  1. Oct 18, 2018 at 9:03 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    when you do. Just go ahead and add the tranny cooler as well. Will help.
    cruiserguy, burntkat and drr like this.
  2. Oct 18, 2018 at 9:06 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Good call, definitely a worthwhile upgrade.
  3. Oct 18, 2018 at 9:18 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    That's the normal light diffusion for HID's, however it doesn't look like he adjusted them right. I believe the light beam should be level with each other. There's a very specific way you're supposed to adjust them.
    I broke the adjusting mechanisms on my retrofits because HID's don't light the high beam indicator anymore unless you run an error correcting module - I kept adjusting and adjusting the headlight position because I couldn't find the light pattern.
    I did it so much the cheap plastic adjusting screws broke, and then I found out the damn high beams were on the whole time.
  4. Oct 18, 2018 at 9:18 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Pro Tip: Magic Erasers are just Melamine Foam, buy the aforementioned in generic form for 1/4th of the price.
    cruiserguy and burntkat[QUOTED] like this.
  5. Oct 18, 2018 at 9:20 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I was pretty upset when I programmed my Scangauge to report transmission temperature, and it told me it was -39.9 Degrees Fahrenheit. Apparenly, 1995-2000 Tacomas do not report transmission temperature.
  6. Oct 18, 2018 at 9:26 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    It needs some hoops on the bumper.
  7. Oct 18, 2018 at 9:28 AM
    kystnTRD
    kystnTRD Ramblin Man
    NW Pennsylvania
    2016 TRD Sport 6MT
    That 4runner is gorgeous
  8. Oct 18, 2018 at 9:32 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Interesting I didn't know that. I do know that they used that material in Japan for cleaning long before it hit the US. My buddy gave me some years before it came out here. When I'm with him we always laugh about it when we see the stuff in stores.
  9. Oct 18, 2018 at 9:34 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yep that's the reason why I painted mine with SEM trim black. The mirrors don't fade fast. Will last years until I have to use the eraser on them again.
    BYJOSHCOOK[QUOTED] likes this.
  10. Oct 18, 2018 at 9:36 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Man, I love my 15 taco, buy clean 3rd gen 4runners make me consider picking one up as an in-town runner.
  11. Oct 18, 2018 at 9:38 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Is there a write up for this?
  12. Oct 18, 2018 at 9:40 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
  13. Oct 18, 2018 at 9:41 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Yeah, I have HIDs that's why I was wondering why it wasn't a flat beam across both lights.
    40011766_10214683079369105_4654110038929_9653a89cb7d64877787034134b3c8dcd340b0b9d.jpg
  14. Oct 18, 2018 at 9:46 AM
    eon_blue
    Azusa, CA
    and some sliders :devil:
  15. Oct 18, 2018 at 9:53 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Looking at doing a drain and fill and adding a cooler at the same time. Most likely this cooler https://www.amazon.com/Long-Tru-Coo...&qid=1539881506&sr=8-1&keywords=tru+cool+4454.
    Any idea on how much fluid I need? 3.4l V6 automatic. I believe that is the A340F. I was thinking around 5qt. But would like to make sure.
    burntkat likes this.
  16. Oct 18, 2018 at 9:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Several on here. I have photos but haven't gotten around to posting it.
    Thats what I used.
    I don't remember. I did a flush last time so i used 5 gal of fluid :oops:
    chowwwww[QUOTED] likes this.
  17. Oct 18, 2018 at 9:56 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I ended up using almost 12 Quarts, or about 3 Gallons to fill my drained A340F after I did my 4x4 conversion.
  18. Oct 18, 2018 at 10:06 AM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Is there a part # for the little plastic molding around these dials?
    Otherwise the knobs don't stay on :(
  19. Oct 18, 2018 at 10:06 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Those are part of the knobs themselves, unfortunately. You'd have to buy all new knobs.
    You can try wrapping them in electrical tape.
    TacoYankee likes this.
  20. Oct 18, 2018 at 10:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Actually there is a small metal sleeve deal that is inside the knobs. If that falls out you're screwed. Happend to one of mine.
    cruiserguy and zero4 like this.
