What kind of engine oil??
Discussion in '1st Gen. Tacomas (1995-2004)' started by MK ULTRA, May 10, 2010.
  1. May 10, 2010 at 6:57 AM
    MK ULTRA
    MK ULTRA [OP] Well-Known Member
    JIM
    Huntsville Ala
    4X4
    What kind of engine oil, viscosity/weight and make, are most of you using??
    I did a search but found nothing.
    My 2.7 has 64k miles on it and I want to start using synthetic in it. I have alot of 5-40 Mobil 1. I may use that.
    What's the opinion out there?
    Thanks
  2. May 10, 2010 at 7:07 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i use castrol 5w-30 with BG MOA additive
  3. May 10, 2010 at 7:19 AM
    blackwatertaco
    blackwatertaco If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    Mobile 1 Syn. And filter. I have about 7.5k on my oil and still looks clean as golden honey.
  4. May 10, 2010 at 7:23 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    it depends on if you want to push out your oil changes. ..if you do, go with something like castrol edge or mobil 1 ep. ..or amsoil, ..or pensoil ultra.
    if you're not going to extend your change interval. ..just go with a regular brand name synthetic.
    at any rate. ..i think the prefered weight is either 5 or 10w30
  5. May 10, 2010 at 8:39 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    Castrol GTX 5w-30 every 3000mi.
  6. May 10, 2010 at 9:02 AM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    x2, that's what I use.
  7. May 10, 2010 at 9:22 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    mobil1 or pennzoil platinum 5w30 and change every 5k miles.
  8. May 10, 2010 at 9:26 AM
    YotaDude01
    YotaDude01 Kentucky Boy
    KY
    01' TRD off-road
    castrol edge 5w-30
  9. May 10, 2010 at 9:40 AM
    jandrews
    '09 FourDubDee TRD OR
    Use whatever weight your owner's manual specifies. As far as brand, all the major brands give excellent results as long as you change on schedule.
    Personally, nothing has given me as good a result as Royal Purple. But try a bunch of stuff and draw your own conclusions.
    Also, oil analyses will help you determine how your engine wear is doing.
  10. May 10, 2010 at 1:49 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    Mobil 1 5w-30 every 3000 miles
  11. May 10, 2010 at 2:51 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Pennzoil 5w30 every 5k
  12. May 10, 2010 at 5:56 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Mobile One fully synthetic every 4-5k should be good. :D
  13. May 11, 2010 at 6:47 AM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    Castrol GTX 5w-30
  14. May 11, 2010 at 7:14 AM
    Boosted17
    Boosted17 Well-Known Member
    Cliff
    Florence, Ky
    Looking for a new Toyota Truck.
    2006 Corvette Z51 M6. Best mod ever!
    Castrol GTX 5w-30 about every 4.
  15. May 11, 2010 at 2:15 PM
    Way2muchtime
    Way2muchtime Well-Known Member
    Oregon
    99' 4Runner SR5 V6 4x4 / 08 Toyota Matrix XRS
    Anyone run Mobil Clean 5000? I just picked some up for our Matrix for $11 at Wally World (5qt jug). I like to change the oil every 3k anyways so synthetic is overkill.
    I was going to run the same stuff in my 4runner next oil change.
  16. May 11, 2010 at 2:53 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I use Mobil 1 5w-30 fully synthetic. Works like a charm!
  17. May 13, 2010 at 3:59 PM
    evanch123
    evanch123 Active Member
    denver
    1998 Tacoma Extra Cab
    K&N FIPK Jardine Cat Back
    I bought my 1998 tacoma with 100,000 miles on it. The first owner used mobile 1 5w 30 starting with the second oil change. That's all I use. I use a mobile 1 oil filter as well. I used to run 5000 mile intervals until I talked to http://www.blackstone-labs.com/ they analyzed my oil and my engine is in perfect health with no wear at 145,000 miles. They told me that this particular oil doesnt break down until 7,500 miles and to run my oil longer.
  18. May 13, 2010 at 4:16 PM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    2020 White SR5 4WD DC LB
    of course
    Mobil 1 for the truck, Royal Purple for the Bike. I just drink the extra Royal Purple, it is like grape juice (just a bit thicker though).:D
  19. May 17, 2010 at 6:21 AM
    MK ULTRA
    JIM
    Huntsville Ala
    4X4
    Thanks for all of the replies.
    I have several gallons of the older 5-40 Mobil 1 DIESEL/TRUCK oil. Guess I'll use it and run it for 7-8k miles or so.
    I don't think they even make that oil any more. Don't know what happened. They may have just changed the label.
    Thanks
  20. May 17, 2010 at 8:16 AM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    I put in Mobil 1 10w-40 fully synthetic in mine yesterday.
