What is your oilChange routine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by STacoL, Oct 16, 2024.
  1. Oct 16, 2024 at 9:16 AM
    STacoL
    STacoL [OP] Active Member
    Brandon
    2006 PreRunner
    Stock
    I’ve got about 220k on my 1GR-FE and like to change my oil every 6000.
    I purchase filters from a local Toyota dealership and buy the 5Q/1G jugs of M1 full synthetic at Walmart. You just can’t buy oil anywhere else for cheaper. I think they usually run about $25 a pop and I alternate between high mileage and regular. It’s great that exactly what the engine calls for after a nice drain.
    I also like to pour a can or half a can of seafoam In a few hundred miles before I plan on changing the oil.
    hbu?
  2. Oct 16, 2024 at 9:21 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I don’t waste my money on seafoam just to have a smokeshow for fun.
    Mobil1 full synthetic (not high mileage) 5W30 5qt jugs mixed with a case of individual quarts to make up the half liter to fill.
    OEM filter.
    Change every 5-6k. Blackstone analyses each change which they keep telling me I can run the oil to 10k because it still has good numbers, but since I’m supercharged and run it hard occasionally and drive it 1-2 times a month I want to track how the internals are doing.
    I have zero oil consumption. Only 95k miles.
    kidthatsirish and STacoL[OP] like this.
  3. Oct 16, 2024 at 9:29 AM
    STacoL
    Brandon
    2006 PreRunner
    Stock
    if you put the seafoam in the crankcase it doesn’t smoke. It just helps remove sludge and other deposits that drain with the oil.
    I’ve never put it in the intake. I feel having port fuel injection and using quality gasoline is all that’s needed.
    jackn7 and a400ryan like this.
  4. Oct 16, 2024 at 10:00 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  5. Oct 16, 2024 at 10:02 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Fram filter from Walmart. I used Mobil 1 for the 1st 200,000 miles but figure it's a waste of money. I buy my oil now from Costco. A box contains two 5 qt jugs. Price used to be $25 but it's up to $38 now. But that's still under $18 for an oil change.
    For the 1st 9 years and 180,000 miles I did 10,000 mile oil changes which worked out to about every 6 months.. The last 70,000 miles have been as a 3rd vehicle and I'm driving less than 10,000 miles/year now so I now change every 6 months and don't consider miles.
    Truck is over 250,000 miles now. It is usually about 1/2 qt low when I change the oil. In 17 years I've never added oil between changes.
  6. Oct 16, 2024 at 10:12 AM
    TacoTuesday1
    FL
    Whatever synthetic oil. $5 dealer filter. Every 5k.
    I don’t use seafoam. Because seafoam is shit.
    I don’t flush before every oil change. This is unnecessary, excessive, and may even cause harm. It is wasteful and does not need it.
    69 Jim, a400ryan and Sprig like this.
  7. Oct 16, 2024 at 10:22 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Why alternate between high mileage and regular?
    And as far as sea foam , I have never put it in any of the numerous cars I’ve owned. I personally don’t see the point. But if it does something for you, go for it.
  8. Oct 16, 2024 at 10:25 AM
    Sprig
    Ken
    Please Lord don’t let this become another useless oil thread
  9. Oct 16, 2024 at 10:31 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Your prayers shall not be answered:
  10. Oct 16, 2024 at 10:34 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Every 6k. Don’t waste my money on seafoam or Blackstone. Change oil, drive and enjoy repeat till 500k. Pretty simple.
    MSN88longbed likes this.
  11. Oct 16, 2024 at 10:36 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I get the 6-qt 5/30 Havoline syn oil that comes in a box (at Walmart). I put in all 6 qts and don't worry about the half qt fill. I also use the larger oil filters, like Wix 51068 or 51085. Change oil every 7K-8K. No Seafoam for me. I put a large bottle of Techron about every other oil change.
    STacoL[OP] likes this.
  12. Oct 16, 2024 at 11:03 AM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    Full Syn Oil at Costco, Kirkland or M1 depending on price. Toyota OEM filters, bought bulk on Amazon. Every time the light comes on, or the first decent Saturday thereafter, so between 5k or 6.5K depending on what's going on. Fumoto valve since day one (second Tacoma so equipped). Love the filter up top. As good a reason as any to keep this truck going....oil changes are too easy!
    164K and never burn a drop.
    jackn7 likes this.
  13. Oct 16, 2024 at 11:42 AM
    Rogue Hunter
    Rogue Hunter Active Member
    2010 Silver Access Tacoma 4x4
    Forgive me to piggyback on your thread (lol). I also have the 1GR-FE engine...I goofed and put in 5w-20 instead of the 5w-30. I don't tow heavy loads or drive at higher speeds...is there any real harm or should I replace asap???
    I always change oil at 5000 miles.
  14. Oct 16, 2024 at 11:45 AM
    Sprig
    Ken
    Blinker fluid every 25,000 miles.
    MSN88longbed, jackn7, szidls and 2 others like this.
  15. Oct 16, 2024 at 11:46 AM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    Every 5K: I change the 5W-30 synthetic oil and 90915-YZZD3 OEM filter (buy both at Walmart), I rotate the four tires, and I inject grease into the 5 Zerk fittings on the driveshafts until grease comes out of each bearing.
    The engine never runs low on oil between changes, and does not burn any oil. Currently at 134K miles.
    taco912 and STacoL[OP] like this.
  16. Oct 16, 2024 at 12:00 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Dealership put 0w20 in my truck quite a few changes ago. Its fine. Just run 5k and change it back.
    I have 3qts of 10w30 and 3qts of 0W20 i am going to use up on my next change. I don't know if I am being cheap or just trying to clean out my garage.
  17. Oct 16, 2024 at 12:07 PM
    spitdog
    I recycle my oil from my truck through my lawn mower. It’s like solving 2 problems with one solution.
    69 Jim, TacoBandido, jackn7 and 4 others like this.
  18. Oct 16, 2024 at 12:46 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    5K Full Syn. Usually Mobil 1 but will use Kirkland. 5w-30. OEM filter.
  19. Oct 16, 2024 at 12:51 PM
    StihlToyota
    StihlToyota Well-Known Member
    Mark
    No. Idaho panhandle
    2001 SR5 4x4 2.7L, 2015 DBCB Sport
    Every 3-5K miles or six months. Full syn(Penzoil Platinum, Mobil 1, Castrol Edge) with either a Purolator Boss, Wix XP or Mobil 1 filter
    O'DubhGhaill and STacoL[OP] like this.
  20. Oct 16, 2024 at 1:30 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    2012 Tacoma 4.0. Bought it with 129,000km (80,000 miles). I use 10w30 conventional oil and Toyota oem filter. Every 5,000kms (3,100 miles) because during the first bunch of oil changes the old oil came out dirtier than l thought it should be.
    I had no information on the maintenance routine of the Tacoma, prior to me taking ownership.
    The old oil appearance has improved immensely over the last 70,000kms (43,000miles) of the quicker oil changes.
    I just had to add to this oil thread!!:D:thumbsup:
    WOODY2, jackn7 and STacoL[OP] like this.
