What is this tube called? (Pic included)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Canyon Jeff, Oct 11, 2014.
  1. Oct 11, 2014 at 6:15 PM
    Canyon Jeff
    Canyon Jeff [OP] Well-Known Member
    Jeff
    Southeast Utah
    98 Tacoma V6 3.4, TRD 4x4 5-speed 100k miles
    Does anyone know what the narrow black tube in this photo is called? And what does it do?? I'm not talking about the electrical running in the back of the photo, but the tube in front of it. It runs from a metal "nipple" on the side if the 4WD shifter, to another metal nipple on the side of the other shifter. The tube is broken where it connects to one of the nipples, and it's leaking small amounts of gear oil. I want to replace it but I don't know what it's called so I don't know how to shop for it...
    Thanks!
  2. Oct 11, 2014 at 6:24 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    its a vent for the transmission and transfer case.
  3. Oct 11, 2014 at 6:32 PM
    Canyon Jeff
    Jeff
    Southeast Utah
    Interesting. If it's a vent, then why is the tube closed? Where does it vent to?
  4. Oct 11, 2014 at 6:33 PM
    Canyon Jeff
    Jeff
    Southeast Utah
    Is it a vent for the t-case INTO the trans, and then out the Trans breather valve?
  5. Oct 11, 2014 at 6:45 PM
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    Could be off base here. I think it is like the differential breathers. Not air tight. Allows hot air to escape.
  6. Oct 11, 2014 at 6:54 PM
    Canyon Jeff
    Jeff
    Southeast Utah
    Thanks for the info. I have a feeling they're not going to have one of these at autozone...
  7. Oct 11, 2014 at 7:59 PM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    No but just get generic hose that's around the same ID and it'll work fine just wont have the prebent turns in it but they don't matter so long as air can vent through it.
  8. Oct 11, 2014 at 8:03 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    This. Anything with the proper inner diameter will work.
    I think it vents into the adapter free space which is pretty protected.
  9. Oct 12, 2014 at 7:42 AM
    primer
    T
    OK
  10. Oct 12, 2014 at 4:05 PM
    Canyon Jeff
    Jeff
    Southeast Utah
    Can anyone explain to me how this thing works? I've seen the other threads on extending breather clearance, and I get how breather valves function. But where is the valve/vent on this thing? It's just a line connecting the Trans and t-case...
    Primer says "it's not air tight, allows air to escape". Well, if that's the case, then buying generic hose won't work, will it? I guess I'm just confused about the function, cuz this thing isnt really a valve. How does it work? If it serves the function of releasing pressure or hot air, then why is it set up differently from all the other valves on the Trans and diffs?
    Thanks for clarifying!
  11. Oct 13, 2014 at 6:58 PM
    primer
    T
    OK
