What is the widest tire that can go on a 17x7.5 rim?
Discussion in 'Wheels & Tires' started by First Tacoma 2011, Feb 13, 2012.
  1. Feb 13, 2012 at 5:02 AM
    First Tacoma 2011
    First Tacoma 2011 [OP] Well-Known Member
    Bruce
    Maryland
    2011 TRD Sport Tacoma
    Toytec 3'' Lift 2'' AAL Bed Light Mod Westin Step Sides
    After some countless hours of surfing the net I am still without an answer to my question. I just ordered my 3’’ lift from toytec and now I looking for tires. I wanted to keep my stock rims which are 17x7.5, I would like to get a 33’’ tire that would fit these. From what I have seen some people say a 285 will be fine and some say you will wear the tire unevenly.
    Does anyone know what’s the widest tire that can go these rims?
  2. Feb 13, 2012 at 5:24 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Depends on the manufacturer.
    Just look up the tires you want and then read their specifications.
    It's very simple.
    I'm not going to assume what tire you want then check and see if they fit. That's for you to do.
  3. Feb 13, 2012 at 5:43 AM
    Namyo
    Namyo -
    This ^^
    Because tires have flexible sidewalls, a single tire size will fit on a variety of rim widths. A tire's rim width range identifies the narrowest to the widest rim widths that the tire is designed to fit.
    When looking at a tires spec it will say what range of width it will work on..
