What is the status of "anytime 2wd Low range"?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VTCAL, May 23, 2025.
  1. May 23, 2025 at 10:56 PM
    VTCAL
    VTCAL [OP] Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I've scanned the 3rd gen forum.
    Caught wind to "discontinued" on the 2nd gens.
    I've got a 2021 6mt Sport and could use low range in reverse!
  2. May 24, 2025 at 4:55 AM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Not sure last time I checked the website was down. I have the harness ready to install and went to look at something about the switch and it was gone.
  3. May 24, 2025 at 6:10 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Some do it, but I don't recommend it. Back in the day when 4X4's had 3 sticks in the floor and manual locking hubs it was easy to shift to low range and stay in 2wd. They also had statements in the owners manual as well as stickers on the dash warning drivers not to do so. They no longer include the warnings because it's impossible to do that from the factory. I've seen guys snap U-Joints who did it.
    Tocamo likes this.
  4. May 24, 2025 at 9:31 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The danger of damage is directly proportional to the quality of the brain operating the controls.
  5. May 24, 2025 at 10:04 AM
    bbal
    bbal Well-Known Member
    2Lo is the only way I can back up a 3000 pound boat or my 1800 pound teardrop without burning up the clutch. Pretty sure a broken joint would be less expensive than a clutch.
    Max8, andy044 and doublethebass like this.
  6. May 24, 2025 at 11:08 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Fixed it...
    Because the force needed to move a trailer does not change depending on whether you are on 2low or 2high...
    One can easily make the argument that 2 low lets you do the (same) work with a gentler application of power.
    The alternative implied; Using 4low under high power, with tight turns on dry surfaces comes with the same risk above PLUS potential damage to the front drive train... (as being bound adds additiinal loads /internal stress.)
    I don't use it for trailers much, but do use it often off road when tight turns are needed while climbing, or when conditions make speed undesirable.
    Chew likes this.
  7. May 24, 2025 at 10:53 PM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    if you need a switch, ch4x4 or air on board sells the switch
  8. May 25, 2025 at 4:20 AM
    Thunder chicken
    Thunder chicken Well-Known Member
    NW Ontario
    ‘18 access cab manual
    Is the thread showing the parts required not here anymore? I did the 2lo mod DIY back in 2018/19, on my almost new truck. A big relay, a big resistor, a switch and splicing into the hsrness, accessing behind the glove box and ta da. It wasnt super hard, and has worked great, i used it yesterday in fact.
    doublethebass likes this.
  9. May 25, 2025 at 5:54 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    shakerhood and VTCAL[OP] like this.
  10. May 25, 2025 at 5:19 PM
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    I honestly forget exactly what I was looking for. I think the wiring diagram for the harness to the switch. I would like to use my aux beam to activate it.
  11. May 25, 2025 at 5:20 PM
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    What would be the danger of using 2 low? It's mostly for things like backing up a steep hill or moving a trailer. Low speed movement.
  12. May 26, 2025 at 5:42 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    He has said this over and over and over again as if simply switching into 2Lo mode immediately grenades everything on principle. Backing up a trailer or whatever else people use 2Lo for is such a slow and controlled process that I would be completely amazed if someone managed to ruin anything by doing so in 2Lo. It’s not like anyone is gassing it hard…they are using it for the slow control.
  13. May 26, 2025 at 6:01 AM
    bbal
    I saw a comment on here a long time ago that putting all the torque strain on just half the system could cause issues. I’m hesitant to pull my 3,000 lb boat up the ramp using 2LO but it would definitely help. The truck is incapable of pulling it up a steep ramp out of water in 2 high. It requires so much clutch slip and clutch smoke at high RPM to get it moving and when I did it last year I actually couldn’t even release the clutch. I went to 4LO and it was gravel so not terrible as I pulled it up the ramp and turned but I still wasn’t happy about it. It’s a family trip that we only do once a year with that boat so I’d like to figure this out.
  14. May 26, 2025 at 6:08 AM
    BLtheP
    Plano, TX
    2Lo would be perfectly fine for what you are needing.
  15. May 26, 2025 at 6:18 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    This sounds like a situation where using 4LO would be no issue.
  16. May 26, 2025 at 6:49 AM
    bbal
    Appreciate the input. I’ll use it.
  17. May 26, 2025 at 7:20 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    4lo had worked fine for me every time I pulled the boat up a ramp or parked it im the yard. I’ve never felt a need for 2lo, but I understand why one might find it useful.
    It’s ok to use 4lo for short distances on pavement if you don’t need to turn sharply.
    I also have never had trouble backing my 2300 lb boat on leveling surfaces in 2hi. It just takes some gentle clutch work. However, I can imagine some situations where I would be challenged.
    The torque to the ground is the same regardless of 2hi or 4hi as long as the driver controls the throttle and clutch correctly. Only The maximum possible torque possible is higher in 2lo. Regardless, I’m skeptical one could grenade the rear axle using 2lo to move a trailer. The forces are likely far below those used in an off-road situation.
