What Height is This Lift? Just Purchased First Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by brandnewcolony, Dec 22, 2010.
  1. Dec 22, 2010 at 3:29 PM
    brandnewcolony
    brandnewcolony [OP] Well-Known Member
    Fort Worth, Texas
    2017 Tacoma TRD Pro SW
    Hi everyone, I have been on TacomaWorld non stop since I purchased my first truck/ Tacoma a few weeks ago. Now I am planning on upgrading my lift and could really use some advice and help. I want to go slightly higher (preferably) than what I have now, but not sure which route to go. Whats on now looks like a 3 inch lift but I'm not sure, what do you all think? After much reading on this forum I am leaning towards 5100's at all four corners, and an AAL. But what inch AAL will I need to purchase to have my truck sitting level? I'm kinda anal about that I don't want the front sitting higher than the back and vice versa.
    Thanks all in advance, I am so thrilled to have my first Tacoma and cant wait to mod it out like all of yours!
  2. Dec 22, 2010 at 3:43 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Check if there's lift blocks in the front above the spring coils/in the back on the spring perch. Also check for lift shackles or AAL (stock packs have 3 leafs and 1 overload). With those, you can see how much lift they are giving.
    Luckily, doesn't look like your truck has a body lift.
    BTW...nice police push bar.
  3. Dec 22, 2010 at 3:58 PM
    brandnewcolony
    Fort Worth, Texas
    Bare with me as I am a complete noob when it comes to lifts, but I believe I have spacers up front( there is 2 separate red polyurethane pieces which I'm sure are spacers) with the stock billys, and not sure what the back has, the leaf pack looks stock so I'm thinking it has lift shackles. Ill have to take some pics when I get off work and post them so I can get the info I need.
  4. Dec 22, 2010 at 4:03 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    There could also be blocks in the back... The leaves should sit right on the axle. If there's a metal box between the leaves and the axle, you've got block s
    Sweet truck... Welcome!
  5. Dec 22, 2010 at 4:05 PM
    brandnewcolony
    Fort Worth, Texas
    I Def have no blocks. Ive seen other pics on here with lift blocks so I know what those look like.
  6. Dec 22, 2010 at 5:10 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    I can see shackles sticking down....so you have a shackle rear lift and spacer front lift. You will be upgrading greatly if you get an AAL for rear (ditch the aftermarket shackles), and get billy 5100's for all four corners. Set the fronts @ 2.5", you'll be set! Great looking taco!
    BTW...def provide undercarriage/suspension pics so we can 100% verify your current setup
  7. Dec 22, 2010 at 5:21 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    x2 get some up close pictures of the front suspension and rear. we can confirm exactly what you have.
  8. Dec 22, 2010 at 5:56 PM
    brandnewcolony
    Fort Worth, Texas
    Thanks a lot for the help man, I will Def post some pics of the suspension asap. I know I want the Billy 5100's all around that seems to be the most popular and best choice, but do you know what inch AAL to get to make it sit even/level? Would you recommend an AAL or full leaf set? Thanks again
  9. Dec 22, 2010 at 6:16 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    PROBABLY THE 2" aal i think thats what the majority of kits come with and you shouldnt need new packs unless yours are frowning and just wore out.
  10. Dec 22, 2010 at 6:58 PM
    brandnewcolony
    Fort Worth, Texas
    Here's the suspension pics guys....
  11. Dec 22, 2010 at 7:00 PM
    98_Mud_bug
    lucedale Ms.
    looks like 2 inch shackles, and some type of coilover. thats not a spacer lift..
  12. Dec 22, 2010 at 7:03 PM
    NegroTundra
    Land of Enchantment
    it looks like a polyurethane spacer to me....with red bellows to match...hmmm i'm thinking rancho shocks?
    Get a different angle of the front setup, like a complete profile pic.
  13. Dec 22, 2010 at 7:06 PM
    brandnewcolony
    Fort Worth, Texas
    Coilovers Really?? I was really thinking it has spacers because the shocks are the stock billys. I dont see a spot where I can adjust them either.
  14. Dec 22, 2010 at 7:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  15. Dec 22, 2010 at 7:09 PM
    98_Mud_bug
    lucedale Ms.
    it may be a spacer but its a small one, maybe some stiff coils for the lift?
  16. Dec 22, 2010 at 7:21 PM
    brandnewcolony
    Fort Worth, Texas
    here are some more pics thanks again for the help guys! I went through a grass field today and the suspension was very squeaky thats one reason I want to replace it. Im thinking my shocks are bad they look like stock billy's but im not 100% sure
  17. Dec 22, 2010 at 7:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im gonna say its the Daystar 3" spacer lift in the front, and the shackle lift in the rear.
  18. Dec 22, 2010 at 7:32 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Bilstein 5100's are nice, and an AAL is a good option for the rear. I have that setup and the ride quality is great.
    Looks like your in the Ft. Worth or Lake Worth area, let me know if you need any help with the install on what you get.
  19. Dec 22, 2010 at 7:34 PM
    brandnewcolony
    Fort Worth, Texas
    chris 4x4, I'm leaning towards you on this one. The pic you posted of the daystar lift looks exactly what im seeing. Does my truck look level to you from the first couple pics?
  20. Dec 22, 2010 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It looks like the back end may be a little higher....
