what is this?
Discussion in '1st Gen. Tacomas (1995-2004)' started by yamahahauler, Apr 30, 2012.
  1. Apr 30, 2012 at 10:38 AM
    yamahahauler
    yamahahauler [OP] Well-Known Member
    tyler
    Culver
    98 white
    bilsteins all around with emu springs.
    Im pretty sure this is a strut but im not totally for sure. Im working on taking off my TM 6 inch lift to put on new shocks/springs and leafs
  2. Apr 30, 2012 at 10:40 AM
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    Looks like some kind of effed up UCA..
  3. Apr 30, 2012 at 10:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats a "Second Strut" on teh TM kit. It takes the place of the UCA.
  4. Apr 30, 2012 at 10:49 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    such a strange design
  5. Apr 30, 2012 at 10:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Interestingly enough......There are many vehicles that use the "Second Strut" design. No new vehicles mind you......but some older ones.
  6. Apr 30, 2012 at 11:11 AM
    yamahahauler
    tyler
    Culver
    98 white
    im taking the TM lift off what do i do to get the stock set up? minus the new shocks and springs im getting do i need to buy new upper control arms?
    should i spend the money to buy new ones? or go to a junk yard and try to find one
  7. Apr 30, 2012 at 12:04 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    if you don't have stock UCA's already you'll need to get some. I imagine junkyard UCA's would be fine as long as they weren't damaged.
  8. Apr 30, 2012 at 12:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You will also need a new crossmember for the front diff. IIRC, the TM kit cuts the OEM on out.
  9. Apr 30, 2012 at 1:31 PM
    yamahahauler
    tyler
    Culver
    98 white
    they cut them out? i thought they just bolted on the new system below the existing one
  10. Apr 30, 2012 at 1:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The ones Ive seen had them cut out. Unless you have a Prerunner. Then they just mount the new one over the old.
  11. Apr 30, 2012 at 1:52 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That looks like a pile of shit lift.
  12. Apr 30, 2012 at 1:58 PM
    yamahahauler
    tyler
    Culver
    98 white
    pretty much is thats why im going to change it soon
  13. Apr 30, 2012 at 2:12 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    its going to be a lot of work.
  14. May 1, 2012 at 1:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
