What is easiest to lift? Front or Rear?
Discussion in 'Suspension' started by Hanz, Oct 20, 2012.
  1. Oct 20, 2012 at 3:35 PM
    Hanz
    Hanz [OP] Well-Known Member
    Doug
    Long Island, NY
    2003 Tacoma DC 4X4 TRD
    LED Instrument lights
    I just installed an OME lift in the rear of my truck and it kicked my ass. I was working alone and ran into a few hang ups.
    I have the front struts pre-assembled. Are they going to be easier to install than the rear?
    Oh, I'm wrenching on a 2003 DBL Cab.
  2. Oct 20, 2012 at 4:45 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Is the front spring and shock is already assembled the hardest part is removing 3 top bolts and a bottom bolt and removing the old and putting in the new one.
  3. Oct 20, 2012 at 5:07 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    sold everything
    I had a way easier time installing the preassembled fronts than my aal. I thought for sure the front would kick my butt, but not so much.
  4. Oct 20, 2012 at 5:08 PM
    sirsaechao
    Tim
    Commifornia
    Rear is more time consuming especially if you have a seized main eye bolt due to rust.
  5. Oct 20, 2012 at 5:08 PM
    Hanz
    Doug
    Long Island, NY
    That sounds too easy. I don't have to separate a ball joint?
  6. Oct 20, 2012 at 5:10 PM
    sirsaechao
    Tim
    Commifornia
    No you don't have too. Worst case is leverage to move the lower control arm bolt hole to match up to the shocks bolt hole.
  7. Oct 20, 2012 at 5:11 PM
    skidooman
    TJ
    Northern Nevada
    sold everything
    Hardest part on the front for me was getting the bottom bolt in the new shock assembly.
  8. Oct 20, 2012 at 5:23 PM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    Silver 2012 DCSB 4x4 V6
    TRD SC, URD 2.8" pulley, NST Pulleys, BullyDog Tuner, Cometic Headgaskets, ARP Head studs, rod bolts, flex plate bolts, header studs, CP Pistons, Molnar Rods, Clevite Bearings, APR Exhaust cam gears, 170* thermostat, URD TCAI, DTLT Headers, URD Y Pipe, URD MK2 Catback exhaust, URD Fuel Pump upgrade, Fuelab Fuel filter, AEM Adjustable FPR, AEM Datalogger with AFR, Boost, Fuel Press, Oil Press, Oil Temp, Trans Press, Trans Temp, Coolant Temp Sensors, TR Drop Kit, StopTech BBK, TR Disc Conv, Stainless braided brake lines, -6AN Stainless braided Fuel lines from rail to tank, -6AN Stainless braided transmission cooler lines w/Earls Cooler, Stainless braided Powersteering lines w/Custom reservoir
    Front was easiest, my springs came pre-assembled. Rear AAL kicked my butt, next time I'm going with a new leaf pack.
  9. Oct 20, 2012 at 5:23 PM
    Hanz
    Doug
    Long Island, NY
    The left front leaf spring bushing sleeve seized to the bolt. I did everything I could not to cut the bolt. I wasted two hours on that and ended up having to cut the bolt anyway. It's my only vehicle and I was working alone. I'm a little frightened to strand myself. :eek:
    Thank you, I'm no longer afraid :D
    Thanks for the reply. I'm glad to hear it doesn't sound so bad. I have some line up tools that may help me.
