What is TSB leaf springs + aal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parrithead, Feb 14, 2011.
  1. Feb 14, 2011 at 6:13 AM
    parrithead
    parrithead [OP] Well-Known Member
    Shane
    Maryland
    What is TSB leaf springs + aal? Sorry new to the forum?
  2. Feb 14, 2011 at 6:17 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    TSB is new 4 leaf packs that toyota puts on if you complain about the lack of payload performance on the factory 3 leaf packs. This is free through a TSB at the dealership. AAL= add a leaf, adding an aftermarket leaf to each side to lift and stiffen the rear end in your own dime. I have both and together you can expect 2-3 inches of rear lift depending on which AAL you go with. I purchased a wheelers AAL set. Hope this helps.
  3. Feb 14, 2011 at 6:24 AM
    parrithead
    Shane
    Maryland
    Ok thanks. I assume Toyota will onle replace the leak packs under warranty?
  4. Feb 14, 2011 at 6:48 AM
    sgrappone
    sgrappone Well-Known Member
    Scott
    Moncks Corner, SC
    04 AC 4X4
    Yes....Only under warranty. If your looking for more affordable lift and your out of warranty there is the option of a 2"aal. If your still under warranty and get the tsb completed then you have the option of the 1.5"aal. Hope this helps.
  5. Jan 31, 2014 at 10:04 PM
    asuperhero
    asuperhero Member
    Robert
    Mill Creek, WA
    '14 TRD Sport
    None yet
    Wait what? So even for 2014's I can get this tsb? How long does it take?
  6. Feb 1, 2014 at 4:15 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Tsb is not something manufacturer feel like it's not something they have to fix. They only fix it when people complain about the part.
    You have to realize most trucks now a days are not bought to be used as a truck. People don't haul shit around no more. So they are made to drive like cars. Made for comfort not usability.Toyota may never fox this "problem"
  7. Feb 1, 2014 at 4:39 AM
    jaymoussy
    jaymoussy Well-Known Member
    Eastern MA, US
    '12 AC Base 2.7l 4a
    ... and what is the best approach to convince local service dept to accept the TSB work?
    Drive up with 50 bags of potting soil in the bed, and show the tech?
    "Fresh" used 2012 here. I thought I was buying a truck...
  8. Feb 1, 2014 at 4:45 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    As along as your in the 3 year 30k miles. Just go in and tell them the rear leafs sag under load and you feel unsafe
  9. Feb 1, 2014 at 4:55 AM
    slowmachine
    slowmachine Well-Known Member
    Alton, NH
    36,000 miles is the limit. Mine were done at 34,500, thanks to this informative forum.
  10. Feb 1, 2014 at 5:03 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Lol i was close. I did mine at 2 weeks and 3 thousand miles
  11. Feb 1, 2014 at 5:19 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    The 2014 already has the newest/best leafs on it......pretty sure you're out of luck. How many leafs do you have? 3 + overload or 2 + overload? I've read on here that ALL 2014s have the 3 + overload now which would be the TSB leafs. The TSB is for older trucks.....maybe up to 2012.
  12. Feb 1, 2014 at 6:26 AM
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    my 2013 sport has 3 plus the overload.
  13. Feb 1, 2014 at 11:46 AM
    jaymoussy
    Eastern MA, US
    '12 AC Base 2.7l 4a
    Are there also some ride improvements with the TSB done, i.e., less bed bounce (when empty), better handling?
  14. Feb 1, 2014 at 12:02 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Count the number of main leafs you have. Those are the longer leafs. There should be 3 of them. Your overload leaf is short and upside down. There is one of them. If you have this, a 4 leaf pack, you don't need a tsb leaf instal by the dealer. If they begin to sag when you put miles on the truck you may need to install an aal to stiffen things up again. Your decision though.
  15. Jun 9, 2014 at 10:34 AM
    jaymoussy
    Eastern MA, US
    '12 AC Base 2.7l 4a
    As iI am approaching the end of my warranty, and the end of the window to get the 2.5 to 3.5 leaf change, I am reviving the thread to ask:
    (3.5 = 3 plus shorter overload leaf)
    Did anybody REGRET getting the 3-leaf pack?
    Handling changes?
  16. Jun 9, 2014 at 2:56 PM
    bjboucher
    Brad
    San Antonio, Texas
    The TSB for weak load carrying doesn't apply to 2012s. Good luck trying to get it. If you have driveline vibrations, that might be your best bet. Simply complaining about load carrying doesn't apply to 2012 and higher. The driveline vibration TSB includes new leafs.
  17. Jun 10, 2014 at 6:58 AM
    jaymoussy
    Eastern MA, US
    '12 AC Base 2.7l 4a
    Well.. that's very unfortunate, disappointing, and not very good design, perhaps!
    Now, what amount of deflection is "acceptable" on my stock 2-leaf+helper?
    Best way to measure actual truck height differential under load?
    I am quite capable of picking up, say 600 lbs of compost, have it weighted at the dump, and drive to my local dealer, who sold me a TRUCK.
  18. Jun 25, 2014 at 11:18 AM
    Tj0hn
    Tj0hn Well-Known Member
    Arkansas
    Stock TRD Sport 4x4
    Good to know! I'm safe.
  19. Jun 25, 2014 at 11:32 AM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    I believe the 2014 Off Roads still only had 2+1 until October of last year (sports had 3+1). Bought mine in December and it has the 3+1.
  20. Jun 25, 2014 at 11:33 AM
    KMitch
    Colorado
    Also, there is another tsb that covers the driveline vibes which is an entirely new leaf pack.
