what have you had to replace on your tacoma...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gupster88, Apr 29, 2010.
  1. Apr 29, 2010 at 11:58 AM
    gupster88
    gupster88 [OP] Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    like the title says, if you have had to replace any parts on your tacoma that you normally would not have to, what are the parts and at how many miles. spark plugs, filters, and all the standard preventative maintenance stuff does not count. im talking like any pumps go out, transmissions, etc
    my buddy has an 06 cummins 2500, we were on a cummins forum and saw a thread like this...you will not believe the number of trannys, injectors, and even motors some guys have gone through before they even hit 75k-100k! could just be the nature of the beast though...
  2. Apr 29, 2010 at 12:07 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Driver side window fell out of the clips. Had to have that replaced along with broken clips. I also had an 02 sensor replaced so far on my 09.
  3. Apr 29, 2010 at 12:13 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    2007 w/ 25K miles on it.
    Radiator cap replaced (under warrantee) - it was leaking.
    Three of my sport wheels were replaced - due to some corrosion on the edges.
  4. Apr 29, 2010 at 12:16 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    how many miles you have it, or should i say...kilometers lol
    yea mine are showing a little bit of corrosion too, nothing big though. cant tell unless you are staring at it close up looking for it like i was lol.
  5. Apr 29, 2010 at 12:16 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    64k, typical engine oil/trans fluid/diff fluid, Cab Air Filter, Tires at 39k. Nothing else. I couldn't be happier!
    Within the next week, new front brakes, rear AAL.
  6. Apr 29, 2010 at 12:17 PM
    Ecapvegas
    Ecapvegas Active Member
    Sin City
    2010 Silver 4x4
    I haven't had it replaced yet, but my cigarette lighter/power adapter socket comes out of it's "home" everytime I hit a bump. It's a little annoying but not a big enough deal to make a special trip to the Stealership.
  7. Apr 29, 2010 at 12:19 PM
    Capita
    Never even hit 10 000 km's when that happened
  8. Apr 29, 2010 at 12:30 PM
    TACO054
    TACO054 Member
    SIDNEY
    ABBEVILLE LA
    05 PreRunner SR5 TRD SPORT
    INTAKE,MAGNAFLOW EXHAUST,AND 3 INCH LIFT
    2005 w/90000 miles had to replace pinion bearing an seal nothin else
  9. Apr 29, 2010 at 12:37 PM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    Rear leaf springs as part of the harsh ride tsb.
  10. Apr 29, 2010 at 12:40 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I only had to replace normal wear items on my 98; brakes, shocks, muffler, etc. I had no major component failures.
  11. Apr 29, 2010 at 12:47 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Have replaced:
    Power steering pump
    brake calipers
    brake rotors
    In need of replacing:
    timing chain/cover
    tailgate
    rear leaf packs
    106k miles
  12. Apr 29, 2010 at 12:58 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Replaced:
    1. Driver's trim piece below/around the remote mirror controls during the first summer (less than 10K miles due to warping from the heat).
    2. Passenger Rear window control (window doesn't always go up from that control...common problem with the DC's). And the replacement randomly doesn't work either. Mileage: Approx 20K+ miles.
    Need to replace:
    Driver's Front Differential Output Bearing. Discovered at 88K miles that it's very, very worn. Since I'm way out of warranty, we'll see how long it lasts...
    No other non wear-and-tear items.
  13. Apr 29, 2010 at 1:08 PM
    blackwatertaco
    blackwatertaco If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    Shocks, Tires.
    my 2003 6.0 F250 powerstroke, Ummm
    Injectors, Oil pump, 3EGR valves, Tires, Shocks, HP P/S line, Brakes, Shift linkage, And shift on the fly switch on my 4x4.
  14. Apr 29, 2010 at 3:22 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    That is odd... if the engine has not been abused and the oil has been changed regularly, a timing chain should last the life of the engine, and Toyota engines can go 300k miles or more.
    Nothing unusual has needed replacing on my 06 with 46k miles -- just tires, filters, fluids, etc.
  15. Apr 29, 2010 at 3:28 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Upper control arms, lower control arms, spindles, front axles, driveshaft, rear springs, lots of shocks, seats, seatbelts, skidplates, bumpers (front and rear), headlights, gas tank, battery, and a few other things.
    I know...I'm not helping. :p
  16. Apr 29, 2010 at 3:35 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    There's a TSB for the timing chain cover leak.
  17. Apr 29, 2010 at 4:01 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    At 10K miles the transfer case seal around front drive shaft. i noticed the gear oil all over my transfer case skid plate
  18. Apr 29, 2010 at 4:10 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Tailgate handle with pop n lock. Diff breather relocation. Gas cap with locking gas cap. Antenna with shorty antenna. Stock grille with grillcraft.
    Not that I HAD to do any of these...they were just good ideas...
  19. Apr 29, 2010 at 4:24 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    Windshield.
  20. Apr 29, 2010 at 4:34 PM
    newtaco2008
    newtaco2008 Well-Known Member
    Fort Mill, SC
    08 prerunner indigo ink pearl
    2008 prerunner 17500 miles. Just the rear spring harsh ride.
