What load range do you run?
Discussion in 'Wheels & Tires' started by maxpower29, Sep 26, 2012.
Load Range
Poll closed Jan 4, 2013.
  1. P
    20 vote(s)
    14.7%
  2. C
    34 vote(s)
    25.0%
  3. D
    20 vote(s)
    14.7%
  4. E
    62 vote(s)
    45.6%
  1. Sep 27, 2012 at 6:52 PM
    #41
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    285/75/16 Dualer MT's in C for me....
  2. Sep 27, 2012 at 6:55 PM
    #42
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    That's my next tire! :D
  3. Sep 28, 2012 at 12:34 AM
    #43
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    E
    285/75/16 KM2s
  4. Sep 28, 2012 at 12:54 AM
    #44
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    What tire is that?
  5. Sep 28, 2012 at 2:37 AM
    #45
    nyfishhunter
    nyfishhunter Well-Known Member
    Sean
    White Plains, NY
    2010 DC 4x4 OR Pyrite
    Weathertechs, Pop N Lock, Whitetail Sockmonkey, OEM bed mat, Undercover SE, Wet Okoles, OEM iPod interface, Rear Spring TSB, Illuminated 4x4 switch, DTRL, Timbrens, 5100s (front .85), Eibachs, 1.5 AAL, OEM running boards, FJ TRD center caps, diff breather mod, trimmed front flaps, ImMrYo mirror bracket, Grillcraft, painted white Sport grill black
    3 Cs and 1 E -- for 3 days. Check your tires before leaving the shop. I didn't until I got home. They said it was an honest mistake -- I think they thought I wouldn't check. Anyhow, after they reordered the 4th, I now have 4Cs. Love them. (Duratrac 265/75/16).
  6. Sep 28, 2012 at 3:40 AM
    #46
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    p is fine but it will be more puncture prone for sure.
  7. Sep 28, 2012 at 5:58 AM
    #47
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    oh you!
  8. Sep 28, 2012 at 6:55 AM
    #48
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    On my search for tires, I ran into the only E range being offered in a certain size. Had a set on this Tacoma for 4 days, took them off for the C rated tire. I would air down for a good enough ride, and the side wall started holding the truck up, not the air in the tire. 34 psi and below, the tires would squirm and move all over. Just my expierience. I'm going to be on the E boat soon enough, like OZ said, next tire is KM2 255/80r17, only one load range offered.
  9. Sep 28, 2012 at 8:34 AM
    #49
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My experiance with e rated has been good. With the oem p rated pos bfg's the truck felt like it was leaning into the corners and would follow the ruts in the road. I had it aligned a couple times after a 2" lift...didn't help. After going to the 265/75/r16 bfg a/t's in e rated the truck now feels like it's riding on rails in the turns...no leaning. Also, it no longer follows the ruts...tracks straight as an arrow. I run 36 psi front/34 back according to the chalk test. I've ran many sets of e rated bfg a/t's on Toyota's for years and honestly can't remember ever having a problem or a flat. Most have lasted around 70,000 miles. Are they over kill for these trucks...yep, but they do have their benifits.
  10. Sep 28, 2012 at 9:01 AM
    #50
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    x2. i came from the stock POS and i feel it rides much much better! i need to chalk test, maybe later today...
  11. Sep 28, 2012 at 1:29 PM
    #51
    maxpower29
    Jordan
    Nova Scotia, Canada
    With the extra weights I'm worried the suspension will wear faster and the power loss will be too much. I refuse to regear too. Too much of an upgrade for me
  12. Sep 28, 2012 at 3:24 PM
    #52
    ae111black
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
  13. Sep 28, 2012 at 3:25 PM
    #53
    BMOC
    Paden
    Phoenix, AZ
    hehe
  14. Sep 28, 2012 at 3:25 PM
    #54
    PLC721
    Patrick
    Chandler, Az
    I'm still debating dude
  15. Sep 28, 2012 at 3:26 PM
    #55
    BMOC
    Paden
    Phoenix, AZ
    I wanted you to get them first so I could see how bad they chunk in the desert :eek:
  16. Sep 28, 2012 at 3:27 PM
    #56
    PLC721
    Patrick
    Chandler, Az
    :burnrubber:
  17. Sep 28, 2012 at 3:38 PM
    #57
    OffroadToy
    What power loss? Honestly, i haven't noticed any difference. :notsure:
  18. Sep 28, 2012 at 4:34 PM
    #58
    maxpower29
    Jordan
    Nova Scotia, Canada
    well I lost some power going from 265/65/17 dueler to 265/70/17 bf a/t
  19. Sep 28, 2012 at 6:55 PM
    #59
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    really ?
  20. Sep 28, 2012 at 6:58 PM
    #60
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Keep in mind, he has a 4 banger, went to a taller tire, went from H/T to an aggressive A/T and a heavier tire. I wouldn't doubt that you'd feel the effects of all that with the smaller engine.
