What is your onboard air compressor?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billthehiker, Mar 6, 2018.
  1. Mar 6, 2018 at 1:45 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Could you link the kit you used or what you used if DIY? I have been trying to rig up this exact setup after an interesting discovery that a tacoma > standard jump lead lengths when pulled into a parking spot.
  2. Mar 6, 2018 at 1:49 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Used these connectors:
    https://www.amazon.com/gp/product/B007JMTS14/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    With this cable routed under cab
    https://www.amazon.com/gp/product/B00KD2756W/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    I keep it disconnected @ battery until I need it as I didn't want a full time 2 gauge hot wire under the truck. Might eventually put a marine battery disconnect switch in but for now just connecting the cable when I need it works fine.
  3. Mar 6, 2018 at 2:00 PM
    Pigpen
    Dan
    Northwest Montana
    I used the warn kits. It's probably more expensive, but everything you need is in the kits and already assembled. I have both kits to run front and rear. I have both kits hooked up to the solenoid, so I can power them both off when not in use.
    https://www.summitracing.com/parts/wrn-32966/overview/
    https://www.summitracing.com/parts/wrn-36080/overview/
    llamasmurf likes this.
  4. Mar 6, 2018 at 2:03 PM
    Gunshot-6A
    Conner
    Everett, WA
  5. Mar 6, 2018 at 4:07 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Pigpen[QUOTED] likes this.
  6. Mar 6, 2018 at 8:00 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    I have a viair 400p automatic. It's pretty fast for a portable air compressor and 35" tires, I like it. I can hook it up the terminals, put the compressor down in front of my bumper and fill all 4 tires. The auto version also turns off after the air line is up to 150psi so it keeps the duty cycle down as I'm walking to another tire. The duty cycle is 33% which is about 20mins(only takes about 3mins a tire from trail pressure to street). I got this one since it was cheaper than the ARB portable one, I don't need on board air for lockers and I can toss it in another vehicle when needed.
    https://www.amazon.com/VIAIR-400P-A...0394284&sr=sr-1&keywords=viair+400p+automatic
    llamasmurf and lo2hi like this.
  7. Mar 23, 2018 at 10:07 AM
    Jeff@ExE
    Jeff@ExE Well-Known Member
    Jeff
    2016 Toyota Tacoma
    A Lot
    It could easily still mount in the bed, you would simply need to run an extended air line and remote port. Makes for a nice setup and saves your underhood for other accessories.
  8. Jul 10, 2018 at 7:35 AM
    Frito
    Frito Well-Known Member
    Seeking Ideas for some clean and efficient plumbing..... I too have a Viar.
    What I would like to do is connect to Firestone Airbags in the rear and also have a chuck available.
    Is this accomplished by some kind of manifold ?
    TIA
  9. Jul 10, 2018 at 10:20 AM
    musher
    musher Well-Known Member
    Alabama(born) >(the world)>Alaska(now)
    2017 Tacoma
    I'd rather not think of all the $ spent :(
    I don't have that setup up but when I planned on doing bags, I was going to run the fill to the bumper and put a tank under the bed. Then run a quick connect to the bumper. The goal was to have air at the bumper. I went a different route and got the compressor and mount from Jeff@ExE and replaced the springs. So far I'm happy with the compressor without a tank.
    I've seen others here with that same set up. Curious to see what you come up with @Frito
    Frito likes this.
  10. Jul 10, 2018 at 4:07 PM
    Frito
    On the hunt.... I'll keep you posted !
    Thanks :thumbsup:
