What is this noise???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adriancast, Sep 13, 2013.
  1. Sep 13, 2013 at 8:39 PM
    adriancast
    adriancast [OP] Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
  2. Sep 13, 2013 at 8:40 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    It says, "the video is private".
  3. Sep 13, 2013 at 8:42 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    I can't watch the video for some reason but the pic looks to be where you front coilover connects to your lower control arm. Is it a squeaking noise? And do you have after market UCA's?
  4. Sep 13, 2013 at 8:54 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Might just be the angle of the pic but is your sway bar rubbing the tie rod?
  5. Sep 13, 2013 at 8:58 PM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    '07 base taco. Sold. Now Taco-less
    Factory cruise added, wood storage box in bed, wood center console/armrest, charcoal air filter delete.
    Almost definite it's not the heim. I'd check skid plates & heat shields. Have someone rev it while you walk around and climb under 'till you find it.
  6. Sep 13, 2013 at 9:09 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    1. Are your rear shocks OEM? There's a bushing sleeve on the OEM shocks that, if not transferred over to the new shocks, can result in squeaking.
    2. You have installed the sway bar relocation plates, right?
    3. How much clearance do you have between the tire and the UCA?
  7. Sep 13, 2013 at 9:23 PM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    In the video it looks like you're in neutral just revving so the shock is stationary and under load so I can't see it making that noise. Have you tried having someone else rev it and try to pinpoint the sound?
  8. Sep 13, 2013 at 9:25 PM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    Could be a bad catalytic, tried banging the exhaust to see if it's somewhere in the system?
  9. Sep 13, 2013 at 9:44 PM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    I woulda sworn that video was just a rev in neutral so I guess my speakers or ears are off this evening.....ohh, I do have a shitty ass cold or flu righ now, duh.
  10. Sep 14, 2013 at 11:23 AM
    KenLyns
    Belly of the Beast
    The spherical bearing looks to be positioned correctly. However, depending on the age, the bearing's teflon liner may be worn. Do you get the noise if you simply bounce the front passenger corner of the truck up and down?
    Could also be worn LCA bushing: http://www.tacomaworld.com/forum/2nd-gen-tacomas/193626-lca-moves-its-mounts.html
  11. Sep 14, 2013 at 12:57 PM
    KenLyns
    Belly of the Beast
    Both the LCA bushing and the coilover bottom heim get exercised when you go on the curb.
  12. Sep 14, 2013 at 6:09 PM
    pinktaco808
    pinktaco808 Hot Steppa
    leave stock?
  13. Sep 15, 2013 at 10:09 AM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    I'd expect the shock mount to make noise more from bumps than acceleration, tho you should rearrange it with spacers to center the shock anyway. The frequency of the noise tells me light metal not thick suspension stuff. Exhaust sys, skid plates, and any aftermarket stuff. Possibly body panels if they're damaged. There's also the chance of a rock sitting on/in a skidplate, heatshield, ect buzzing with the right engine harmonics, been there many times.
  14. Sep 29, 2013 at 8:04 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Also check your motor mount brackets at the frame rails if thats not the cure.
  15. Sep 29, 2013 at 12:57 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    In that case, I'd be retorquing the LCA bolts to make sure the noise wasn't caused by movement between the steel bushing sleeve / alignment cam / and the frame bracket. The rubber bushing itself should not need any lubricant . An easy check to possibly avoid larger problems down the road (or trail.:cool:).
