What maintenance procedures are "feel good" but of dubious usefulness?
Discussion in '1st Gen. Tacomas (1995-2004)' started by AmherstAndy, Oct 10, 2019.
  1. Oct 25, 2019 at 10:00 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I pray that the new F-350 Super Duty with the Power Stroke Diesel I just bought two weeks ago doesn't suffer from similar engineering oversights. Yes, I still have my Taco.
  2. Oct 26, 2019 at 6:12 AM
    Glamisman
    Glamisman Well-Known Member
    I had a mechanic buddy that works at a Ford dealership... should be a problem free truck. The issues I have with Fords after the 2003 M.Y. were "how" the repairs were performed. When I found out that the cab has to come off the frame to do major motor repairs I said pass on Ford for my next HD truck. I have been a Ford guy my whole life and this was the deal breaker. I buy new and keep for a lifetime so long term maintenance is a major issue with me. My buddy says that there are still emmissions issues with the diesels but that work is 2 bays down from him.
  3. Oct 26, 2019 at 6:32 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    at what age would you recommend it be done, the timing belt and all that
    i have the years but not the mileage on mine currently
  4. Oct 26, 2019 at 6:34 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    When it's been proven that the WS fluid that toyota uses is shit and should be replaced. Some people just wanna be set
    lawless and cruxofthebisquit like this.
  5. Oct 26, 2019 at 6:49 AM
    Indy
    Indy Master of all I survey.
    There's a lot that are pointless at best. Short oil changes tops the list. The 3k m change was brought out by the oil companies. I surprised they didnt propose a 300 mile change. Oil doesn't go bad from age. It's pretty common to see a 5k recommended car go to 15k, send in an analysis and get told they can go another 5-10k. Send it in again and get told the same. I remember 1 porsche owner that bragged he did an oil change after every fill up or else the car didn't "feel right". I guess if I went through 1 tank of gas a year I'd do the same.
    Seafoam is dubious. I've used it on 2 or 3 different vehicles, no change. My current ride had a sticky injector and I went through 2 bottles. It still has a sticky injector. The smoke vids that people use as proof that it's working are a joke. All that proves is it creates smoke. The internal pics I've see show similar results to water injection.
    Radiators are not a maintenance item. Some people change them regularly and have never had one fail, which is their proof. I wear white socks, also never had a radiator fail. So proof that the replacees also wear white socks... coincidence and causation aren't the same.
    Lbj will wear over time and need replaced but they wear slowly and give lots of advanced notice when it's time.
    Rubber and plastic will fail eventually so belts and hoses are a wear item
  6. Oct 26, 2019 at 6:55 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    thank you
    many on TW would disagree, but i don't necessarily know what type of advanced warning i would get?, mine are still original 22 years old at 131k
    and they seem perfectly fine, but i really don't know much about that front suspension stuff
  7. Oct 26, 2019 at 7:23 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    proven by whom?
  8. Oct 26, 2019 at 7:28 AM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Some scientific testing they did in Europe. Basically it was fluid that was created so that companies didnt have to pay excessive fees or taxes or something by having vehicles that required less maintenance. So instead of like 60k miles. The said it was lifetime of the transmission which in turn was a loop hole for paying less on something. I wanna say emissions. Been a few years since I saw it.
    Another member on here actually had a whole write up on it
    Edit: basically the WS fluid would heat up quick and couldn't Hold Veracity well. Idk. I'd have to look up the info
  9. Oct 26, 2019 at 7:29 AM
    Indy
    Noise increases, alignment wanders, tire wear changes... generally people notice odd tire wear and clunks, then take it in for an alignment and find they need to replace Lbj before they align. It's rare to have a perfectly fine joint and have it fail catastrophically.
    cruiserguy and GQ7227[QUOTED] like this.
  10. Oct 26, 2019 at 7:48 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    I flush/change all my fluids @ 30,000 miles,,, change the oil @3,000, dino oil,,, suffering through the PO not doing this because it uses a qt about every 1000 miles, engine wear. If I had a auto, I'd do the total flush with the BG flush between 30 & 50 for a PM.
    truck passed inspection on the tread mill this time,, the only thing I did different was use the BG 44k to help clean up the convertor that'd just barely fail just about everytime. I'll still put a after market on it later on, probably before next inspection is due.
  11. Oct 26, 2019 at 7:52 AM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Cleaning the MAF sensor at every oil change is a required one for me. As dirt builds up it causes the engine to be less responsive off of idle. I let it go on one of my Tacomas for a while (life got busy) and after cleaning it I was surprised how much better it drove. I've also just straight up replaced it with OEM(great deal on eBay for them right now) as even after cleaning something wasn't right on the truck and I got a very occasional too lean code. I've diagnosed several coworkers rigs that they were getting bad mileage, bad drivability, etc with to a dirty sensor.
  12. Oct 26, 2019 at 8:12 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Maybe we should turn the thread into best "practice maintenance items" that are not commonly known. :)
    Over the years, I've seen a lot of problems appear on cars from neglect of uncommonly known maintenance items. The owners thought they were providing exceptional maintenance by changing the oil and filter every 3,000 miles. It take a lot more than that to keep your vehicle running like its still new well after it crosses the 200,000 mile mark.
  13. Oct 26, 2019 at 8:40 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    :oops: I'd prefer this too, just feels better..... :D (I'm being funny, before everyone wants to tear me up)
    CS_AR[QUOTED] likes this.
  14. Oct 26, 2019 at 8:44 AM
    CS_AR
    Oh I know.. Maybe we don't think a vehicle should feel like it is "broken in" good until after it has 200,000+ miles. Before that, its just a baby.
    cruiserguy[QUOTED] and GQ7227 like this.
  15. Oct 26, 2019 at 8:44 AM
    #35
    GQ7227
    GQ7227 mw survivor
    J A Y
    sounds good to me!
    tony2018 likes this.
  16. Oct 26, 2019 at 8:46 AM
    #36
    tony2018
    tony2018 Well-Known Member
    Saw a ford diesel truck stuck at home depot yesterday.... he was fiddling under the hood and going back and forth I guess trying to start it. Cold yesterday and the wind chill was the killer part.
  17. Oct 26, 2019 at 8:47 AM
    #37
    tony2018
    Sayin.
  18. Oct 26, 2019 at 9:35 AM
    #38
    BillsSR5
    bill
    2014 SR5
    LINKS to any of this info? smoking gun post #202:burp: >>https://www.tacomaworld.com/threads...transmission-now.331521/page-11#post-12286244
  19. Oct 26, 2019 at 9:48 AM
    #39
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    10 yrs. seems pretty safe no matter the mileage. Unless we're talking about someone like the million milers of Tundra fame who drive 24/7 from new. Had someone done that with a 3.4 I would bet they could have done 250K changes but that's why I was asking if ANYONE ever heard of a belt breaking under 10 yrs. old.
    Did you know Honda J45's (their 3.5 V6 used in everything) have a slight (or maybe not so slight, it pops up on their forums pretty often) reputation for factory tensioners going bad no matter the mileage? I had a Sienna (3.0 engine) tensioner, bagged as factory, fail at 20K but i really think it was a well labled counterfeit from China.
    CS_AR and GQ7227[QUOTED] like this.
  20. Oct 26, 2019 at 9:53 AM
    #40
    cruxofthebisquit
    Orange Texas
    2000 TRD
    cruiserguy and CS_AR like this.
