  1. May 27, 2011 at 6:45 AM
    #1961
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    i finally got myself a taco :D 1996 4cyl 4x4 reg cab
  2. May 27, 2011 at 11:02 AM
    #1962
    Slodgetto
    Slodgetto Über Posre
    Silas
    Oooohhhhhhh!!! I think I get it. And yes, I had sprayed everything with PB Blaster to get everything out, and they were still wet when I put them back on.....:eek: Maybe I should re-torque them now that they're dry... thanks, man! I have :facepalm:myself!
  3. May 27, 2011 at 12:20 PM
    #1963
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    I finished installing some Bushwacker Cut out flares! Bit of a PITA to install. Time consuming mainly. You can also see the JBA exhaust tip peaking out in one of the pics. I installed their Cat back system a few days ago.
    Now its time to cut up some big rig mud flaps and install them!
    I just had to get both my babe's in one picture. :p
    Next on the to do list: vinyl flooring and Line-X Xtra....EVERYWHERE!
  4. May 27, 2011 at 1:23 PM
    #1964
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Thats a nice 96! I love the color! How long and how hard was it to install the bushwackers?
  5. May 27, 2011 at 3:08 PM
    #1965
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    What???? :p
  6. May 27, 2011 at 3:16 PM
    #1966
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The bushwhackers look good man I just installed mine last week and I love them.
  7. May 27, 2011 at 5:13 PM
    #1967
    JLee
    Jerry
    Grass valley CA
  8. May 27, 2011 at 6:40 PM
    #1968
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Dude!
    Those flares are rockin'! I must say they go with your tires very well and I love your front bumper! Good choice.
    Truck is lookin' great!:cool:
  9. May 27, 2011 at 6:47 PM
    #1969
    JLee
    Jerry
    Grass valley CA
    Thanks man I didn really know if I was going to like them but they turned out awesome! The sliders are weld on and there ELITE off road.
    Thanks yeah they cover just as much tire as I wanted them to. I stick out just about 1 1/2" past the flair.
  10. May 27, 2011 at 7:14 PM
    #1970
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    That's right you heard me .
  11. May 27, 2011 at 7:59 PM
    #1971
    futuretacoowner
    futuretacoowner Well-Known Member
    Andrew
    Canada
    02 2.7L xtra cab
    those look great!!I was thinking of getting some for my truck.
  12. May 27, 2011 at 9:32 PM
    #1972
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Lookin good man. What lift and tire set ups are you running? Just curious, it looks really good.
  13. May 27, 2011 at 10:42 PM
    #1973
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    washed them both
  14. May 27, 2011 at 10:51 PM
    #1974
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    could be the brake pedal switch?
    hard to tell from that pic
  15. May 27, 2011 at 11:14 PM
    #1975
    Twistedtacoma4wd
    Twistedtacoma4wd Member
    Taylor
    Alabama
    98 tacoma 4x4
    Total chaos upper control arms, adjustable coil overs, water temp gauge and vacuum gauge from street glow, 2 10" boss 2200w subs w/ crunch 1000w amp. K&N cold air intake, LCM header with dynomax exhaust.
    Did a little offroading and then washed her up.
  16. May 28, 2011 at 5:22 AM
    #1976
    CdnSldr
    Canada Eh!
    It actually wasnt that bad. About 5 hours. I was doing it in my driveway as well lol. Pulling the front tires would have made it easier.
  17. May 28, 2011 at 5:27 AM
    #1977
    CdnSldr
    Canada Eh!
    In the front ive got the standard ULK from toytec. Rear are 2.5" overload springs from Northwest Offroad with 5125's.
    Tires are 33/12.5/15's Duratrac's on Wheeler's type B steelies.
  18. May 28, 2011 at 7:52 AM
    #1978
    scocar
    scocar Patron of the Farts
    Yeah, it is retarded design. You have seen the replacement options, right? Some guys have made bronze bushings using stock from hardware stores. Eventually, I will be doing this.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/76599-clutch-pedal-squeak-new-bushing-design.html
    http://www.tacomaworld.com/forum/1st-gen-tacomas/139718-clutch-pedal-permanent-squeak-fix.html
  19. May 28, 2011 at 8:11 AM
    #1979
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    hey dude id get a new bushing for that soon.. i ran mine for a long as time without the bushing cause i was lazy and well i was driving one day and my pedal stuck to the floor.. so wtf right? pull the pedal off and the spring had ground away over a 1/4 slot into the cradle of the bushing and offset the geometry so much that the pedal didnt function...
    i ended up welding it and grinding it down and replaced the bushing. ill eventually make a bronze one.. later.
  20. May 28, 2011 at 1:15 PM
    #1980
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    I used it as a "truck" ;)......New side fences installed this week and my wife did not "LIKE" the new look....:rolleyes:....
    Off to the "Pit" for more ledge and cast away pavers.....so much for working on the "TRUCK"...:p..
    One good thing came out of all this work....got to "play" out in the pit.....20+ acres of trouble :cool:....
