what lift kit would you use if you don't offroad?
Discussion in 'Suspension' started by TRD4UNC, Mar 25, 2013.
  1. Mar 25, 2013 at 2:50 PM
    TRD4UNC
    TRD4UNC [OP] Member
    There is so much information out there and I am so confused. I want a comfortable ride, i don't do any offroading, just 85% highway travel. I just want a higher stance to put bigger beefier tires. Just for looks really. Trying to stay under $800.....suggestions? i have a 2013 TRD Sport double cab preRunner
  2. Mar 25, 2013 at 3:00 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    I personally like my 5100's set at 1.75" and the rear TSB. It sits level, rides good. That slight lift enabled me to fit 265/75R16's. I still might get the spacer to correct the taco lean but for right now I'm satisfied with it.
  3. Mar 25, 2013 at 3:13 PM
    TRD4UNC
    TRD4UNC [OP] Member
    so a spacer kit? one local shop suggessted a ReadyLift SST 3" front, 2" rear lift. They do all the local toyota dealers lifts and use this kit
  4. Mar 25, 2013 at 3:16 PM
    Large
    Large Red
    Bingo, go for it..
  5. Mar 25, 2013 at 3:17 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Spacer kit would be the cheapest option, but if you are willing to spend $800 then dont do a spacer lift. At least go with bilstein 5100s with stock coils, set at 1.75" or 2.5" and a add a leaf in the rear with new shocks. The next step up would be getting aftermarket coils to go along with the 5100s
  6. Mar 25, 2013 at 3:17 PM
    Manwithoutaplan
    ID
    6 inch spacers in front and 6 inch blocks in the back.
  7. Mar 25, 2013 at 3:18 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Up travel for days
  8. Mar 25, 2013 at 3:18 PM
    TRD4UNC
    TRD4UNC [OP] Member
    what are the pros and cons of say for example a $350 spacer kit? like the readylift....
  9. Mar 25, 2013 at 3:18 PM
    Manwithoutaplan
    ID
  10. Mar 25, 2013 at 3:19 PM
    Manwithoutaplan
    ID
    fyi op i have 3 inch rubber spacers for the coils.
  11. Mar 25, 2013 at 3:20 PM
    Large
    Large Red
    Just do it, you can cram 285s and will be happy if you don't wheel.
  12. Mar 25, 2013 at 3:21 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Pros - cheap
    Cons - crappy ride, risk damaging your shocks, blocks in the rear prematurely wear out your springs and promote axle wrap.
    Honestly you might be happy with spacers, but why cheap out on parts for a brand new $25,000 + truck
  13. Mar 25, 2013 at 3:26 PM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    3" Rough Country Lift. Well Priced, Simple, Includes all you need, good ride, no vibrations, room for 33" tires, Clearance for offroad. This is all coming from ME, I actually own the kit and drive it every day on my 2012.
  14. Mar 25, 2013 at 3:29 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    3" body lift :rolleyes:
  15. Mar 25, 2013 at 3:33 PM
    Manwithoutaplan
    ID
  16. Mar 25, 2013 at 3:35 PM
    Monster Coma
    Corey
    I like the view of my frame:cool:
  17. Mar 25, 2013 at 3:39 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Pick up a spacer lift on here cheap from someone upgrading and run that. If you don't like it, well the money you saved on picking them up here you can then spend to re-install better parts and you'll be back to where you were. Lots of guys running spacers happily.
  18. Mar 25, 2013 at 4:11 PM
    Tarpon24
    Tarpon24 Well-Known Member
    Frankie
    Fl
    Trd
    Leveling kit, 20 in rims, flowmaster true duals, bullying watch dog,
    awsome hows gonna give me the hat and cd ????
  19. Mar 25, 2013 at 4:13 PM
    Manwithoutaplan
    ID
    I can make you Compilation Cd of Nickelback's greatest hits :p
  20. Mar 25, 2013 at 4:22 PM
    evanmb31
    evan
    connecticut
    09 trd off road
