What kind of coolant should i use??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WARGASM723, Aug 18, 2010.
  1. Nov 5, 2013 at 7:40 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    What?
    ^ this
    We are arguing that saving $30-40 every 3-5 years actually makes it ok that the coolant might not be compatible with your $multi-thousand vehicle, and it may not last as long as the OEM coolant. Seriously? Just use the Toyota stuff and move on.
  2. Sep 25, 2015 at 8:03 AM
    RAV
    RAV Member
    Bob
    Metrowest Massachusetts
    2015 Tacoma TRD Sport Double Cab 4x4
    NRA Life Member American Tonneau Cover Pop&Lock Traxion Tailgate Ladder 5-100
    Just looking to buy some of this (“Toyota Super Long Life Coolant”) to keep on hand to do top offs.
    Note the following from the "Toyota 2015 Tacoma Warranty and Maintenance Guide":
    In the schedule section, coolant is to be changed at 100,000 miles or 120 months. There is a caveat on this at the end of the book on page 71 of the maintenance log:
    Your Toyota is equipped with Genuine Toyota Super Long-Life Coolant. The replacement intervals for engine coolant recommended in this booklet are based on replacement with Genuine Toyota Super Long-Life Coolant or similar high-quality non-silicate, non-amine, non-borate ethylene-glycol coolant with long-life hybrid organic acid technology (i.e., a combination of low phosphates and organic acids). If another type of ethylene-glycol coolant is used, replacement intervals may be different.​
    I'm probably going to bite the bullet on this one and get a gallon of the factory item (and keep the receipt on hand for records). I did this with my Dodge Caravan for transmission fluid when they had issues with non EOM fluids.
    What are the thoughts of this group?
  3. Sep 25, 2015 at 2:55 PM
    1owner05
    1owner05 Well-Known Member
    Long Island
    05 black
    Dealerships usually have specials they run on the coolant and other things. It's $18.95 a gallon right now by me. No brainier to use the factory stuff at that price, or a bit more.
  4. Jan 9, 2017 at 11:43 AM
    MilesToEmpty
    MilesToEmpty Well-Known Member
    Charles
    Frederick Co, MD
    '13 Baja TX
    Wheelers Progressive AAL, Firestone RideRite airbags.
    Going to bump an old thread.
    Was jump starting a coworker and noticed my coolant lank was at the "Low" marker.
    I recently flushed the coolant on my 2008 Prius which uses the Long Life Toyota stuff.
    https://www.amazon.com/gp/product/B004SL8568/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    But back at the question... 2013 has Pink coolant in it and has only ever been serviced at the dealership. My new bottle of 00272-SLLC2 is def red and not pink!
    Veryhelpfulforum likes this.
  5. Jan 9, 2017 at 11:50 AM
    Markcal
    Markcal Well-Known Member
    Just make sure to use the SLL coolant (pink) and not the LL coolant (red). The coolant you gave a link to states SLL coolant, so that should be OK.
  6. Jan 9, 2017 at 11:51 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    pink or red, I think you are splitting hairs. If you purchased the pre-diluted Toyota Super Long Life fluid you have the right stuff
  7. Jan 9, 2017 at 11:53 AM
    Markcal
    Not so, Red coolant or LL coolant are for pre-2005 Tacoma = different formula.
  8. Jan 9, 2017 at 11:56 AM
    glk21c
    MD
    yep, duly noted. SLL is the key
  9. Jan 9, 2017 at 12:36 PM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    I use AMSOIL Coolants!
  10. Jan 13, 2017 at 3:08 PM
    Jagfan904
    Jagfan904 Well-Known Member
    Brandon
    Silver double cab 07
    Painted rims, Stero, speakers, truck box, k and n cabin and engine air filter
    I went to the dealership and picked some up.
  11. Jan 13, 2017 at 4:01 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I just did a drain and flush on my truck. I used Pentofrost A4. It's OE compatible and picked it up at Autozone.
  12. Jan 13, 2017 at 4:56 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    I've used Zerex Asian or Valvoline Asian for mine. Have used the Valvoline more recently as it's cheap and readily available at several Walmarts here. Will drain the radiator and refill a couple times a year.
    Zerex: https://smile.amazon.com/gp/product/B0033QO022/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Valvoline: https://www.walmart.com/ip/Valvoline-Asian-Vehicle-Antifreeze-with-Zerex-Pre-Mix-1-gal/49660461
    R0dzilla75 likes this.
  13. Sep 2, 2019 at 3:44 PM
    DanK83
    DanK83 Well-Known Member
    Dan
    Maine
    2003 Tacoma SR5 V6 4X4
    I just ordered that Zerex red for my '03 Tacoma. $15/gal is pretty cheap on Amazon . com
  14. Aug 20, 2022 at 8:18 AM
    Mastiff37
    Mastiff37 Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    Resurrecting this thread... My 2011 Tacoma is at the "low" mark and I want to top off. I bought it used, so don't know the exact maintenance history for sure (I have the carfax and it indicates all maintenance at the dealer). It looks "pink" to me. Am I safe to put Toyota SLL in there? Or better yet, is there something at Oreilley or Autozone that will do the trick safely? Don't care so much about an extra $15, but it's a haul to get to the dealer.
  15. Aug 20, 2022 at 9:42 AM
    #35
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    I would say to just do a flush and be done with it just to be sure. Drain the radiator and then the two block drains. Fill up the radiator and reservoir with either OEM SLL or go with an Asian pink fluid like Pentosin A4 or Aisin pink coolant. Drive the truck for about a half hour with the A/C on hot. Let it cool down and check the coolant in the morning. If the reservoir is low fill it back up.
    Mastiff37 likes this.
  16. Aug 20, 2022 at 8:13 PM
    #36
    Mastiff37
    Tucson, AZ
    Almost $40 a gallon with tax for the Toyota stuff locally... :eek:
  17. Aug 21, 2022 at 6:42 AM
    #37
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    WalMart no longer sells the Zerex. When they carried it, it was $17/gal, an amazing price.
    Crom likes this.
