  1. Jan 28, 2020 at 8:27 PM
    1997tacomav6
    Denver
    I’ve had two sets of the Monroe quick struts,
    Both sets gave out leaking after about 30k or 40k.
    They don’t compare to the kings but the kings are very expensive and a much larger size strut and stronger spring. Now my truck is perfectly leveled too because they are adjustable in height.
    They can handle pot holes for example pretty easily while the Monroe the truck feels the jarring effect
    mayday[QUOTED] and GQ7227 like this.
  2. Jan 28, 2020 at 8:55 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    Took the old truck up to 11k ft in Colorado after comparing trucks with 1997tacomav6
    Did a few laps in 4wd around a semi plowed rest stop way high up there!
    Got incredible fuel mileage somehow
    Almost 22 per gallon
    Back home I can barely get 20 anymore!
    Is it a result of the thinner air in Colorado?
    Das it mang likes this.
  3. Jan 28, 2020 at 8:57 PM
    mayday
    mayday Well-Known Member
    Central Coast, CA
    99 5 speed 4x4 SR5 TRD Supercharged
    Thanks for the update. I'll make sure I monitor for leaking.
  4. Jan 28, 2020 at 9:02 PM
    1997tacomav6
    Denver
    You will have to look hard, I didn’t see my leaks this last time till the struts were off the truck.
  5. Jan 29, 2020 at 3:36 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    ...As you might expect, turning off the main drag onto New York Mountain Road resulted in the snow level got significantly deeper. Traffic had gone before us, but it had been light - two, or perhaps three vehicles over the last several days. We pressed on...
    We'd encounter the deepest snow so far, and you can read all about it in
    Mojave Redemption #5 - Into the New York Mountains
    CS_AR, Phessor, chrslefty and 3 others like this.
  6. Jan 29, 2020 at 10:34 AM
    Phessor
    Phessor Well-Known Member
    I swapped out my old steering wheel for a Lexus IS300 one with a Rav4 center section and 4Runner column plastic.
    I still need to get the correct clock spring and do the resistors on the C/C shaft.
    But I like how it looks.
    chrslefty, SwampYota, CS_AR and 9 others like this.
  7. Jan 29, 2020 at 10:51 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Curious on what those two controllers are to the left of your wheel?
  8. Jan 29, 2020 at 10:53 AM
    Phessor
    Warn dual beam driving lights.
  9. Jan 29, 2020 at 10:55 AM
    betterbuckleup
    Ian
    Concord, CA
    What about to the right of the clutch cancel button?
  10. Jan 29, 2020 at 10:56 AM
    Phessor
    Dual battery voltage meter.
    And the red button below is the control switch for the dual battery controller.
  11. Jan 29, 2020 at 11:33 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Anyone know if it's possible to order a MAF gasket somewhere? It's not from Toyota. Can only get it with the sensor.
  12. Jan 29, 2020 at 11:52 AM
    betterbuckleup
    Ian
    Concord, CA
  13. Jan 29, 2020 at 11:59 AM
    Reh5108
    Idaho
  14. Jan 29, 2020 at 12:02 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Isn’t it just an o ring?
  15. Jan 29, 2020 at 12:09 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Will the Toyota one not work?
  16. Jan 29, 2020 at 1:22 PM
    betterbuckleup
    Ian
    Concord, CA
    Just mounted my winch battery isolator.
    Now just to find some switches to match the ARB ones and then I can wire it up.
    chrslefty, Prayn4surf and SwampYota like this.
  17. Jan 29, 2020 at 1:29 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    I still need to get the black 4runner steering column plastic for mine.
  18. Jan 29, 2020 at 1:48 PM
    Phessor
    There is a 4Runner in my local salvage yard that has them. I can grab them and bring it down with me for the tail run.
  19. Jan 29, 2020 at 1:50 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    That's be awesome! Thanks!
    Phessor[QUOTED] likes this.
  20. Jan 29, 2020 at 1:52 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    Mounted up my lights and added a hoop to my bumper to protect them.
    CS_AR, nw_chris, Trim taco and 8 others like this.
