What I Learned Today Removing My Headlamps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WATacoRider, Dec 10, 2009.
  1. Dec 10, 2009 at 4:00 PM
    WATacoRider
    WATacoRider [OP] Well-Known Member
    TRD Sport 4x4
    Removing the front grill is very easy. Only 2 bolts, 2 of those hole clips, and 2 little tiny tabs you push in.
    There are 4 bolts for the headlamps.
    2 on top which are very easy to remove. 1 on bottom corner by grill. It's slightly covered by the bumper, so it's a little harder to remove and put back in properly.
    The 4th bolt is a bitch to get to. I was going to try to make it easy on my myself by remove the wheel well lining, but I couldnt figure out how to get it off....
    So basicly, I just went under the truck and felt around until I got the bolt loose with my socket. Pain in the ass.
    After all the bolts are remove, it's still a pain in a the ass to remove the actual housing, from the truck. Gotta angle, wiggle, and until you get the right combination. Same thing putting it back into place. UGH.
    Nothing like remove my 02 Taco headlights, that was super easy.
    The Eagle Eye or whatever brand of headlights look almost exactly like OEM, except for the fit. It's close enough to work, but will be off slightly.
  2. Dec 10, 2009 at 6:04 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    You can pull of two or three clips off the lower side of the inner fender well, and pull it back far enough to get the bitch bolt.
    http://www.xr-underground.com/forum/showpost.php?p=225562&postcount=91
  3. Dec 10, 2009 at 7:10 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Mine was easy as pie, I cutout the inner fenders ages ago when I got my lift. Just a matter of throwing a ratchet on it
  4. Dec 10, 2009 at 7:12 PM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    Lucky dog if you are stock in the suspension dept. its not fun to get up in there!
