What kind of Jack Stand to use with truck. what load capacity?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, Oct 13, 2010.
  1. Oct 13, 2010 at 8:27 AM
    JUJtacoma2010
    JUJtacoma2010 [OP] Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    I need to buy a jack and jack stands. what load capacity should I buy? would 3 ton jack stand work?
  2. Oct 13, 2010 at 8:30 AM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Yes, 3-ton stands will work. Remember that jack stands are rated per pair. So the 3-ton stands are actually 3000lbs each.
  3. Oct 13, 2010 at 8:34 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    get the tallest ones you can afford too, I always have to stack wood blocks under mine to reach the frame rails. It's really annoying.
  4. Oct 13, 2010 at 8:56 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I bought the big tall heavy stable 6 ton ones. I want to feel safe while I'm working under there. Also, trucks sit taller than cars, so you need to be able to have them extended taller; and the bigger ones tend to be taller.
    The ones at Kragen/OReilly freaked me out. After I bought them, I found that the adjustable catch had a very tenuous hold on the extension bar. I thought it could let go, so I returned 'em.
    My two cents: don't skimp here.
  5. Oct 13, 2010 at 9:07 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I have this problem too. It's a real PITA. Been thinking about getting another set that's taller.
  6. Oct 13, 2010 at 12:10 PM
    Eurosport
    Eurosport Well-Known Member
    rhino ramps
