  1. Jan 7, 2020 at 9:50 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    How long do the spherical heims in coilovers typically last?
    Trying to track down a noise in my front end when the driver side loads up on a hard right hand turn.
  2. Jan 7, 2020 at 9:51 AM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    ADS recommended servicing(replacing) them every 60k miles approx. I’ll be sending my COs in soon.
    Check your upper control arm bolt/nut. I had a similar noise not too long ago and that’s what it turned out to be.
  3. Jan 7, 2020 at 10:04 AM
    betterbuckleup
    Ian
    Concord, CA
    Thanks!
    Good suggestion. I'll double check that.
    If that's not it i'll pull my CO's and cycle the suspension to try and narrow it down.
  4. Jan 7, 2020 at 10:07 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Maybe for full rebuilds (and even then that's way too long of a service interval IMO) but definitely not for the lower spherical bearings. Mine make it one wheeling season, sometime less than 10k miles.
  5. Jan 7, 2020 at 10:14 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    I agree. Replace that stupid coil spring with a linear spring. A hardware store spring works, a brake pedal return spring also works. As does a clutch pedal return spring for a 4-cylinder first gen Tacoma.
    Did you get new plastic bushings? If not, things will start to wear quickly. If you did get new bushings all will be good until the new plastic bushings wear out.
    GQ7227 likes this.
  6. Jan 7, 2020 at 10:28 AM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I got about 20k miles out of my lower bearings, they were pretty shot and had a bunch of play. I can’t imagine them lasting 60k.
    betterbuckleup likes this.
  7. Jan 7, 2020 at 10:35 AM
    01Montaco
    01Montaco Well-Known Member
    Matthew
    Montana
    2001 Red Tacoma TRD SR5
  8. Jan 7, 2020 at 11:51 AM
    Winkle99
    Winkle99 Don't Look Back
    David
    CO
    99 XCab 3.4 Manual 4x4 TRD SR5
    Yup. You can see the new plastic bushing in the post’s picture lying next to the old pedal assembly.
    I will try this brass bushing when the plastic bushing fails.
  9. Jan 7, 2020 at 11:56 AM
    Phessor
    Phessor Well-Known Member
    What have I done with my 1st Gen today, I drove as far as I could on several trails.
  10. Jan 7, 2020 at 12:23 PM
    Gyrkin
    Wyoming
    Some people just gotta do things the hard way. :der:
    Gen1FTMFW and Wadar like this.
  11. Jan 7, 2020 at 12:33 PM
    Gyrkin
    Wyoming
    That's just the one that goes in the center. There are also bushings that go on each end.
  12. Jan 7, 2020 at 1:16 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Id agree with this 100% almost all shock companies recommend rebuilds at 15k for driving in only dirt. Dirt plus pavement its like 25-30k. Mine lasted about 10k as well since it really only lives in the dirt now and I got a lot of miles in last year. 60k is way too long
  13. Jan 7, 2020 at 2:23 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Made that annoying battery light go off with a new alternator, came on this morning on my way to work and wouldn’t go off.
    Area51Runner, sandsloth and m3bassman like this.
  14. Jan 7, 2020 at 4:51 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    Well today it was the starter (at least the removal), tomorrow I’ll install the new one. On the bright side the Northstar AGM battery is still good...
    But when it rains it pours. In the last month and a half: tires, timing belt & water pump, 90k mi maintenance, LCA’s, left inner tie rod, alignment, new King struts & coils up front and Foxes in the rear, and another alignment next week after I put the new suspension in this coming weekend.
    Hopefully she’ll be good for a while after that.
    For the record I’m not complaining, she’s a great truck and I’ve put a lot of performance parts on her. For an 18yo truck with 114k miles she still feels like she only has 20k on her. Just painful to invest this much $$ in such a short duration. :spending:
    Okay bitch session over, this will help get another 30 years and 900k out of her.
  15. Jan 7, 2020 at 7:05 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Same here. 10k
    six5crèéd likes this.
  16. Jan 7, 2020 at 9:10 PM
    TacomaTyler_2002
    TacomaTyler_2002 Well-Known Member
    Tyler
    Southern California
    2002 Tacoma 2wd 2.7L
    nothing to my Tacoma but I bought this 4Runner
  17. Jan 7, 2020 at 10:12 PM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Here’s another situation when what we drive, how we drive and where we drive are all part of the answer to the “how often” question. Most of you said you don’t agree with the 60k recommendation because of your experience. I have over 100k on my kit and my CO bearings upper and lower are fine. I check regularly and lube/clean often.
    I’m just repeating what was told to me by ADS. Yes it was a full rebuild that I asked about which obviously included the bearings. If your experience is different then by all means go with that and recommend that to others but again, all of our experiences differ.
    xtremewlr, betterbuckleup and Phessor like this.
  18. Jan 8, 2020 at 12:33 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The motor itself is the same basically. Shouldn't be an issue.
    Depends on your driving. Lots of wheeling, 10-15k. Street mostly, Id got 20-30k max.
  19. Jan 8, 2020 at 12:34 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    mine were seized up after 7k... but road salt.
    Fernando likes this.
  20. Jan 8, 2020 at 8:12 AM
    Prayn4surf
    Socal
    Glad it worked for you, if you read my post I pretty much stated what is recommended by King, Fox, and Icon on their websites. If you wanna take yours to 60k thats cool with me. I still think the intervals should be sooner, and you will benefit from better ride quality by cutting that rebuild time in half. And I agree 100% terrain differences and driving style affect intervals.
