  1. Nov 5, 2018 at 7:41 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    Current development with my truck: started it up tonight, started running/idling extremely rough. Attempted to drive it a short distance and it has no power and is vibrating excessively. Check engine light came on, but I don't have a scanner to read to code(s) currently. I'm thinking it's possibly misfiring, maybe a bad coil or injector. Any thoughts? BTW, its a 3.4 auto
  2. Nov 5, 2018 at 8:05 PM
    1997tacomav6
    Denver
    Well I’m under my truck and see this.
    Is this a leaking brake cylinder or a rear axle seal issue?
    Oil is only on the outside section as shown
    Guess I will take the drum apart tomorrow
  3. Nov 5, 2018 at 8:06 PM
    1loganwright
    1loganwright Logan no.2
    Logan
    San Antonio, TX
    '02 Lunar Mist PreRunner SR5
    AutoZone will read and diagnose the codes for you free of charge. They will even give you a print-out of them if you so desire.
    2002Tacoma4x4 likes this.
  4. Nov 5, 2018 at 8:11 PM
    aknickyota22
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Yeah I have a friend that has a code scanner, will borrow it tomorrow and see what codes it's throwing. Just wondering if anyone had any ideas on what it could be.
  5. Nov 5, 2018 at 8:16 PM
    tmswell
    tmswell Well-Known Member
    Bay Area, California
    2002 Tacoma TRD-OR DC 4x4
    Awesome Picture!
    yote[QUOTED] likes this.
  6. Nov 5, 2018 at 8:18 PM
    1loganwright
    Logan
    San Antonio, TX
    How long has it been performing like this? Have you noticed any slight issues like this before tonight?
  7. Nov 5, 2018 at 8:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Blown axle seal.
    Do them both while you're at it.
  8. Nov 5, 2018 at 8:36 PM
    aknickyota22
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Just started acting up tonight. Its been running great, no previous issues.
  9. Nov 5, 2018 at 8:47 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Has anyone fixed loose auto shifter? I have a 1996 4Runner shifter, and it has quite a lot of play. Sometimes it pops out of gear if you lightly knock into it with your arm. It's also difficult to tell if you're in Neutral or Drive at time since the shifter is so loose.
    FLBAdrian and Brice like this.
  10. Nov 5, 2018 at 8:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Axle seal would be my guess too. If it is gear oil, the smell will be distinctive. When the seal goes, it usually smart to replave the bearing as well. Also, the brakes will have taken on gear oil and are ruined.
    As Monte mentioned, if one side has gone, the other side is not far behind.
    1997tacomav6[QUOTED] likes this.
  11. Nov 5, 2018 at 8:50 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    replace the bushings...
    outlawtacoma likes this.
  12. Nov 5, 2018 at 8:53 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    In the shifter? Didn't realize it was serviceable.
    I'm having a hard time picturing this.
  13. Nov 5, 2018 at 8:55 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Gear oil has a pretty distinct smell. How's you brake fluid level look?
  14. Nov 5, 2018 at 8:56 PM
    aknickyota22
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
  15. Nov 5, 2018 at 9:03 PM
    Knifemaker84
    Knifemaker84 Member
    Scotty
    2001 Taco
    NONE
    Did my trans fluid....including dropping the pan and new "strainer". $128.00 all in. Did the job myself.
    BYJOSHCOOK, Jiveydude and Crodell6 like this.
  16. Nov 5, 2018 at 9:06 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Mine had a similar problem recently, it started suddenly too. Luckily I was about a mile from the house so I limped/coasted home. Your description sounds very similar to what mine was doing.
    ScanGauge said it was a P0304 code or a misfire on cylinder 4. That was on the non-coil side (driver). If yours is the same side you can determine if it’s the coil feeding it by starting the truck, pulling the spark plug wire on the misfiring cylinder and holding it next to the engine block. If it sparks then it’s not the coil. When I did it I had spark but it was coming out of the side of the boot. Bad boot.
    I replaced plugs and wires. CEL went off, runs like a champ.
    Here is a good DIY thread, not that it’s complicated or anything but he does give you the diagram for which wire goes to which coil and cylinder which can be useful if you cross it up.
    https://www.tacomaworld.com/threads/how-to-replacing-spark-plugs-and-wires-on-5vz-fe-3-4-v6.261034/
    zero4, 2002Tacoma4x4 and Fuergrissa like this.
  17. Nov 5, 2018 at 9:10 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  18. Nov 5, 2018 at 9:13 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Well hell ya! Scored this on an Amazon Warehouse deal (open box) for 46 bucks. Just happened to look tonight... I don't normally get that lucky.
    That's one more part for the 4x conversion. :thumbsup:
  19. Nov 5, 2018 at 9:17 PM
    Thaitoy
    Thaitoy 2003 3.0 turbo diesel. 6in lift w 33's
    2003 taco 3.0 turbo diesel
    6 inch lift. 33in tires 10000lb winch and shocks
    More progress on the stripes.
    4 hours to do the wrap on the grill and the hood.
    Repainted the front bumper installing it today then finish wrapping it.
  20. Nov 5, 2018 at 9:17 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    @BartMaster1234
    I actually make some bushings for the auto shifter. Lemme know if interested. I have em in my turbo truck and in my friends 4runner
