what kind of jack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by das56170, May 24, 2008.
  1. May 24, 2008 at 9:14 PM
    das56170
    das56170 [OP] Well-Known Member
    Orange County
    2007 Tacoma Access Cab 4X4 SR5 (sold), 2002 Tundra Access Cab 4x4 SR5, TRD Offoad
    Tacoma - Flowmaster cat-back exhaust, volant cold air intake, 3" lift with AAL, 285/75 r 16 pro comp xterrains, 1" differential drop, spare tire mod, hypertech in-line speedometer calibrator, debadged
    For those of you who have a lifted truck what kind of jack are u carrying around for everyday driving, in case of a flat. after a 3" lift will the small jack that is supplied with the truck be big enough to lift the truck. I'm thinking about a getting a hi lift jack, but i'm not sure if that would work to lift up the truck by the frame. I've never used a hi lift jack. Where do you lift the truck with this type of jack. I don't feel like driving around with a floor jack.
  2. May 24, 2008 at 9:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I just keep a peice of 6x6 and a peice of 2x12 when off roading to put under the jack to prevent it from sinking into the soil. In town the factory jack seems to lift it just fine. :)
  3. May 24, 2008 at 9:21 PM
    das56170
    Orange County
    thanks
  4. May 24, 2008 at 10:42 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Ah, you don't know jack.
  5. May 25, 2008 at 4:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Hi-lifts are very nice to have but they do pose a problem on where to jack from on the trucks.
    If you go offroading at all - it's a good idea to get yourself some rocksliders anyway. The proper rocksliders (mounted properly to frame) can be used to lift the vehicle using a hi-lift jack. The reason rocksliders are so good - is because you can lift both the front & the rear. For the rear - a hitch is good to use a hi-lift on.
    I had a set of square tube rocksliders on my 96 welded to the frame -the hilift jack was awesome to use.
