  1. Mar 2, 2020 at 9:21 PM
    ronmastas
    ronmastas Member
    '95 Tacoma 4x4
    Morimoto D2S mini 5.0 retrofit in my 1995 Toyota Tacoma. Clears airbox and battery without spacing headlight forward!
    More pictures here.http://imgur.com/gallery/U5xd8ftIMG_20200224_160823_01.jpg
    Parts List:
    Vision X 5x7 (glass housing, cast aluminum housing) Morimoto D2S mini 5.0 projectors
    Morimoto Apollo 3.0 housings
    Morimoto XB35 4300k bulbs
    Xenondepot Xtreme HID ballast 35 watts
    Morimoto H4/9003 Bi-xenon wiring harness
    AMP to D2S adapter harness 90 degrees (for clearance)
    4" PVC Cap and Extension Pipe
  2. Mar 2, 2020 at 9:44 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    There really isn't a wrong answer. I mounted mine as close to vertical as possible. Just depends on where you want your lower mounts to be
    I appreciate his input. He's not just blindly following the rhetoric in here. Sure he may come off a bit crass but what does that matter. From quickly googling the grappler, it looks pretty light weight to me. If a 12T press can't do it I don't think I'd have much confidence in that.
    jubei likes this.
  3. Mar 2, 2020 at 10:52 PM
    2Runner
    2Runner Well-Known Member
    Scott
    So Cal
    2002 Regular Cab 2.4L MT 2WD
    They sent me an email saying they had to cancel the order, since of course it was not available any longer.. well it was worth a shot I suppose!
    Jiveydude[QUOTED] likes this.
  4. Mar 2, 2020 at 10:54 PM
    jonesbt
    jonesbt Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    I'm not sure if you guys want to give it any credit, but the harbor freight wheel bearing press kit has served me well through 3 wheel bearing changes on a Honda Civic and a Corolla. I'm not sure how it would do with our trucks, but my guess is that it would handle the job fine? I use the press with a big electric impact and let the tools do the work.
  5. Mar 2, 2020 at 11:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It might be a lot to ask for, but maybe el hefe can work it so ignored quoted content is also blocked for the ignorer. :notsure:
  6. Mar 2, 2020 at 11:30 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You can rent a similar tool from autozone......
  7. Mar 3, 2020 at 5:50 AM
    Running Board Man
    Running Board Man Well-Known Member
    Thats what i was going to check when i go to work in an hr
  8. Mar 3, 2020 at 6:43 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    yes, i def. remember the 95 single cab with a bench seat i had for a couple years before upgrading 23 years ago, the 7 hour long-distance drives several times per month was not ideal sitting on a bench but i found a little comfort in a neckbone type pillow stuffed behind the lumbar area
  9. Mar 3, 2020 at 7:44 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    :confused:
  10. Mar 3, 2020 at 8:03 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    So Im not the only one with screwy typing on here?
  11. Mar 3, 2020 at 8:30 AM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Hey guys, just wanted to drop a line and say thank you to all of you guys that post up helpful info on here. I just had what I would consider a very successful off-roading trip thanks largely to the helpful info found on these pages. And those of you that are willing to help me out with feedback and suggestions, thank you guys specifically!
    Was thinking that some positive words might help out to encourage constructive activity here with the other shit going on. You guys that are giving helpful info just know that we appreciate it.
  12. Mar 3, 2020 at 9:27 AM
    eon_blue
    Azusa, CA
    Glad it's not just me, was starting to think it was something glitchy with my new phone I just got. When trying to edit my posts on the browser the cursor jumps to a random place while I'm in the middle of typing.
    Blue92[QUOTED] likes this.
  13. Mar 3, 2020 at 10:21 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yup. My biggest issue is if I need to re-word something and put the cursor in the middle of the sentence and hit the space bar, the next word in line totally dissapears.
    eon_blue[QUOTED] likes this.
  14. Mar 3, 2020 at 10:51 AM
    POSTacoMike
    POSTacoMike On the rocks, please
    Red Deer AB
    2001 Tacoma DC XPreRunner
    OME Suspension, ARB Bumper, frame swap, Rebco logger box.
    Got my 00 Xtracab ripped down. My double cab prerunner will be coming into the shop for its 4x swap, gears, lockers, etc.
  15. Mar 3, 2020 at 11:10 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I believe our local bandito mentioned in another thread that an update is coming soon. Along with it will be a built in Dark skin finally as well thank god.
  16. Mar 3, 2020 at 11:49 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  17. Mar 3, 2020 at 12:10 PM
    1997tacomav6
    Denver
    You will love these lights I installed mine couple months ago over the weekend I open them back up and painted the inside reflectors all black, my only issue was it took me awhile to get the horizontal lines to match each side.
  18. Mar 3, 2020 at 12:27 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    :amen:
  19. Mar 3, 2020 at 1:09 PM
    munozx16
    munozx16 New Member
    Omar
    2001 Toyota Tacoma
    KMC Wheels
    new to the forum , made the account 2 years ago but never really go to posting my build, so here is my before and after
  20. Mar 3, 2020 at 1:11 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You and @Empty_Lord can race on the rebuild.
    Lucky for you he isn’t much competition
