What is a good under hood mount for a ARB duel air compressor?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The_donk, Oct 31, 2020.
  1. Oct 31, 2020 at 4:38 PM
    The_donk
    The_donk [OP] Well-Known Member
    Ian
    Waco , TX
    2013 Tacoma TRD off road
    Everything
    I need a good mount for my air compressor and it is hard finding anything but slee for under the hood in my 2nd gen. Any suggestions?
  2. Oct 31, 2020 at 4:47 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I suggest Slee.
    It’s well made, easy to install, hold the compressor securely.
    Why don’t you like it?
    The_donk[OP] likes this.
  3. Oct 31, 2020 at 4:50 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Depends on its duelling opponent...
    On a serious note, most 3rd gen underhood mounts are compatible with 2nd gen, because the inner fenders are the same. If you want to run shorter wiring and mount the compressor on the driver's side, the Rago mount should work, as long as you have an automatic trans: It has its drawbacks - makes fuse box hard to open, and exasperates Taco Lean.
    The_donk[QUOTED][OP] likes this.
  4. Oct 31, 2020 at 4:56 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
