What have you hauled lately
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Adibucur1, Feb 11, 2017.
  1. Dec 11, 2017 at 5:16 PM
    #221
    CristiaanC
    CristiaanC Well-Known Member
    Austin, TX
    2017 Inferno 4x4 SR5 DCSB
    King 2.5 Coilovers, SPC UCAs, OME Nitros, Deaver Springs, SCS SR8s. Hercules TerraTrac M/T
    Hey guys,
    I don't think anyone has done this yet, but I will be towing a 6x12 uhaul trailer from Texas to NY for the next few days. Trailer is around 2000 lbs empty, I probably have about 1000 lbs of weight (at least) in it. I also have about 400 lbs of weight in the bed. I do have the tow package on it, so hopefully it'll be smooth sailing. Going through TN, VA and PA can be a bit hilly to say the least, so we'll see how it goes.
  2. Dec 11, 2017 at 5:24 PM
    #222
    pdxtaco02
    pdxtaco02 Well-Known Member
    Luke
    Portland, Oregon
    2016 TRD Sport QS MT
    Hauled this strange setup from Portland Oregon to a Willows, CA for a Race Weekend.
    2 Bikes total and a bunch of gas, water food and gear
    I estimate ~1100 lbs in the trailer and 600 in the bed.
    She did great, averaged 17.5 mpg w/ stock tire setup
    rlx02 and Mr. Torgue like this.
  3. Dec 11, 2017 at 5:26 PM
    #223
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Some of you should invest in helper springs or sumosprings
  4. Dec 11, 2017 at 8:16 PM
    #224
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    Can't say that I do and my load is extremely tongue heavy until I get a better weight distribution hitch set up. What tires are you running and what motor, transmission, and transmission setting are you set up with? I've got the the stock TRDOR tires, V6, auto with ECT. I could see it happening with super hard tires or a manual but otherwise it seems odd.
  5. Dec 11, 2017 at 8:19 PM
    #225
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    Do you have a brake controller? Stock taco in 16 did not, I haven't kept up with Tacoma news so if yours has a brake controller youre good. If not I'd hold off until you out one in. That much weight absolutely will push you around and having no ability to control the trailer can lead to dangerous conditions in a split second.
    Towing with a bad set up will get you in trouble before you can blink. Been there, done that, done fuck with it.
  6. Dec 11, 2017 at 8:22 PM
    #226
    mweidl
    mweidl Well-Known Member
    Mikey
    Southern California
    2017 Tacoma SR 4x4 Auto
    I do all my towing with my diesel tacoma
    specter208, Misfit and Mr. Torgue like this.
  7. Dec 11, 2017 at 8:32 PM
    #227
    smcfarla
    smcfarla Well-Known Member
    CT
    2017 TRD sport, red
    Picked up my mower from it's tune up...perhaps seasonably late
    specter208 and pdxtaco02 like this.
  8. Dec 12, 2017 at 2:29 AM
    #228
    CristiaanC
    Austin, TX
    Don't have the time to do that. The trailer does have a surge brake system installed.
    So I guess we shall see how it turns out....:fingerscrossed:
  9. Dec 12, 2017 at 5:17 AM
    #229
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    When I test drove the Gen3 I was not able to test towing performance so I'm trying to get your feel. I'm gen2 with 4L auto. I had an 06 with MT but found it to be weak when taking off with load. The clutch would squeal. I don't think tires matter too much as I've done it with various rubber. The main consideration for me is the fact it breaks loose at 1500 rpm which demonstrates good bottom end torque.
    As far as tongue load goes, it's important to have enough. Although I don't go as far as to measure it, I try to visually offset my loads forward of the axles the goal being 10 to 15 percent. When towing my 27" RV with WDH, it's very easy to spin. When I set up my WDH, I don't remove all the load from the rear, about half. Without WDH, the sag is 2". With WDH, the sag is 1". I'm guessing 600 lbs tongue load without an 300 lbs with. Anyways, just trying to see if the 3.5 had any balls at all at low rpm. If not, is it the computer chocking it out? I used to tow with a 97 4Runner and although it would not break loss, lol, it would tow fine at moderate speeds. The 4Runner didn't have the rear suspension to handle the tongue loads and it lacked power.
  10. Dec 12, 2017 at 5:21 AM
    #230
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
  11. Dec 12, 2017 at 6:44 AM
    #231
    smithers0990
    smithers0990 Member
    2016 Tacoma (Double Cab)
    Fully loaded SnapOn Epic tool box. Finally got out of the industry.
    Lawfarin and 1cleanFG like this.
  12. Dec 12, 2017 at 2:52 PM
    #232
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    Even without a load being towed the 3rd gen isn't going to win any drag races. That being said, I've had to pull off on some up hills and then get back up to speed with a 6000 pound trailer and it's easy enough to get up to speed.
  13. Dec 12, 2017 at 5:18 PM
    #233
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Thx Mr Torque that's good to know.
    When accelerating to highway speeds with said 6000lb load, without bring in a hurry, what rpm range are you in? In other words what rpm do you take it to before it downshifts? Do you set the shift to 4th or 5th when towing?
  14. Dec 13, 2017 at 6:52 AM
    #234
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    I'm usually in the hilly terrain getting to the desert so I'll set it to S4 with ECT. If it's flat or downhill for a long ways the I'll shift up to 5th. It's been awhile but I believe it was usually running 3-4k rpms with the load and ECT on while doing 65-70.
  15. Dec 13, 2017 at 6:54 AM
    #235
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Hauled my ass to Walmart and back this morning. :D
    specter208 likes this.
  16. Dec 13, 2017 at 9:39 AM
    #236
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    I personally don't know go over 60 mph with heavy loads. Not for lack of power but more so for stopping in a hurry. Just me being aware that my load is heavier than my truck, brakes or not. So at 60 mph I'm running at 2500 rpm in 4th. It takes quite a grade to make it shift to 3rd then it goes to about 3500 rpm until I round the top.
  17. Dec 13, 2017 at 10:51 AM
    #237
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    My 2016 TRDOR with: Snugtop Rebel, another 300lbs in the bed, a tongue weight of 275lbs, and nothing other than SumoSprings. They do the job just fine.
    slamson00 likes this.
  18. Dec 13, 2017 at 11:10 AM
    #238
    Dan_Boone
    Dan_Boone New Member
    Drew
    Just picked up a half cord of seasoned firewood today. The sag isn't as bad as it looks, I'm on a hill. [​IMG]
  19. Dec 13, 2017 at 4:08 PM
    #239
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    Fair enough, I believe the 16 shifts closer to 4k when cruising but I don't remember for sure. I do leave larger spaces between me and other vehicles while towing, but I'll cruise along the same speed. The brakes and tires on the trailer are pretty solid and I believe it stops pretty close to the same distance as without. I've got the brakes pretty dialed in with the Tekonsha or however it's spelled controller. Trailer doesn't push or pull the truck when slowing down.
  20. Dec 13, 2017 at 4:19 PM
    #240
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    I have the same controller. Works very well. This what I'm normally towing.
    Mr. Torgue[QUOTED] likes this.
