What kind of alarm system do I have?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bicklebok, May 31, 2011.
  1. May 31, 2011 at 12:25 PM
    bicklebok
    bicklebok [OP] Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    I have a 2000 model Tacoma with a security system. I even have the manual that came with it, but it doesnt have any info on who made it. The manual just says Theft Deterrent System (TDS). It has a little red light with built in switch to the left of the steering wheel. The system itself is mounted near the left kick panel tie strapped on to a wiring harness.
    I did some research on this but Im still lost. I just want to get another remote for it, and I dont want to buy one off ebay if it wont program. the ebay seller says it works with factory alarms. I dont think this is a factory alarm.
    I know very little about keyless entry alarm systems!
  2. May 31, 2011 at 12:55 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Pics would help (of the remote as well). Also, if you still have the original remote, look from some numbers on the back and try googling them. You can look under the hood for other components and see if the name is on them as well.
  3. May 31, 2011 at 1:18 PM
    bicklebok
    Ronnie
    Montgomery, AL
    The numbers on the back of the remote are so worn I cant read them. I will take a pic of it when I get home tonight.
    I dont think there's anything under the hood. I have looked pretty good.
    A programmable remote from ebay is $20. I may just take a chance on it.
  4. May 31, 2011 at 1:23 PM
    Triangleacre1
    Triangleacre1 Well-Known Member
    Dustin
    Delaware
    01 Tacoma SR5
  5. May 31, 2011 at 2:31 PM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
  6. May 31, 2011 at 4:01 PM
    bicklebok
    Ronnie
    Montgomery, AL
  7. May 31, 2011 at 4:02 PM
    bicklebok
    Ronnie
    Montgomery, AL
  8. Jun 1, 2011 at 5:07 AM
    Killer
    Mobile, Al.
    My guess is that you have an aftermarket alarm. That FOB does not look like any Toyota FOB that I have ever seen.
  9. Jun 1, 2011 at 8:11 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Pull the main controller unit and check for marks / tags / labels ...
    That's definitely not a Toyota accessory alarm system fob.
  10. Jun 1, 2011 at 8:20 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yes. The main control box should be under your dash by your steering column. Should be a black box no bigger than 6" by 4". Look for some serial numbers, etc... on that.
  11. Jun 1, 2011 at 8:48 AM
    bicklebok
    Ronnie
    Montgomery, AL
    It is located there. I found serial numbers but havent been able to do anything with them since I dont know the brand of system. Today Im going to cut the cable ties loose and look on the back of the box to see if it gives me any additional info. I saw on a website while searching that there is additional information on the back side of some boxes. So far, even with the literature that came with the alarm, I cant find the manufacturer info.
  12. Jun 1, 2011 at 8:57 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    If it is the same alarm that I have in my truck (I have the little red button as well), then it is not going to have any markings on it other than the serial numbers. I literally pulled my dash apart and pulled every box out that was connected in the alarm harness and there is no brand name on it. From the research I have done on the system, they only put these alarms in trucks made in the southern states and it is made by Audiovox or something like that. I have been meaning to try to order a fob from the place posted above but have never got around to it. My truck didn't even come with a key fob so my alarm is useless until I get around to ordering one.
    Edit: Here is the thread I made a few months ago. It has a few pics of the boxes that were under my dash.
    Click Here
  13. Jun 1, 2011 at 8:59 AM
    bama trd
    bama trd Well-Known Member
    Alabama
    2007 Silver Tacoma TRD Off Road
    Painted Grill with painted Land Cruiser emblem,Tinted Windows, BF Goodrich AT 275/70/17's on 4 Runner SR5 Rims, Bilstein 5100 front and Rear, debadged, fog light on anytime mod,
    I had the same deal with a Z71 that i owned last year. I followed the wires to the small black box ( up in the dash beside the steering collum) broke the zip ties and found a name on it. You can also call a stereo/alarm store and tell them info from the unit.
  14. Jun 1, 2011 at 9:23 AM
    bicklebok
    Ronnie
    Montgomery, AL
    Thanks everyone! I will keep you posted.
    Honestly, I would love to just kill the alarm, but from what I have read, it will disable the ignition unless I can figure out how to hook the wiring back the way it was from the factory.
  15. Jun 1, 2011 at 9:33 AM
    bama trd
    Alabama
    I DID kill mine and took the thing out , I saw how it was wired and cut maybe 2-3 wires and reconnected with the factory wiring. You could look at it and tell exactly how the insaller had hooked it up. Good Luck
  16. Jun 1, 2011 at 9:43 AM
    bicklebok
    Ronnie
    Montgomery, AL
    Hey bama trd! what part of Bama are you in?
    Im hoping when I look under the dash it will be obvoius the way the factory wiring should be. I sure hope so!
  17. Jun 1, 2011 at 10:57 AM
    Rusty White Taco
    Rusty White Taco Active Member
    Central Coast, CA
    04 4x4 Xtra Cab TRD Offroad SR5
    Debadged, Front 5100s at 2.5, 1" rear shackle lift, 5125s in the rear, trimmed exhaust pipe
    If my memory serves me correctly, TDS alarms are just dealer-installed alarms made by Audiovox. Search for TDS, Audiovox, or Prestige alarm remotes (they also made the Prestige line for Toyotas). Good luck!
  18. Jun 1, 2011 at 11:53 AM
    bicklebok
    Ronnie
    Montgomery, AL
    Thanks! Youre on to something! i didnt realize TDS was a trademark name until I did a search.
  19. Jun 2, 2011 at 4:04 AM
    bicklebok
    Ronnie
    Montgomery, AL
    Update: I ordered a used FOB from ebay last night. It should be the right one. I could get enough FCC ID numbers off the old FOB(they were worn away from being in the PO's pocket) to match it to the FOB I ordered.
    When it gets here, will see if I can get it programmed.
