What load range do you run?
Discussion in 'Wheels & Tires' started by maxpower29, Sep 26, 2012.
Load Range
Poll closed Jan 4, 2013.
  1. P
    20 vote(s)
    14.7%
  2. C
    34 vote(s)
    25.0%
  3. D
    20 vote(s)
    14.7%
  4. E
    62 vote(s)
    45.6%
  1. Sep 27, 2012 at 9:18 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    LT265/75R16 terra grapplers in E.
  2. Sep 27, 2012 at 9:40 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I'm going from an E down to a D or C. In 35's though.
  3. Sep 27, 2012 at 9:45 AM
    Hurtin Albertan
    Hurtin Albertan Free Man
    Duck
    on the road less traveled
    The mud hides the tree scrapes in the paint
    Huskyliner floor mats
    For summer I run Toyo Open Country MT's E-rated on 17" alloys. For winter I run Wrangler Duratrac E-rated on 16" steelies. Yeah it's overkill but the roads I use daily will destroy tires so its peace of mind for me. My truck earns a paycheck on beat up industry roads and my recreation pursuits are past the end of those same roads. No more separated tires causing me grief. IMHO though, C-rated tires would be my choice if my truck didn't hafta work and if they were available with the tread I want.
  4. Sep 27, 2012 at 9:46 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    So what, just because I'm not out tearing out my sidewall on rocks, I'm just a puddle jumper? I agree with brianpdx, your statement is a huge overgeneralization.
    Also, if you're going to be 2 days out, you should have been prepared with at least 1 full sized spare. Your situation was not the result of a soft sidewall, it was the result of not being prepared for the expedition.
  5. Sep 27, 2012 at 10:02 AM
    Joshman35
    Joshman35 Well-Known Member
    Josh
    White Mountains, Arizona
    09 Tacoma Custom
    Too many to list
    I destroyed both rear tires. I was as prepared as I should have been, except for E load tires.
  6. Sep 27, 2012 at 12:31 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Said the guy who walked out 2 days for help...
  7. Sep 27, 2012 at 12:34 PM
    Pugga
    Massachusetts
    :laughing:
  8. Sep 27, 2012 at 2:32 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    x2:cool:
  9. Sep 27, 2012 at 5:10 PM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Im wondering whats best for me. The 265/70/17 bfg ATs I have now or the tires Im looking at the dueler revo 2s. The revos though say the P rated can take 2833lbs, and yet my C rated bfs only take 2684lbs. Im thinking its better then what I have now then no? Same weight too
  10. Sep 27, 2012 at 5:14 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Wow, really? E range tires are made to handle large loads, period. Because of that they have very tough side walls to hold that weight. Tough side walls don't get flats easily. If you think your "using" all of you E range tires to their full extent, your wrong. Have you put 3500 lbs on one tire? Don't think so. Our little trucks don't have enough weight to bulge the side walls at low pressure.
  11. Sep 27, 2012 at 5:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    E range
  12. Sep 27, 2012 at 5:28 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    I am using E load on my winters, but only because it was the only load range available for my 265 75 R16. I ran C and D loads before with no issues. E loads may have 10 plies on the tread surface but may only have 2 plies on sidewalls. IMO some tires with 6 plies in the thread surface and 3 in the sidewall can be adequate for most applications. That's my $ 0.02 worth. :cool:
    mikeytacooo likes this.
  13. Sep 27, 2012 at 5:32 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I run P rated Hankook Dynapro ATM's. Go offroad about 5-6 times per year. They're more than adequate. It comes down to buying what you need. I would guess half the people who have E rated tires, have them just to say they have E rated tires.
  14. Sep 27, 2012 at 5:51 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    i may not be using the full weight.(or most guys on here with E rang. i had to them for the thinker side walls for offroading. oh and YES the truck WILL bulge the side walls on an E rang tire. i’ll take psi reading and pic of mine tomorrow.
    like i said above, i had got them for the thicker side walls.
  15. Sep 27, 2012 at 6:21 PM
    #35
    OZ-T
    Peter North
    British Columbia
    I have E rated Hankook ATm's , I have the E rated ones because that's the only rating available in 275/70/17 , before these tires I had E rated Hankook MT's , I had the E rated ones because that's the only rating available in 265/70/17
  16. Sep 27, 2012 at 6:22 PM
    #36
    90YotaPU
    Union County, NJ
    So you guys are the other half (the half that's not running them just to say they run them)? :notsure:
  17. Sep 27, 2012 at 6:24 PM
    #37
    OZ-T
    Peter North
    British Columbia
    After I tire of these ATm's , I'll get E rated KM2's , I'll get the E rated because that's the only rating available in 255/80/17
  18. Sep 27, 2012 at 6:24 PM
    #38
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    yeah. i did not get them just to say i have them. i off road some, also hunt and everything a lot.
    edit: also they only had D and E in the LT265/75R16.
  19. Sep 27, 2012 at 6:28 PM
    #39
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Goodyear MTR's 35x12.5R17 in load range C
  20. Sep 27, 2012 at 6:47 PM
    #40
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    I have E rated 265/75/R16 Michelin LTX A/T2s, E was the only option.
