at 6:17 PM
    JKO1998
    Utah
    Are they the same? I guess I can go look huh
  7. Aug 28, 2018 at 6:19 PM
    vonellis
    Some and some more
    They are the same
  8. Aug 28, 2018 at 6:21 PM
    JKO1998
    Utah
    Sweet
    (I’ll be watching you and your post :homer:)
  9. Aug 28, 2018 at 6:29 PM
    vonellis
    Some and some more
    Nice! I feel funny :jerkoff: I’ll make a soon to part out tread in the parts section now
  10. Aug 28, 2018 at 6:59 PM
    vonellis
    Some and some more
  11. Aug 28, 2018 at 7:27 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Mine was making my cheap HIDs not work properly. And it bugged me
    zero4 and JKO1998[QUOTED] like this.
  12. Aug 28, 2018 at 7:33 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Pretty sure DRLs have been proven to increase safety.
    Not too many detriments either besides going through a few more bulbs. I don't really understand disabling them. :notsure:
    m3bassman likes this.
  13. Aug 28, 2018 at 7:35 PM
    JKO1998
    Utah
    Why does it seem like literally no other vehicle has them allll the time.
  14. Aug 28, 2018 at 7:36 PM
    Squeaky Penguin
    Brett
    A lot of vehicle do, they just use a seperate bulb. Our Tacomas just use the low beam bulb at like 50% power.
  15. Aug 28, 2018 at 8:11 PM
    JKO1998
    Utah
    Maybe I just need to make a raptor grille with raptor lights
  16. Aug 28, 2018 at 9:29 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I did much the same to my son's 97 XJ when he started driving two years ago. I wired them to run any time the ignition is on (there is a switch as well, but even when it's turned on, they're still only going to come on with ignition).
    I am running $25 cheap Nitecore LEDs from Amazon, for his safety (the truck is *quite* noticeable on the street with them running, day or night), and as an experiment. It's been through many rainstorms, a couple deep puddles, and lots of driving since, without incident. I have since put them on my S10 and will soon be adding a pair to my wife's 94 ZJ and my recent acquisition, the 97 Tacoma. DRLs are a good thing to have (but no, I don't think running the low beams at half power is the greatest application of the idea).
  17. Aug 28, 2018 at 9:32 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Concur. This is where the aftermarket comes in.. IIRC, DEI 545T (the Nite-Lite system, about $30) takes care of this nicely.
    Similiarly, I never understood why the lighting circuit isn't a switched-ignition load. When have you ever left the lights on a car that wasn't running, and had it be a good thing?
    m3bassman[QUOTED] likes this.
  18. Aug 28, 2018 at 9:39 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Concur. I became a big fan of being noticed on the road (not seen, noticed. HUGE difference) when I took MSF (Motorcycle Safety Foundation) classes. One of the things they keep hammering home is, be seen. Be aware that you may be lost in glare or just dulled senses from other drivers being overloaded by info after a long day. So do things like run DRLs, driving lights on the forks work great- or sway in your lane a bit when approaching intersections. I applied this to my son's XJ as an experiment and it's worked quite well.
  19. Aug 28, 2018 at 9:41 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    On his truck, it's an independent circuit, seperate from the other lighting. When I get around to installing a 545T in his truck, I will likely run the "headlight" output from that system to the LEDs instead. They work FAR better than the craptastic factory headlights, and are more noticeable.
    At the same time, I will install a relay so the factory lighting is disabled with key off. Obviously, flashers will be unaffected, as they should be available independent of the key.
  20. Aug 28, 2018 at 9:48 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Re-read what I said.
    They aren't wired into the headlights, in any fashion.
    When I put the 545T in, I will likely run the headlight output from that controller, to the LEDs. This way they are ignition-switched, and serve all the "light flash" functionality one has in a normal alarm installation- but being LED they are brighter and draw far less than the stock headlights.
    Unrelated to that, I will rewire the factory light switch feed through a relay, such that the IGN must be on for the factory lights to work (except for the flashers, which I will leave alone and functioning as normal, independent of IGN).
