  1. Oct 25, 2020 at 12:45 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You don't have to cut the boots of you take this plate off, slide the boot on, and then put the plate back on.
  2. Oct 25, 2020 at 1:15 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  3. Oct 25, 2020 at 2:53 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yeah, never really thought about condensation. Well, we'll see how it goes. Already because of the light color when I turned them on in the gargage, I'm not enthralled with the LEDs, and I haven't even seen them on the road yet.
    My guess is that I'm 90% likely to purchase new boots and go with some other solution. Probably non-LED, though the Philips you mentioned sound intriguing. Linky?
    Interesting. From how I had to cut mine, I'm not sure that would have worked - the reinforced vent hole/tube sections of the boot were aligned with the heatsink, and were really tweaking the positioning of the LED in the housing. Only by cutting those thicker rubber areas out was I able to get good "bulb" alignment.
    Thanks for the pic though - removing that plate is a great route to try for sure! :thumbsup:
    1997tacomav6 likes this.
  4. Oct 25, 2020 at 3:04 PM
    JKO1998
    Utah
    I’m not completely sure I understand
    The metal retainer clip still fits under the rubber piece too.
    I feel like I’m misunderstanding. Not that really matters I guess.
  5. Oct 25, 2020 at 3:10 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-vs-philips-led-headlights.460313/
    xeon depot sells them and i think retorfit source too.
    Reh5108 and turbodb[QUOTED] like this.
  6. Oct 25, 2020 at 4:00 PM
    Markb574
    Markb574 Member
    Mark
    2004 Black Tacoma
    Blacked out my grille and bumpers today. Also, this is my first vehicle and first post of TW.
  7. Oct 25, 2020 at 4:03 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    So my little 12v masterflow mv50 (something like that) air compressor finally took a crap. I’m thinking about going over board and getting the dual arb compressor. But no way will it fit in the engine bay. Anyone have other suggestions on a good place for it? I thought I’ve seen someone use the back cubby hole but I can’t find it on here.
    yodataco and ToyotaDriver like this.
  8. Oct 25, 2020 at 4:32 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    My boots necked down to the circumference of the shaft between the heatsink and retainer clip, and there was a bunch of rubber reinforcement in that neck down area. Looks like your boot has a big circle cut in it, so all that part is gone. I'm surprised you even had to take off the retainer clip to get the boot on.
    But I'm with ya - doesn't matter at this point, hahahaha.
    :thumbsup: Here's to hoping I don't mind the color temp.
    m3bassman[QUOTED] likes this.
  9. Oct 25, 2020 at 4:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's the one thing I dislike about running the LED replacement housings in my old style front. The color temp is just disgusting, it's harsh and it looks like a cheap vehicle that someone put a dollar store HID kit into. But they're more resilient than the old sealed beams my truck came with so it's worth it. Otherwise I wouldn't put up with it. They make LEDs with softer color temp, but you never see them in headlights, which is a shame.
  10. Oct 25, 2020 at 4:39 PM
    eon_blue
    Azusa, CA
    Could always put some color correction lighting gels in the headlight housing haha
    Kidding, mostly
  11. Oct 25, 2020 at 4:41 PM
    Speedytech7
    Interesting idea, but you've seen a gel fade before I'm sure. Need to convince one of these Chinese factories to use some softer LEDs
    eon_blue[QUOTED] likes this.
  12. Oct 25, 2020 at 5:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    6000 Kelvin is terrible light. At least for my old eyes. That white, white, white light is almost useless for visual depth and adverse weather.
  13. Oct 25, 2020 at 5:15 PM
    Empty_Lord
    Dan
    its horrible in rain.. my rental car had the LED lights and in rain.. fuck your better off with a candle
    ToyotaDriver and Speedytech7 like this.
  14. Oct 25, 2020 at 5:15 PM
    JKO1998
    Utah
    Haven’t got the chance to see what they’re like in snow or rain, but that white light early in the morning definitely takes a seconded to adjust to
  15. Oct 25, 2020 at 5:33 PM
    Mischief
    Mischief misadventurer
    Christi
    Duke City NM
    2004 Tacoma crewcab TRD
    I fixt my cracked coil tower today. Thx for the heads up, it wasn't bad but I can see how it could get a lot worse in a hurry.
  16. Oct 25, 2020 at 5:34 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    How long did you compressor last? Think mine is going on 8 years and still going. Was definitely worth the $50 I spent on it.
  17. Oct 25, 2020 at 5:35 PM
    Mischief
    Christi
    Duke City NM
    It looked to me by the way things were bent that it was prolly cracked from topping out50530097596_3f67fbbc5a_c.jpg
  18. Oct 25, 2020 at 5:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Limit straps will help with that.
    Mischief[QUOTED] likes this.
  19. Oct 25, 2020 at 5:46 PM
    Dan8906
    Daniel
    Concord, California
    3-4 years? I think trying to air up more than just my truck over the years did it in. It’s so slow! I’m looking at all the options
    Reh5108[QUOTED] likes this.
  20. Oct 25, 2020 at 5:51 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    That was me. I stuffed my twin compressor in the passenger side cubby hole
