What kind of paint to cover stock rims?
Discussion in 'Wheels & Tires' started by 08chocotaco, Nov 21, 2010.
  1. Nov 21, 2010 at 9:45 PM
    08chocotaco
    08chocotaco [OP] Well-Known Member
    TAYLOR
    San Diego/Los Angeles
    2016 Silver TRD Sport
    No current modifications
    What kind of paint do i use if i want to color my stock trd off road rims in black? i want them flat black or gloss black, either one is fine to me, most preferrably gloss.. if anyone has any questions, let me know. thanks: )
  2. Nov 22, 2010 at 12:31 AM
    Tackz
    Tackz Well-Known Member
    West Palm Beach, FL.
    '14 TRD Sport DC/LB 4x4
    Wet sand em' first with a 400 grit. Get as much gloss off as possible. Then a light coat of Rustoleum primer & then 2 coats of Rusto gloss black. Let dry, enjoy.
  3. Nov 22, 2010 at 12:45 AM
    Eurosport
    Eurosport Well-Known Member
    around the world
    plasti dip them
  4. Nov 22, 2010 at 6:58 AM
    08chocotaco
    TAYLOR
    and it comes out looking perfectly good? did you do the inside of the wheel also?
  5. Nov 22, 2010 at 7:01 AM
    CB6979
    CB6979 Active Member
    Mason, OH
    06 Tacoma SR5
    Tinted Tail Lights, De-Badged, Murdered Grill and Rear Bumper, DVD Head Unit, Tinted Windows. More to come when $$$ allows
    +1 Plasti Dip. Stuff is awesome
  6. Nov 22, 2010 at 7:04 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Back in the day (late 80s) when I was blacking out all my rims I used engine enamel because of its high-temp adhesion properties, it is less likely to peel because don't forget those wheels spin very fast-hense constant major windage. I would google the proper procedure for surface prep too:)
  7. Nov 22, 2010 at 7:12 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Wheels take alot of abuse- I would look into powder coating or a material which is a more durable finish then the rattle can approach. :cool:
  8. Nov 22, 2010 at 7:25 AM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    Here's how mine were done:
    1. Wash wheels using SOS pad and water. Mark and remove the weights.
    2. Sand with 320 grit wet & dry, don't forget to do the Toyota emblem on the center caps. Mask off the tires.
    3. Prime with NAPA 7220 self etching primer, three coats. Prime the backs first.
    4. After the primer dries, lightly sand with 600 grit then wash with mild soap and water, dry.
    5. Paint with NAPA 7244 Toyota trim black (this is the semi-gloss, like the bumpers and door handles), three coats doing the backs first. A NAPA paint store can put this paint in cans, but using a gun with medium reducer would be better. Prime and paint the wheels standing up on a low table of some sort.
  9. Nov 22, 2010 at 7:30 AM
    Tackz
    Or, you could do any of the above. Powder coating IS best though.
  10. Nov 22, 2010 at 7:44 AM
    trdtaco10
    trdtaco10 Well-Known Member
    Fayetteville, NC
    '10 TRD OR 4X4
    UWS toolbox, window tint, Bilstein 5100s on all four corners, black 16" TRD FJ wheels, 14" Shorty Antenna, Weathertech all weather floor liners, Satoshi Grill Mod, Rear leaf TSB, OME 885x's, Desert Racing UCAs, Icon 3 leaf AAL
    I used Duplicolor Wheel Coating. Here were my steps.
    1. Wash wheels and let dry.
    2. Sand with 400 grit and wipe down with acetone.
    3. After acetone dries, tape off the wheel or use the index card method.
    4. 3 coats of Duplicolor self-etching primer (very light coats)
    5. 2 coats of Duplicolor wheels coating, satin black. (light coats again!)
    6. Let cure for a day or so and your ready to go.
    If you want the added gloss you could spray them with the clear wheel coating right after the black. And I also found that you need something like rustoleum semi-gloss or gloss for the center caps. For some reason the duplicolor wouldn't stick.
    Whatever way you go I'm sure it will look great! Can't wait for pics!
  11. Nov 22, 2010 at 7:48 AM
    trdtaco10
    Fayetteville, NC
    '10 TRD OR 4X4
    I will agree that powdercoating is one of the most durable coatings but when you look at price it was gonna cost me 400+ depending on what powdercoating options I wanted and I painted my rims rattle can method for like 60 for everything and a few hours of my time. And if you get a chip in the powdercoating you have to live with it or get it redone. Get a chip or scratch with rattle can, tape off the small area, sand, spray, done.
  12. Nov 22, 2010 at 8:33 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    I used duplicolor engine enamel in gloss black..It lasts for a while with proper prep work.
    I'm currently getting my wheels powder coated and picking them up on Wednesday.
  13. Nov 22, 2010 at 9:48 AM
    08chocotaco
    TAYLOR
    ok so if i do it, this is what i got out of it... sand the whole rim inside and out with 320 grit san paper, the prime the whole rim inside and out with primer, 2 coats, let that fully dry, sand then wash again, then spray like three rounds of black paint, and then a couple of clear coat? if i am wrong, please tell me what i am missing... dont worry i will acid wash the whole rim front and back when i do this so they will be as clean as they possibly could be
  14. Nov 22, 2010 at 11:23 AM
    Who Dat Popcorn
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Well what I did was sanded with 400 grit, then went on to 600, then 1000. 3 coats of primer, 3 paint, and 3 clear. (Wheels where cleaned before each grit, and right before the first primer)
    Make sure you allow enough time for coats to dry. Putting them on too fast will cause problems.
    My way is a little excessive, but the paint lasted a very long time.
  15. Nov 22, 2010 at 12:00 PM
    08chocotaco
    TAYLOR
    No its totally understandable. how long did it stay on your riims for?
  16. Nov 22, 2010 at 12:28 PM
    Who Dat Popcorn
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    They lasted a good year. Of course I had little chips here and there, but when we started to get snow, the salt started eating the paint.
  17. Nov 22, 2010 at 1:59 PM
    08chocotaco
    TAYLOR
    well i wouldnt have to worry about that being i live in san diego:)
  18. Nov 22, 2010 at 2:31 PM
    IslandBoy71
    IslandBoy71 Well-Known Member
    Reggie
    Lakewood, CA
    06 TRD PreRunner Sport SR5 DC
    TRD Intake,Flowmaster Super 10 exhaust, King 2.5 c/o adjusted to 3inch front and King 2.5 rears w/AAL. Custom bed rack, rock sliders and rear tire carrier.
    Duplicolor Wheel paint or Plasti Dip if you dont want them to be permanent. FYI if you use plasti dip do not do any sanding!
  19. Nov 22, 2010 at 2:44 PM
    08chocotaco
    TAYLOR
    i want them to be more sperminent because im keeping my truck for as long as possible and if i want different, im sure someone would switch stock for black:) haha
  20. Nov 22, 2010 at 2:52 PM
    Azjohn
    Azjohn Well-Known Member
    arizona/SLO Ca/SF Ca.
    2010 trd sport
    debadged
    powder coat black is impossible to touch up a chip (and it will happen).<br>
