What is your lighting wiring setup?
Discussion in 'Lighting' started by NoMallCrawlTaco, Feb 17, 2011.
  1. Feb 17, 2011 at 6:36 AM
    NoMallCrawlTaco
    NoMallCrawlTaco [OP] © "HELL FUCK YEAH!" © COPYRIGHT FOR MY PROTECTION!
    Arizona
    4" Camburgs Icon AAL 3 Pac BLHM Tacoshi Grill More to come...
    I am putting in my Hellas.
    I am looking for a good wiring configuration...
    What do you have and how did you wire your's up?
    I would like mine to be able to come on but not be a drain on the battery.
    Like the stock standard setup.
    I could really use some tech help. I don't like the tap in on the battery shit that come with the lights. I want this BULLIT proof.
    If you can post a easy to follow schematic that would be awesome...
  2. Feb 17, 2011 at 8:16 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    Not a whole lot of options man.
    You either need to tap onto the battery or onto a fuse block connected to battery.
    Whatever you do use a relay.
  3. Feb 18, 2011 at 4:42 AM
    NoMallCrawlTaco
    Arizona
    What do you mean use a relay?
    And how would one set up to say tap into the the fog lamps? I have them so they come on anytime with the FOG LIGHT MOD from here. Might be nice to just tap into the fog lights and have my Hella Grill lights come on with the fogs.
    Thanks for your help, I didn't think anyone was going to respond.
  4. Feb 18, 2011 at 4:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You'd probably overload that circuit. You can use the fogs as the trigger (using a relay and a cab switch), but I wouldn't draw the power off the fog light circuit.
    I've got a set of PIAA's set up so there's a switch in the cab and a relay under the hood. The switch has to be on and the headlights (high beams) have to be on to switch the relay on and power the lights. A test light is your friend when wiring lights up. Also, just a recommendation, I always solder and heat shrink all connections, just wire tying or crimping them and wrapping in electrical tape is not the correct way to connect wires.
  5. Feb 18, 2011 at 5:07 AM
    NoMallCrawlTaco
    Arizona
    do you have a wiring diagram by chance...
  6. Feb 18, 2011 at 5:22 AM
    Pugga
    Massachusetts
  7. Feb 18, 2011 at 5:24 AM
    NoMallCrawlTaco
    Arizona
    Thank you sir.
    This is one of the main reasons I love TW...
    Toyota Folks helping one another.
    Have a GREAT day!
  8. Feb 18, 2011 at 5:26 AM
    Pugga
    Massachusetts
    :thumbsup:
    Happy to help, let me know if you have any other questions. Unfortunately, wiring is hard to talk about over the internet but I can get pictures once I'm back home.
