What is the functional or performance gain using different wheel offsets?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trucks2019, Dec 9, 2023.
  1. Dec 15, 2023 at 4:02 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I have to second this statement. I thought my truck is less sensitive to road crown running a 0 offset but it could just be the tires.
    Personally I think a +5 to 0 offset looks really good.
    hiPSI[QUOTED] and bulalo like this.
  2. Dec 15, 2023 at 4:12 PM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    To all the people saying there’s no functional difference: throw some 35x12.5x17 on your stock rims real quick then come back and try again.
  3. Dec 15, 2023 at 4:50 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Negative wheel offset creates better stability...I Googled it so as such my answer is "beyond contestation."
  4. Dec 15, 2023 at 4:58 PM
    TacoTuesday1
    SD CA
    ah yes, width stability racing Nurburgring in a high CoG lifted big tire truck with no sway bars
    CaptainBart45[QUOTED] likes this.
  5. Dec 15, 2023 at 5:07 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I went +5 with 33" 255/80/17 Wildpeak's, and a 2" Lift. Soooo glad I didn't have to remove my mudflaps, or do any trimming.
  6. Dec 15, 2023 at 7:05 PM
    Trucks2019
    Trucks2019 [OP] Well-Known Member
    Nice, which tires are those? And what’s rims?
  7. Dec 15, 2023 at 7:06 PM
    Trucks2019
    Does your spare fit under the bed still?
  8. Dec 15, 2023 at 8:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Stock. We are talking about stock. Change size, all bets are off.
    BC Hunter likes this.
  9. Dec 16, 2023 at 7:31 AM
    DoritoBurrito
    DoritoBurrito Member
    2014 Tacoma TRD OR
    The tires are 265/75/16 BFG All Terrain K02 and the rims are 16x8 0mm offset KMC Impact OL. Really happy with the way they look and fit.
    I haven't put a new tire on my spare yet but I've read that it should fit without any issues. Seems like this tire size is really the way to go if you want to run a larger tire without having to do any cutting.
    https://www.tacomaworld.com/threads/will-a-265-75r16-fit-in-the-spare-tire-spot.400420/page-2
  10. Dec 18, 2023 at 7:28 AM
    czukie
    czukie Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    Am I the only one that is sad @SCSPerformance refuses to make a 17” wheel with +0 offset? :annoyed:
  11. Dec 18, 2023 at 9:29 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    This is, in fact, the main driver on the topic... However, depending on where you live, this value may be negative...
    I am a fan of the Ray 10 look. - I'm sad they don't make a 16"...
    - but maybe also happy because then my current wheels are the best looking option by quite a bit.
  12. Dec 18, 2023 at 9:40 AM
    czukie
    Colorado
    What is your setup?
  13. Dec 18, 2023 at 11:22 AM
    OZ TRD
    Central Coast CA
    I have the stock 16" PRO wheels - I do not recall the offset on these, With Falken AT3w 265 75 16 - one notch up from stock. And I do not foresee going any bigger...
  14. Dec 18, 2023 at 11:35 AM
    czukie
    Colorado
    I believe they are +5mm
  15. Dec 18, 2023 at 4:07 PM
    #35
    TacoTuesday1
    SD CA
    This.
    If I'm not mistaken, bigger tires require wider width than what comes on stock wheels
  16. Dec 18, 2023 at 5:05 PM
    #36
    btiptacoma
    btiptacoma Active Member
    Pic?
  17. Dec 18, 2023 at 5:07 PM
    #37
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    Suspension is the same but the range of motion is increased ….
  18. Dec 18, 2023 at 5:40 PM
    #38
    TacoTuesday1
    SD CA
    no
    limit is limit and bumpstop is bumpstop
    UCA LCA strut spring tie rods and axle is the same
    Method or Icon doesn’t magically create Long Travel
    hiPSI likes this.
  19. Dec 18, 2023 at 6:01 PM
    #39
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    On the front there is no increased wheel articulation with wheel offset. In the rear there technically is but the 50mm swing from +25 to -25 would end up in a pretty negligible articulation increase.
    Just think about the geometries involved and it’s pretty simple to picture.
  20. Dec 18, 2023 at 7:56 PM
    #40
    fake4x4
    Cool stuff
    Doesn’t make sense , you gain more range when you increase your track width ….simple Geometry
