What kind of alarm?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eordonez, Apr 16, 2008.
  1. Apr 16, 2008 at 11:21 AM
    eordonez
    eordonez [OP] Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    Ok, maybe this is stupid but i don't care, i found this Toyota security alarm/module/sensor/dontknowwhatitis/thing near the mirror adjusting controls, can anyone tell me what does it do, what kind of alarm system is, who else got this? Thanks
  2. Apr 16, 2008 at 11:29 AM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    Hmmm interesting. I have never seen that before. Does it turn the alarm system off maybe?
  3. Apr 16, 2008 at 11:33 AM
    eordonez
    Ed
    Chihuahua, Mexico
    Its not a button, its just a lil red light and like a very small speaker, the light flashes when the truck is closed, also, i found in the rear of the truck a blind module (i dont know if i should call it that) but its that plastic piece next to the security module, seems to me like they installed a factory alarm and the installer forgot to throw away the plastic piece....
  4. Apr 16, 2008 at 12:05 PM
    redtoytaco
    redtoytaco Well-Known Member
    So Cal
    06 PreRunner Dcab LB SR5
    That is part of the factory alarm. It's a alarm status indicator as well as a microphone that is used as a break glass sensor. If you arm your alarm and lightly tap the driver side window it should trip the alarm.
  5. Apr 16, 2008 at 12:27 PM
    eordonez
    Ed
    Chihuahua, Mexico
    Does this means that i have more than just the key less entry? maybe rs3200?
  6. Apr 16, 2008 at 2:20 PM
    eordonez
    Ed
    Chihuahua, Mexico
    I'm trying to figure this out, i cant understand why i have that sensor/light, if i don't have the rs3200 (not that i know), i don't think they install it as a factory option here in Mexico..... :confused:
  7. Apr 16, 2008 at 5:18 PM
    redtoytaco
    So Cal
    Does the light flashes after about 60 seconds after you lock the doors and the key is not in the ignition? If it does try tapping the center of the driver side window glass with the tip of your key. Be careful not to do it to hard you may cause the window to break depending on the force you apply. If your horn starts wailing after tapping then you have a factory alarm. It is VIP-3200 plus is the only factory installed alarm for the 2005+ tacoma.
  8. Apr 16, 2008 at 5:37 PM
    eordonez
    Ed
    Chihuahua, Mexico
    Is there any other way??? I found this pdf http://www.toyotapart.com/installation/08586-04840.pdf
    I Checked all the accessory function checks in page 17, all of them worked, i didnt wanted to try the glass tap thing coz i might break the glass.... what do you think??
  9. Apr 16, 2008 at 9:52 PM
    redtoytaco
    So Cal
    If you follow everything in the instruction in verifying the functions with the exception of tapping the glass it is all up to you. I was skeptical when i got my truck but by just lightly tapping the window the alarm did trip for me.
  10. Apr 16, 2008 at 10:23 PM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
    Its probably some dealership add-on. It could be any brand they choose. Probably not a name brand. They make money off that stuff.
  11. Apr 17, 2008 at 9:54 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    That's the RS-3200 alarm I think. If all other functions work and you are not sure about tapping the glass roll the window down and then arm it and clap your hands in front of the speaker.
  12. Apr 17, 2008 at 10:32 AM
    eordonez
    Ed
    Chihuahua, Mexico
    That sure did trigger the alarm, rolled window down, armed and clapped, began to beep.... thanks for the advice.... if is the rs3200 than that means it can be programmed right???
  13. Apr 17, 2008 at 1:21 PM
    maverick491
    South Jersey
    Yep, if it's the rs3200 you should be able to program it. I believe the instructions for the programing are posted in 007tacoma's photo gallery.
  14. Apr 17, 2008 at 2:08 PM
    eordonez
    Ed
    Chihuahua, Mexico
    I tried that, didn't worked, i was trying to program the auto lock feature.... but those steps don't work
