  1. Jan 9, 2020 at 7:31 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I need to get that done ASAP too.
    Where’d you get it and how much?
  2. Jan 9, 2020 at 7:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Scan gauge II
    Id get an ultra gauge though.
    m3bassman and Phessor like this.
  3. Jan 9, 2020 at 7:39 PM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Ditto on the Ultra Gauge.
    And get the 1st Gen mount from @SpikerEng
    SpikerEng likes this.
  4. Jan 9, 2020 at 7:47 PM
    1997tacomav6
    Denver
    Mine is under the radio,
    Scanguage II
    Long term trims
    Short term trims
    Engine temp
    Lots of options to pick from
    Advance auto has them 145.00 or so,
    Plug and play
  5. Jan 9, 2020 at 8:08 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    Well I got the new starter in last night, and tonight I went from this:
    To this:
    Alignment scheduled for tomorrow morning.
  6. Jan 9, 2020 at 8:18 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Do you even overland?
    You need more shit on your dash.
    And soon going to need to find where to put a rear air locker switch, or figure out if I can re-purpose the factory elocker switch to trigger an ARB solenoid.
    SwampYota, sandsloth and Phessor like this.
  7. Jan 9, 2020 at 8:32 PM
    Wadar
    Wade
    A few.
    When I installed my “in bumper” lights I tied them into the high beams. (and a switch) I’ll do some looking at my notes and see what I can get you for a wiring diagram.
    chrslefty likes this.
  8. Jan 9, 2020 at 8:33 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    If you tap the signal to the high relay to send a signal to the relay for the lights you should work.. out a switch inline to that and you can make it so they can be turned off for regular high beam use age
    Area51Runner likes this.
  9. Jan 9, 2020 at 8:38 PM
    nw_chris
    nw_chris Outside Everyday
    Albany, OR
    2022 DCSB TRD-OR
    Got it from Toyota of Miami. $105 shipped
    Sorry my gauge choice isn't good enough for you two :rofl:
  10. Jan 9, 2020 at 8:40 PM
    Wadar
    Wade
    A few.
    ^This^ is how I set mine up... I can run them with the high beams, and they turn off with the low beams. Or they can be turned on with the headlights off.
  11. Jan 9, 2020 at 8:46 PM
    Squeaky Penguin
    Brett
    Yeah buddy! I'm overlanding in comfort with my heated seat, and I don't even have to open my hood to air up.
    Must be rough living with only 3 switches.
    :luvya:
  12. Jan 9, 2020 at 8:49 PM
    0maru1212
    0maru1212 New Member
    gonna do an overland type build out, with full size spare and heavy tonneau cover may be a head ache rack, bushwhackers .... ahhh so much to do
  13. Jan 9, 2020 at 8:51 PM
    Empty_Lord
    Dan
    Not off the top of my head. I’m not
    Home otherwise I’d send the EWD
  14. Jan 9, 2020 at 8:57 PM
    Wadar
    Wade
    A few.
    I think these are the diagrams that I used... (it’s been a while)
    Remember to use the appropriate size fuse for you lights, not the theoretical amperage fuse From the diagrams. I’ve had no problems in the last 4-1/2 years. TW and TTORA, along with some of the Jeep forum's have good writeup’s if you google it.
    C732467D-8E21-4815-ABB7-B5D2BAAC6355.jpg 88FED586-972E-49E3-AB42-F5D73E752453.jpg 3079ECFF-2362-42C3-B534-7BA198BF7BCA.jpg EF4C3ECA-8E93-45FB-838C-A47544E8E996.jpg
    Phessor likes this.
  15. Jan 9, 2020 at 9:00 PM
    Wadar
    Wade
    A few.
    Basically you want your high beam switch to trigger a relay to minimize the draw, and keep the higher amperage isolated from your headlights. I’m pretty sure I tapped into mine in the dash under the steering wheel.
  16. Jan 9, 2020 at 9:03 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    forecast is for winter storms to finally start brewing this weekend,
    did some FF reapplication for protection against the elements
    might have used 1/2 a rattle can in all wheel wells and spot in the door sills
    Chicago guy said the FF won't wash off like the other product i was trying seemed to in these particular areas with heavy rain a few weeks ago
    Black DOG Lila and nagorb like this.
  17. Jan 9, 2020 at 9:32 PM
    SpikerEng
    SpikerEng Well-Known Member
    Leon
    Portland, OR
    If you already have the SG, I'm not sure it makes sense to switch to the UG. But starting with a clean slate, the UG is cheaper, displays a up to twice as many gauges, and (most importantly IMO) can be set up with audible alarms if/when things go wrong (e.g. a burst coolant hose).
  18. Jan 9, 2020 at 10:26 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I think the big drawback to the scangauge is the customer support. I've heard there is none.
    Edit, I switched them. Scangauge is supposed to have good support, ultagauge is supposed to not have good support.
  19. Jan 10, 2020 at 4:30 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Ace115[QUOTED] likes this.
  20. Jan 10, 2020 at 4:53 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    SwampYota[QUOTED] likes this.
