What motor is this
Discussion in '1st Gen. Tacomas (1995-2004)' started by yellowdog5, Feb 8, 2018.
  1. Feb 8, 2018 at 5:52 PM
    Madjik_Man
    Colorado Front Range
    What year is your truck?
    There are factory service manuals (FSM) we can send you in PDF format.
    One thing that's very helpful, and somewhat customary, is to enter your truck's info into your profile so it shows up under your name after "vehicle:". It'll help you get help by members when you're asking a question because we can see what year, engine, transmission, 4x4 or 2x4, etc...
    HSmith_11 likes this.
  2. Feb 8, 2018 at 8:09 PM
    Pervy
    Pervy Well-Known Member
    East Texas
    2.4 Tacoma, 3.4 4Runners
    Assuming the engine hasn't been changed out, the easiest and most definitive way to figure out what engine it is would be to just call up your Toyota dealership with your vin and have them tell you what exact engine it is. Haha better then having us play detective.
  3. Feb 9, 2018 at 1:27 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I think I know what you mean. Earlier 4-cyl 1st gen models have engines with distributor and 4 high voltage wires going to each spark plug. The distributor was on the pass. side of the engine, like in my "Taliban Truck":
    Newer models have 4 coil packs one on each spark plug so there is no high voltage wires, no distributor. Each coil pack is connected straight to ECU (of course low voltage). This is probably why the engine looks different.
    scocar, TacoTRD78, JimBeam and 2 others like this.
  4. Feb 9, 2018 at 1:32 AM
    yayayayayaya
    yayayayayaya Active Member
    Patrick
    Alaska
    1999 V6 Tacoma
    Keeping it tame
    Definitely not a 3vze, currently on a rebuild of one of those. That may have been answered already...
  5. Feb 9, 2018 at 1:34 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    What he said that’s basically the main difference... if you need to do intake gaskets it’s changes a bit too but those very rarely go bad. What do you intend to do in a “tune up” valve clearances? Valve cover gasket? Or dobyou just mean oil change check brakes, and all fluilds? Anyway goodluck find the what have you done to your first gen today thread super helpful guys less trolling
    TacoTRD78 likes this.
  6. Feb 9, 2018 at 2:08 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Manuals like the chilton/ clymer can be a big help, but I agree they're confusing when they cover a wide range of vehicles. That looks like the 2.7 3rz-fe to me.
  7. Feb 9, 2018 at 3:40 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    As someone else said, I'd go with the factory service manual (FSM). There are some links around here and other sites where you can get the full FSM. This site cannot host the FSM itself, since it is basically a pirated commercial product... But you can find it. You can get one at a dealer too, but they're rather expensive, like over $100, iirc.
  8. Feb 12, 2018 at 3:17 AM
    yellowdog5
    yellowdog5 [OP] Well-Known Member
    2002 Tacoma SR5 4wd 2.7L
    Yes, you are describing what I'm pretty sure I have, there is a bar that goes across the top of all of the coil packs, not sure what to do to take it off, a video or manual with some photos would sure be helpful.
  9. Feb 12, 2018 at 6:44 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Welcome!
    I use www.toyota.com to record my oil changes & all other maint. Click on "Owners" at the top right.
    You can also look up all factory service work your trucks had by previous owners.
  10. Feb 12, 2018 at 8:02 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I think you are confusing the injectors and coil-packs. On the driver-side of the engine, that 'bar' is the pressurized fuel rail which goes over the tops of (and connects to) the fuel injectors.
    The top of one of the coil-packs (#1) is clearly seen on top of the valve cover. Coil-pack #2 is barely visible behind that hose connecting the valve cover to the throttle body.
    I wonder if the original motor was swapped with a motor not intended for the American market. (JDM?)
  11. Feb 12, 2018 at 9:02 AM
    yellowdog5
    Thanks, it's a 2002, I added the info.
  12. Feb 12, 2018 at 9:03 AM
    yellowdog5
    I think you're right I wondered if they might be injectors but where are the spark plugs? Did you see my photo? There are no wires coming out of the top of the motor.
  13. Feb 12, 2018 at 9:22 AM
    yellowdog5
    It's a 3rz but where are the plugs?
  14. Feb 12, 2018 at 1:11 PM
    tan4x4
    Rick
    Folsom, CA
    I believe your truck has a 'Coil-On-Plug' (COP) type of ignition system.
    This means instead of having 1 or 2 coils, providing the 14,000-volt sparks for the 4 spark plugs,
    the truck has one coil for each spark plug. Each coil connect directly to the top of the spark plug,
    therefore there are no 'fat' plug wires. You can see the top of the COP clearly on top of the
    valve cover (I use the term 'coil-pack').
    To get to plug #1, disconnect the COP from the harness, remove that little bolt,
    and the COP should lift right up and off the plug, with a little resistance.
    Then you'll be able to look down that hole, and see the plug.
    You need a long extension to use along with the spark plug socket.
    To get to the other 3 'COPs', you need to remove some intake parts to get at them.
  15. Feb 12, 2018 at 4:13 PM
    #35
    RysiuM
    Rysiu
    ^ this. V6 engine has 3 coil packs running 2 spark plugs each. So there is a high voltage wire going from a coil pack to spark plugs.
    I4 has 4 coil packs each placed on the top of the spark plug. So the high voltage wire from each coil goes straight down to the spark plug under it.
  16. Feb 12, 2018 at 5:16 PM
    #36
    yellowdog5
    THANK YOU!, don't know why I couldn't see it before, but your explanation makes it very clear. I can do it now, should I replace the coils, or is there a way to test them? I have a multi meter but would need instructions on how to test them.
  17. Feb 12, 2018 at 5:37 PM
    #37
    Madjik_Man
    I can send you the FSM for the 01-02 but the folders are named with abbreviations. Kind of hard to navigate them all.
    Maybe someone else has a better copy?
    If not I'll send you what I have.
  18. Feb 12, 2018 at 5:45 PM
    #38
    tan4x4
    Rick
    Folsom, CA
    If you don't have any symptoms, and just want to do a basic tuneup, then
    : new plugs, new PCV, new air filter, clean MAF sensor.
    Are you having any symptoms, like poor idle, bad mileage, check engine light is on, etc ?
    Don't replace coils ($$$) unless they are bad.
    The Haynes manual may have a way to test them (need a multimeter).
  19. Feb 13, 2018 at 6:42 AM
    #39
    yellowdog5
    I'll start a thread asking about the FSM, if I don't have any luck I'll get back to you.
  20. Feb 13, 2018 at 6:45 AM
    #40
    yellowdog5
    The only thing I notice is the check engine light on, the code is P0300, I wanted to fix the things I can do before taking it to the shop, and it's probably time for a tuneup, it has about 18000 miles on it since I got it 12 years ago (yes, that's right, it's not used a lot)
