What locker and what gear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LuckeyTRD, Jun 28, 2010.
  1. Jun 28, 2010 at 12:22 PM
    LuckeyTRD
    LuckeyTRD [OP] rIDIN wHEELIEz!!
    Cole
    Evans, GA
    2010 PreRunner ALL TERRAIN
    BHLM, Blacked out tails, window tint 5%, tinted windshield , 8000k hids hi/lo and fogs. Black side badges, debadged tailgate, camburg 1.25" uniball UCA's, Camburg 4" spindles, ext. brake lines, Fox remote resi coilovers. Fox 2.0 Pro series rear piggybacks, 3" Allpro Leaf pack, OEM roof rack, Brush guard. Custom TRD allterrain decals. UWS low profile black toolbox
    i have a 2010 dc trd sport and im lookin into upgrading the rear end, ill be running 33's within the next two months and i want to have some serious legit traction (no more gay LSD) Im pretty sure i wanna run a 4.11 but idk what brand and i def dont know what brand locker.... and i wanna kinda keep i the cost to a minimum. SO HELP ME OUT!!! LOL
  2. Jun 28, 2010 at 12:28 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    well the best locker you can get is the ARB selectable air locker.
    *takes a seat and grabs :popcorn:*
  3. Jun 28, 2010 at 1:09 PM
    LuckeyTRD
    Cole
    Evans, GA
    i want some... nvm i got some.. :popcorn:
  4. Jun 28, 2010 at 1:13 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    oh I think that locker runs about 800 bucks or so, plus youll need a compressor and have it all installed.
  5. Jun 28, 2010 at 1:35 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    The ARB is the sworn by locker by most hardcore wheelers (doing stuff your Prerunner never will be able to... sorry I say it cause I had one :D) As for "upgrading the diff" are you referring to swapping out for a whole new diff or... ? That's some serious work with suspension modifications, drive-shaft modifications, brakes, ect ect. The rear ends on our trucks are pretty robust, though some of the real hardcore guys have been breaking them... You're probably fine just running an ARB.
    Also, note your rear diff is open, not LSD. The Auto-LSD uses the breaks to simulate a clutch engaged LSD... The "true" clutch LSD in on the sports was dropped in 09+ for auto-LSD.
  6. Jun 28, 2010 at 2:11 PM
    LuckeyTRD
    Cole
    Evans, GA
    ok... i dont wanna go with an air locker although i have the type of compressor for it already and most of the braided lines layin around the shop but i just wanna be able to do what the offroad can do (hit a button, hit the gas, and leave TWO skid marks lol)
  7. Jun 28, 2010 at 2:14 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I think your only option for a push button locker is either the TRD off road e-locker or the ARB air locker
  8. Jun 28, 2010 at 2:18 PM
    LuckeyTRD
    Cole
    Evans, GA
    ok exactly how badass is the airlocker? u guys have peaked my attention
  9. Jun 28, 2010 at 2:21 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Check out youtube.... it's all over.
    That said if you're looking for two skid marks on the pavement... LSD is a much better bet as it will put a lot less strain on the drive-train. Locked burnouts will cause a decent amount of axle wrap.... which causes things to break.
  10. Jun 28, 2010 at 2:25 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    ^x2
    lockers are for un-improved roads only
    turn off your ATRAC and all that other crap and you should be able to break loose and spin those tires
    Kids and 30k trucks :rolleyes:
  11. Jun 28, 2010 at 4:10 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How badass is the ARB?? I had a jeep with a front & rear ARBs.
    That locker is sooo damn good, that it can get you into trouble if you're not careful with it. It can scare the bejesus out of you while offroading in extreme situations.
    Here's an example: You start driving up this really long dirt incline (arb is not engaged). You get 3/4 of the way up and you suddenly stop moving. All of your tires are spinning and you start moving backwards. WHile you're still spinning the tires....and not moving, you reach down and hit the ARB Switch. The wheels lock up and you start moving forward. It's THAT frigin awesome!!
  12. Jun 28, 2010 at 4:29 PM
    splitbolt
    splitbolt Well-Known Member
    Arkansas
    2016 TRD OFFROAD DCSB MGM
    Is RD129 the correct part number for this application?
    I have an '07 Prerunner I'm considering doing this to; I should be okay with swapping out my mechanical LSD?
  13. Jun 28, 2010 at 8:01 PM
    LuckeyTRD
    Cole
    Evans, GA
    x2 ?
  14. Jun 28, 2010 at 8:10 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R MGM TRDOR Premium Daddy Wagon
  15. Jun 29, 2010 at 6:10 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    you dont have a mechanical LSD, you have the auto, brake controlled lsd.
