What Kind of Oil, Antifreeze, gear Oil, P/S fluid, Brake, and clutch Fluid to Use
Discussion in '1st Gen. Tacomas (1995-2004)' started by brian8980, Dec 30, 2014.
  1. Dec 30, 2014 at 4:06 PM
    brian8980
    brian8980 [OP] Well-Known Member
    Brian
    Charlestown, MD
    98 Tacoma 4x4 2.7L 4C
    none, yet
    I know, I know, i am getting WAY ahead of myself on this thred and questions as i still have i would say 25-40 hrs worth of work on my taco in thread 2.7l issues and problems... but have been thinking about this now and trying to plan out my budget, when i see them pick them up, etc..
    So i have a 1998 tacoma, 2.7l with 4x4 manual..... figured while i have it in a warmer place then out side, do all the fluids as i will be 3/4ths through them anyways and most havent been done in 60k+ and i have 220k on the girl...
    so....
    1. What is a good synthetic oil to use?
    2. What is a good antifreeze to use? the normal pink stuff or regualar ok?
    3. What is a good transmission and transfer case gear oil to use?
    4. What is a good diff gear oil to use?
    5. What is a good brake fluid to use?
    6. What is a good clutch fluid to use?
    7. What is a good P/S fluid to use?
    If i have missed anythink, let me know. I have so basic ideas, but what some opinions before i give mine. Have beeen reading ALOT on here and its help out more then anyone knows. Thanks for the advice in advance, happy trails through the new year, cheers!
    Gimp
  2. Dec 30, 2014 at 4:16 PM
    GoldyLocks
    GoldyLocks Well-Known Member
    Mesa az
    97 caged 4x4 tacoma, SR1 Rhino
    LOL
    so....
    1. What is a good synthetic oil to use? mobile 1 synthetic 5w30
    3. What is a good transmission and transfer case gear oil to use? mobile 1 synthetic, transmission uses 65w90 i believe
    4. What is a good diff gear oil to use? front diff uses 95w140 and rear uses 65w90
    7. What is a good P/S fluid to use? dex meric
    my answers to ones i know in bold.
    the weights of the oil will likely change depending on where you live and what you use your truck for.
  3. Dec 30, 2014 at 4:27 PM
    brian8980
    Brian
    Charlestown, MD
    none, yet
    normal driving usually... with the ocassional huniting/fishing trip off road...and thanks...
  4. Dec 30, 2014 at 7:50 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; mattgecko's Underhood Lighting; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    My answer to MOST of your questions is Amsoil.
    1. SAE 5W-30 Signature Series
    2. OEM Toyota Red Long Life Coolant
    3. Severe Gear 75W-90
    4. Severe Gear 75W-90
    5. Series 500 High-Performance DOT 3 Brake Fluid
    6. Series 500 High-Performance DOT 3 Brake Fluid
    7. Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid
  5. Dec 31, 2014 at 6:04 PM
    jkulysses
    jkulysses Well-Known Member
    Jake
    Oregon
    01' Tacoma 4x4 3.4l 5 spd
    I enjoy doing oil changes so in my opinion synthetic is pointless. I run Dino oil & change it every 4 to 5k. I run whatever name brand is on sale but more often then not I use Super tech. Been using it for years.
    I just changed the oil in my rear end a few nights ago & used Valvoline full synthetic 75w-90. They only had 3 quarts of Valvoline left so in the front end I'm running Delo full synthetic 75-90.
    Transmission & transfer case I'm running Redline MT-90 75-90 full synthetic.
